Depuis une reinstallation totale suite au passage du PI3B+ au PI4 , je me suis apercu d'une erreur dans les logs" Error: (Zigate ) ota_decode_new_image - invalid file size read .empty - 0 " ,une idée pour resoudre ce soucis ,
Ci joint log demarrage :
2019-12-21 02:30:08.438 Sunrise: 08:41:00 SunSet: 16:55:00
2019-12-21 02:30:08.438 Day length: 08:14:00 Sun at south: 12:48:00
2019-12-21 02:30:08.438 Civil twilight start: 08:04:00 Civil twilight end: 17:32:00
2019-12-21 02:30:08.438 Nautical twilight start: 07:23:00 Nautical twilight end: 18:13:00
2019-12-21 02:30:08.438 Astronomical twilight start: 06:45:00 Astronomical twilight end: 18:52:00
2019-12-21 02:30:08.719 Active notification Subsystems: email, gcm (2/13)
2019-12-21 02:30:08.737 Starting shared server on: :::6144
2019-12-21 02:30:08.296 Status: Domoticz V4.11579 (c)2012-2019 GizMoCuz
2019-12-21 02:30:08.301 Status: Build Hash: 289b1cf80, Date: 2019-12-19 11:30:06
2019-12-21 02:30:08.301 Status: Startup Path: /home/pi/domoticz/
2019-12-21 02:30:08.701 Status: PluginSystem: Started, Python version '3.7.3'.
2019-12-21 02:30:08.727 Status: WebServer(HTTP) started on address: :: with port 8081
2019-12-21 02:30:08.734 Status: WebServer(SSL) started on address: :: with port 8443
2019-12-21 02:30:08.737 Status: TCPServer: shared server started...
2019-12-21 02:30:08.737 Status: RxQueue: queue worker started...
2019-12-21 02:30:10.738 Status: Hardware Monitor: Started
2019-12-21 02:30:10.793 Status: (LGTV) Started.
2019-12-21 02:30:10.793 Status: GPIO: This hardware is deprecated. Please transfer to the new SysFS hardware type!
2019-12-21 02:30:10.796 Status: (Zigate ) Started.
2019-12-21 02:30:10.796 Status: EventSystem: reset all events...
2019-12-21 02:30:10.806 Status: EventSystem: reset all device statuses...
2019-12-21 02:30:10.902 Status: Python EventSystem: Initalizing event module.
2019-12-21 02:30:10.903 Status: EventSystem: Started
2019-12-21 02:30:10.903 Status: EventSystem: Queue thread started...
2019-12-21 02:30:10.970 Status: PluginSystem: Entering work loop.
2019-12-21 02:30:11.493 (Zigate ) runmode_with_gpiocommand
2019-12-21 02:30:11.493 (Zigate ) + Checkint GPIO PINs
2019-12-21 02:30:11.565 (Zigate ) + Checkint GPIO PINs
2019-12-21 02:30:11.695 (Zigate ) Start Network: Network joined / formed Status: 01
2019-12-21 02:30:11.131 Status: (LGTV) Entering work loop.
2019-12-21 02:30:11.131 Status: (LGTV) Initialized version 0.7, author 'Chris Gheen @GameDevHobby'
2019-12-21 02:30:11.378 Status: (Zigate ) Entering work loop.
