nouvel utilisateur de la ZiGate USB, j'essaie de l'intégrer dans mon installation Domoticz qui tourne sur un serveur Debian 9.
et là problème, je ne m'en sors pas !!
Domoticz
Version: 4.11724
Build Hash: 867979abf
Compile Date: 2020-02-23 11:10:00
dzVents Version: 3.0.0
Python Version: 3.5.3 (default, Sep 27 2018, 17:25:39) [GCC 6.3.0 20170516]je sèche, toute suggestion est la bienvenue... merci.
NB : j'ai testé la ZiGate sous Windows 10 avec les outils indiqués et pas de souci. J'ai même pu mettre à jour vers le dernier firmware (3.1c).
2020-02-24 12:03:50.239 Status: (ZiGate) Started.
2020-02-24 12:03:50.310 Status: (ZiGate) Entering work loop.
2020-02-24 12:03:50.311 Status: (ZiGate) Initialized version 4.8, author 'zaraki673 pipiche38'
2020-02-24 12:03:50.311 Status: (ZiGate) Zigate plugin beta-4.8.002 started
2020-02-24 12:03:50.311 Status: (ZiGate) Debug: 2
2020-02-24 12:03:50.311 (ZiGate) Debug Mode: 2, We do recommend to leave Verbors to None
2020-02-24 12:03:50.311 (ZiGate) 'HardwareID':'9'
2020-02-24 12:03:50.311 (ZiGate) 'DomoticzHash':'867979abf'
2020-02-24 12:03:50.311 (ZiGate) 'Language':'fr'
2020-02-24 12:03:50.311 (ZiGate) 'Mode3':'False'
2020-02-24 12:03:50.311 (ZiGate) 'UserDataFolder':'/home/serviceuser/domoticz/'
2020-02-24 12:03:50.311 (ZiGate) 'Mode1':'USB'
2020-02-24 12:03:50.311 (ZiGate) 'StartupFolder':'/home/serviceuser/domoticz/'
2020-02-24 12:03:50.311 (ZiGate) 'Author':'zaraki673 pipiche38'
2020-02-24 12:03:50.311 (ZiGate) 'Mode6':'2'
2020-02-24 12:03:50.311 (ZiGate) 'DomoticzBuildTime':'2020-02-23 11:10:00'
2020-02-24 12:03:50.311 (ZiGate) 'Name':'ZiGate'
2020-02-24 12:03:50.311 (ZiGate) 'HomeFolder':'/home/serviceuser/domoticz/plugins/Domoticz-Zigate/'
2020-02-24 12:03:50.311 (ZiGate) 'DomoticzVersion':'4.11724'
2020-02-24 12:03:50.311 (ZiGate) 'Address':'0.0.0.0'
2020-02-24 12:03:50.311 (ZiGate) 'Version':'4.8'
2020-02-24 12:03:50.311 (ZiGate) 'SerialPort':'/dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0'
2020-02-24 12:03:50.311 (ZiGate) 'Port':'9999'
2020-02-24 12:03:50.311 (ZiGate) 'Key':'Zigate'
2020-02-24 12:03:50.311 (ZiGate) 'Mode4':'9440'
2020-02-24 12:03:50.311 (ZiGate) 'Database':'/home/serviceuser/domoticz/domoticz.db'
2020-02-24 12:03:50.311 (ZiGate) Device count: 0
2020-02-24 12:03:50.311 Status: (ZiGate) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2020-02-24 12:03:50.311 Status: (ZiGate) Switching Heartbeat to 5 s interval
2020-02-24 12:03:50.311 Status: (ZiGate) DomoticzVersion: 4.11724
2020-02-24 12:03:50.311 Status: (ZiGate) DomoticzHash: 867979abf
2020-02-24 12:03:50.311 Status: (ZiGate) DomoticzBuildTime: 2020-02-23 11:10:00
2020-02-24 12:03:50.311 Status: (ZiGate) load PluginConf
2020-02-24 12:03:50.312 Status: (ZiGate) pluginWWW set to /home/serviceuser/domoticz/plugins/Domoticz-Zigate/www/
2020-02-24 12:03:50.312 Status: (ZiGate) pluginConfig set to /home/serviceuser/domoticz/plugins/Domoticz-Zigate/Conf/
2020-02-24 12:03:50.312 Status: (ZiGate) homedirectory set to /home/serviceuser/domoticz/plugins/Domoticz-Zigate/