2019-12-21 02:30:11.378 Status: (Zigate ) Initialized version beta-4.6, author 'zaraki673 pipiche38'
2019-12-21 02:30:11.384 Status: (Zigate ) Zigate plugin beta-4.6.038 started
2019-12-21 02:30:11.384 Status: (Zigate ) Debug: 0
2019-12-21 02:30:11.384 Status: (Zigate ) Python Version - 3.7.3 (default, Apr 3 2019, 05:39:12)
2019-12-21 02:30:11.384 [GCC 8.2.0]
2019-12-21 02:30:11.384 Status: (Zigate ) Switching Heartbeat to 5 s interval
2019-12-21 02:30:11.384 Status: (Zigate ) DomoticzVersion: 4.11579
2019-12-21 02:30:11.384 Status: (Zigate ) DomoticzHash: 289b1cf80
2019-12-21 02:30:11.384 Status: (Zigate ) DomoticzBuildTime: 2019-12-19 11:30:06
2019-12-21 02:30:11.384 Status: (Zigate ) load PluginConf
2019-12-21 02:30:11.386 Status: (Zigate ) allowOTA set to 1
2019-12-21 02:30:11.386 Status: (Zigate ) batteryOTA set to 1
2019-12-21 02:30:11.386 Status: (Zigate ) filename set to /home/pi/domoticz/plugins/Zigate/Conf/PluginConf-09.json
2019-12-21 02:30:11.387 Status: (Zigate ) pluginHome set to /home/pi/domoticz/plugins/Zigate/
2019-12-21 02:30:11.387 Status: (Zigate ) homedirectory set to /home/pi/domoticz/plugins/Zigate/
2019-12-21 02:30:11.387 Status: (Zigate ) pluginData set to /home/pi/domoticz/plugins/Zigate/Data/
2019-12-21 02:30:11.387 Status: (Zigate ) pluginConfig set to /home/pi/domoticz/plugins/Zigate/Conf/
2019-12-21 02:30:11.387 Status: (Zigate ) pluginOTAFirmware set to /home/pi/domoticz/plugins/Zigate/OTAFirmware/
2019-12-21 02:30:11.387 Status: (Zigate ) pluginReports set to /home/pi/domoticz/plugins/Zigate/Reports/
2019-12-21 02:30:11.387 Status: (Zigate ) pluginWWW set to /home/pi/domoticz/plugins/Zigate/www/
2019-12-21 02:30:11.387 Status: (Zigate ) Opening DomoticzDB in raw
2019-12-21 02:30:11.403 Status: (Zigate ) Plugin Database: DeviceList-9.txt
2019-12-21 02:30:11.421 Status: (Zigate ) DeviceConf loaded
2019-12-21 02:30:11.421 Status: (Zigate ) load ListOfDevice
2019-12-21 02:30:11.471 Status: (Zigate ) Entries loaded from /home/pi/domoticz/plugins/Zigate/Data/DeviceList-9.txt : 9
2019-12-21 02:30:11.475 Status: (Zigate ) Transport mode: PI
2019-12-21 02:30:11.491 Status: (Zigate ) Python version: ['3.7.3 (default, Apr 3 2019, 05:39:12) ', '[GCC 8.2.0]'] dist: ('debian', '10.2', '') linux_distribution: ('debian', '10.2', '') system: Linux machine: armv7l platform: Linux-4.19.86-v7l+-armv7l-with-debian-10.2 uname: uname_result(system='Linux', node='raspberrypi', release='4.19.86-v7l+', version='#1283 SMP Fri Nov 29 18:37:40 GMT 2019', machine='armv7l', processor='') version: #1283 SMP Fri Nov 29 18:37:40 GMT 2019 mac_ver: ('', ('', '', ''), '')
2019-12-21 02:30:11.587 Status: (Zigate ) Connection Name: Zigate, Transport: Serial, Address: /dev/serial0
2019-12-21 02:30:11.587 Status: (Zigate ) Connection open: Name: 'ZiGate', Transport: 'Serial', Protocol: 'None', Address: '/dev/serial0', Port: '', Baud: 115200, Connected: False, Parent: 'None'
2019-12-21 02:30:11.593 Status: (Zigate ) Request Disabling Accepting new Hardware
2019-12-21 02:30:11.593 Status: (Zigate ) Trigger a Topology Scan
2019-12-21 02:30:11.593 Status: (Zigate ) Trigger a Energy Level Scan
2019-12-21 02:30:11.696 Status: (Zigate ) Zigate details IEEE: 00158d0001ed40bc, NetworkID: 0000, Channel: 11, Status: 01: ZIGATE - [01] Incorrect Parameters
2019-12-21 02:30:11.696 Status: (Zigate ) Non 'Factory new' Restart status: RUNNING
2019-12-21 02:30:11.747 Status: (Zigate ) Major Version Num: 0003
2019-12-21 02:30:11.747 Status: (Zigate ) Installer Version Number: 031a
2019-12-21 02:30:11.795 Status: MQTT: Connecting to 127.0.0.1:1883
2019-12-21 02:30:11.996 Status: MQTT: connected to: 127.0.0.1:1883
2019-12-21 02:30:12.150 Status: (Zigate ) Accepting new Hardware: Disable
2019-12-21 02:30:12.196 Status: MQTT: Subscribed
2019-12-21 02:30:12.251 Status: (Zigate ) Zigate addresses ieee: 00158d0001ed40bc , short addr: 0000
2019-12-21 02:30:12.251 Status: (Zigate ) Network state UP, PANID: 6760 extPANID: 0xc4326613119ca66f Channel: 11
2019-12-21 02:30:12.355 Status: (Zigate ) Number of devices recently active in Zigate = 5
2019-12-21 02:30:24.419 (Zigate ) Switch Blue Led On
2019-12-21 02:30:24.420 Status: (Zigate ) Zigate set to Certification : CE
2019-12-21 02:30:24.420 Status: (Zigate ) Start Web Server connection
2019-12-21 02:30:24.433 Status: (Zigate ) Web backend for Web User Interface started on port: 9440
2019-12-21 02:30:24.433 Status: (Zigate ) Plugin with Zigate firmware 031a correctly initialized
2019-12-21 02:30:24.441 Status: (Zigate ) Available Firmware Type: 4545 version: 23014631 - filename: 159699-5.1-TRADFRI-remote-control-2.3.014.ota.ota.signed size: 182590 Bytes
2019-12-21 02:30:24.447 Status: (Zigate ) Available Firmware Type: 8705 version: 12221572 - filename: 10035514-TRADFRI-bulb-ws-1.2.221.ota.ota.signed size: 172734 Bytes
2019-12-21 02:30:24.453 Status: (Zigate ) Available Firmware Type: 8707 version: 12221572 - filename: 10035534-TRADFRI-bulb-ws-gu10-1.2.221.ota.ota.signed size: 172734 Bytes
2019-12-21 02:30:24.459 Status: (Zigate ) Available Firmware Type: 4549 version: 22008631 - filename: 10005778-4.1-TRADFRI-onoff-shortcut-control-2.2.008.ota.ota.signed size: 179582 Bytes
2019-12-21 02:30:24.464 Status: (Zigate ) Available Firmware Type: 4548 version: 12214572 - filename: 159700-TRADFRI-motion-sensor-1.2.214.ota.ota.signed size: 157822 Bytes
2019-12-21 02:30:24.471 Status: (Zigate ) Available Firmware Type: 16643 version: 21022631 - filename: 10046695-1.1-TRADFRI-light-unified-w-2.1.022.ota.ota.signed size: 202878 Bytes
2019-12-21 02:30:24.477 Status: (Zigate ) Available Firmware Type: 16641 version: 12245572 - filename: 159495-TRADFRI-transformer-1.2.245.ota.ota.signed size: 181118 Bytes
2019-12-21 02:30:24.483 Status: (Zigate ) Available Firmware Type: 4552 version: 20022623 - filename: 10039874-1.0-TRADFRI-motion-sensor-2-2.0.022.ota.ota.signed size: 186814 Bytes
2019-12-21 02:30:24.489 Status: (Zigate ) Available Firmware Type: 4487 version: 22009631 - filename: 10037585-5.1-TRADFRI-connected-blind-2.2.009.ota.ota.signed size: 186942 Bytes
2019-12-21 02:30:24.495 Status: (Zigate ) Available Firmware Type: 4354 version: 22005631 - filename: 10037603-3.1-TRADFRI-signal-repeater-2.2.005.ota.ota.signed size: 189822 Bytes
2019-12-21 02:30:24.500 Status: (Zigate ) Available Firmware Type: 8449 version: 12214572 - filename: 159696-TRADFRI-bulb-w-1000lm-1.2.214.ota.ota.signed size: 168318 Bytes
2019-12-21 02:30:24.505 Status: (Zigate ) Available Firmware Type: 16897 version: 12217572 - filename: 159698-TRADFRI-driver-lp-1.2.217.ota.ota.signed size: 173246 Bytes
2019-12-21 02:30:24.512 Status: (Zigate ) Available Firmware Type: 4353 version: 20022623 - filename: 10005777-4.1-TRADFRI-control-outlet-2.0.022.ota.ota.signed size: 204222 Bytes
2019-12-21 02:30:24.518 Status: (Zigate ) Available Firmware Type: 16898 version: 12217572 - filename: 159697-TRADFRI-driver-hp-1.2.217.ota.ota.signed size: 173246 Bytes
2019-12-21 02:30:24.523 Status: (Zigate ) Available Firmware Type: 4546 version: 12248572 - filename: 159701-TRADFRI-wireless-dimmer-1.2.248.ota.ota.signed size: 172926 Bytes