2020-02-24 12:03:50.312 Status: (ZiGate) pluginReports set to /home/serviceuser/domoticz/plugins/Domoticz-Zigate/Reports/
2020-02-24 12:03:50.312 Status: (ZiGate) pluginOTAFirmware set to /home/serviceuser/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2020-02-24 12:03:50.312 Status: (ZiGate) pluginHome set to /home/serviceuser/domoticz/plugins/Domoticz-Zigate/
2020-02-24 12:03:50.312 Status: (ZiGate) pluginData set to /home/serviceuser/domoticz/plugins/Domoticz-Zigate/Data/
2020-02-24 12:03:50.312 Status: (ZiGate) filename set to /home/serviceuser/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-09.json
2020-02-24 12:03:50.312 Status: (ZiGate) Opening DomoticzDB in raw
2020-02-24 12:03:50.314 Status: (ZiGate) Plugin Database: DeviceList-9.txt
2020-02-24 12:03:50.315 Status: (ZiGate) DeviceConf loaded
2020-02-24 12:03:50.316 Status: (ZiGate) --> Config for TUYA/TS0011
2020-02-24 12:03:50.316 Status: (ZiGate) --> Config for TUYA/TS0002
2020-02-24 12:03:50.316 Status: (ZiGate) --> Config for TUYA/TS0012
2020-02-24 12:03:50.316 Status: (ZiGate) --> Config for TUYA/TS0013
2020-02-24 12:03:50.316 Status: (ZiGate) --> Config for TUYA/TS0001
2020-02-24 12:03:50.316 Status: (ZiGate) --> Config for OSRAM/LIGHTIFY Outdoor Flex RGBW
2020-02-24 12:03:50.316 Status: (ZiGate) --> Config for OSRAM/Plug Z3
2020-02-24 12:03:50.316 Status: (ZiGate) --> Config for OSRAM/Lightify Switch Mini
2020-02-24 12:03:50.316 Status: (ZiGate) --> Config for OSRAM/CLA60 TW OSRAM
2020-02-24 12:03:50.316 Status: (ZiGate) --> Config for OSRAM/Plug 01
2020-02-24 12:03:50.317 Status: (ZiGate) --> Config for GLEDOPTO/GL-C-008
2020-02-24 12:03:50.317 Status: (ZiGate) --> Config for GLEDOPTO/GL-D-003Z
2020-02-24 12:03:50.317 Status: (ZiGate) --> Config for GLEDOPTO/GL-C-009
2020-02-24 12:03:50.317 Status: (ZiGate) --> Config for GLEDOPTO/GLEDOPTO
2020-02-24 12:03:50.317 Status: (ZiGate) --> Config for Eurotronics/SPZB0001
2020-02-24 12:03:50.317 Status: (ZiGate) --> Config for IKEA_TRADFRI/TRADFRI bulb E27 WS clear 950lm
2020-02-24 12:03:50.317 Status: (ZiGate) --> Config for IKEA_TRADFRI/TRADFRI bulb E26 WS opal 980lm
2020-02-24 12:03:50.317 Status: (ZiGate) --> Config for IKEA_TRADFRI/TRADFRI bulb E27 WS opal 1000lm
2020-02-24 12:03:50.317 Status: (ZiGate) --> Config for IKEA_TRADFRI/TRADFRI bulb GU10 WS 400lm
2020-02-24 12:03:50.317 Status: (ZiGate) --> Config for IKEA_TRADFRI/TRADFRI bulb E27 WS opal 950lm
2020-02-24 12:03:50.317 Status: (ZiGate) --> Config for IKEA_TRADFRI/TRADFRI bulb E27 WS opal 980lm
2020-02-24 12:03:50.318 Status: (ZiGate) --> Config for IKEA_TRADFRI/TRADFRI wireless dimmer
2020-02-24 12:03:50.318 Status: (ZiGate) --> Config for IKEA_TRADFRI/TRADFRI Signal Repeater
2020-02-24 12:03:50.318 Status: (ZiGate) --> Config for IKEA_TRADFRI/FLOALT panel WS 60x60
2020-02-24 12:03:50.318 Status: (ZiGate) --> Config for IKEA_TRADFRI/TRADFRI bulb E14 WS opal 400lm
2020-02-24 12:03:50.318 Status: (ZiGate) --> Config for IKEA_TRADFRI/TRADFRI control outlet