2019-12-21 02:30:24.530 Status: (Zigate ) Available Firmware Type: 16900 version: 20022623 - filename: 10038562-TRADFRI-sy5882-bulb-ws-2.0.022.ota.ota.signed size: 209790 Bytes
2019-12-21 02:30:24.538 Status: (Zigate ) Available Firmware Type: 16899 version: 20022623 - filename: 191100-4.1-TRADFRI-sy5882-driver-ws-2.0.022.ota.ota.signed size: 208830 Bytes
2019-12-21 02:30:24.543 Status: (Zigate ) Available Firmware Type: 2 version: 165801BC - filename: 190579-ncp572b444.ebl.ota.ota.signed size: 166270 Bytes
2019-12-21 02:30:24.548 Status: (Zigate ) Available Firmware Type: 8706 version: 12217572 - filename: 159695-TRADFRI-bulb-ws-1000lm-1.2.217.ota.ota.signed size: 173246 Bytes
2019-12-21 02:30:24.554 Status: (Zigate ) Available Firmware Type: 10241 version: 13009572 - filename: 10035515-TRADFRI-bulb-cws-1.3.009.ota.ota.signed size: 178366 Bytes
2019-12-21 02:30:24.561 Status: (Zigate ) Available Firmware Type: 16901 version: 21022631 - filename: 10040611-3.2-TRADFRI-sy5882-unified-2.1.022.ota.ota.signed size: 208254 Bytes
2019-12-21 02:30:24.562 Error: (Zigate ) ota_decode_new_image - invalid file size read .empty - 0
2019-12-21 02:30:25.022 Status: (Zigate ) TxPower Attenuation : 0 dBm
2019-12-21 02:31:07.794 EventSystem: Event triggered: Lumiere TV_1
2019-12-21 02:31:07.824 Activating Scene/Group: [AUTO LUMIERE TV]
2019-12-21 02:31:07.827 Activating Scene/Group Device: Lumiere TV (On)
2019-12-21 02:31:07.835 (SonOff) Light/Switch (Lumiere TV)
2019-12-21 02:31:11.177 GPIO: Optional connected Master Domoticz now updates its status
2019-12-21 02:32:00.299 EventSystem: Event triggered: Lumiere TV_1
2019-12-21 02:32:00.316 Activating Scene/Group: [AUTO LUMIERE TV]
2019-12-21 02:32:00.319 Activating Scene/Group Device: Lumiere TV (On)
2019-12-21 02:32:00.326 (SonOff) Light/Switch (Lumiere TV)
2019-12-21 02:33:00.309 EventSystem: Event triggered: Lumiere TV_1
2019-12-21 02:33:00.341 Activating Scene/Group: [AUTO LUMIERE TV]
2019-12-21 02:33:00.343 Activating Scene/Group Device: Lumiere TV (On)
2019-12-21 02:33:00.350 (SonOff) Light/Switch (Lumiere TV)
Merci de votre aide
ERREUR IMAGE OTA(Error: (Zigate ) ota_decode_new_image - invalid file size read .empty - 0)
Domoticz en version BETA
Raspbery PI4
Pizigate
5 sonde Xiaomi Aquara
2 on/off en Zigbee
1 Repeteur Tradi kea
1 relais lumiere par SonoFf avec firmware modifié
TV*LG
3 ECHO ALEXA
Raspbery PI4
Pizigate
2 on/off en Zigbee
TV*LG
3 ECHO ALEXA
Re: ERREUR IMAGE OTA(Error: (Zigate ) ota_decode_new_image - invalid file size read .empty - 0)
Pas bien grave. Corrigé sur la branche betacedpic a écrit : 21 déc. 2019, 02:34 Bonjour,
Merci de votre aide
Merci,
Ma BDD domoticz atteind les 1,5Go en 2 ,3 jours et plantes une idée tout cela peu venir ?
Raspbery PI4
Pizigate
2 on/off en Zigbee
TV*LG
3 ECHO ALEXA
Raspbery PI4
Pizigate
2 on/off en Zigbee
TV*LG
3 ECHO ALEXA
Voir peut-être sur un groupe plus généraliste, car je ne vois pas ce qui pourrait générer cela coté plugin.cedpic a écrit : 23 déc. 2019, 20:49 Merci,
J'ai vu que tu avais 5 Devices, c'est quoi ? que des Lampes Ikea ?
Tu peux aussi désactiver OTA (les upgrade de Firmware).
Oui la question était plus généraliste
J ai 5 sonde aquara, 2 on/off zigbee répéteur Ikea voilà pour la parti zigbee
Après j ai un sonoff flasher avec Tashoma
Bonne fête
Bonne fête
Raspbery PI4
Pizigate
2 on/off en Zigbee
TV*LG
3 ECHO ALEXA
Raspbery PI4
Pizigate
2 on/off en Zigbee
TV*LG
3 ECHO ALEXA