2020-02-24 12:03:50.318 Status: (ZiGate) --> Config for IKEA_TRADFRI/TRADFRI remote control
2020-02-24 12:03:50.318 Status: (ZiGate) --> Config for IKEA_TRADFRI/TRADFRI bulb E26 WS clear 950lm
2020-02-24 12:03:50.318 Status: (ZiGate) --> Config for IKEA_TRADFRI/TRADFRI bulb E12 WS opal 400lm
2020-02-24 12:03:50.318 Status: (ZiGate) --> Config for INNR/RB 285 C
2020-02-24 12:03:50.318 Status: (ZiGate) --> Config for Konke/3AFE28010402000D
2020-02-24 12:03:50.318 Status: (ZiGate) --> Config for Konke/3AFE14010402000D
2020-02-24 12:03:50.318 Status: (ZiGate) --> Config for Konke/3AFE170100510001
2020-02-24 12:03:50.319 Status: (ZiGate) --> Config for Konke/3AFE140103020000
2020-02-24 12:03:50.319 Status: (ZiGate) --> Config for CLEODE/ZHUM
2020-02-24 12:03:50.319 Status: (ZiGate) --> Config for CLEODE/ZPLUG
2020-02-24 12:03:50.319 Status: (ZiGate) --> Config for CLEODE/ZMOVE
2020-02-24 12:03:50.319 Status: (ZiGate) --> Config for Legrand/Dimmer switch w/o neutral
2020-02-24 12:03:50.319 Status: (ZiGate) --> Config for Legrand/Remote switch
2020-02-24 12:03:50.319 Status: (ZiGate) --> Config for Legrand/DIN power consumption module
2020-02-24 12:03:50.319 Status: (ZiGate) --> Config for Legrand/Double gangs remote switch
2020-02-24 12:03:50.319 Status: (ZiGate) --> Config for Legrand/Shutter switch with neutral
2020-02-24 12:03:50.319 Status: (ZiGate) --> Config for Legrand/Micromodule switch
2020-02-24 12:03:50.319 Status: (ZiGate) --> Config for Legrand/Connected outlet
2020-02-24 12:03:50.319 Status: (ZiGate) --> Config for Legrand/Mobile outlet
2020-02-24 12:03:50.320 Status: (ZiGate) --> Config for Legrand/Shutters central remote switch
2020-02-24 12:03:50.320 Status: (ZiGate) --> Config for Legrand/Cable outlet
2020-02-24 12:03:50.320 Status: (ZiGate) --> Config for Philips/LST002
2020-02-24 12:03:50.321 Status: (ZiGate) --> Config for Philips/SML001
2020-02-24 12:03:50.321 Status: (ZiGate) --> Config for Philips/SML002
2020-02-24 12:03:50.321 Status: (ZiGate) --> Config for Philips/RWL021
2020-02-24 12:03:50.321 Status: (ZiGate) --> Config for Schneider/EH-ZB-VACT
2020-02-24 12:03:50.321 Status: (ZiGate) --> Config for Schneider/EH-ZB-RTS
2020-02-24 12:03:50.321 Status: (ZiGate) --> Config for Schneider/EH-ZB-BMS
2020-02-24 12:03:50.321 Status: (ZiGate) --> Config for Schneider/EH-ZB-LMACT
2020-02-24 12:03:50.321 Status: (ZiGate) --> Config for Schneider/EH-ZB-SPD-V2
2020-02-24 12:03:50.321 Status: (ZiGate) --> Config for Schneider/EH-ZB-HACT
2020-02-24 12:03:50.322 Status: (ZiGate) --> Config for Schneider/EH-ZB-SPD
2020-02-24 12:03:50.322 Status: (ZiGate) --> Config for Others/FB56-ZCW08KU1.1
2020-02-24 12:03:50.322 Status: (ZiGate) --> Config for LIVOLO/TI0001
2020-02-24 12:03:50.322 Status: (ZiGate) --> Config for SALUS/SPE600
2020-02-24 12:03:50.322 Status: (ZiGate) --> Config for Heiman/SmokeSensor-N-3.0
2020-02-24 12:03:50.322 Status: (ZiGate) --> Config for Heiman/GAS_V15
2020-02-24 12:03:50.322 Status: (ZiGate) --> Config for Heiman/SMOK_V16
2020-02-24 12:03:50.322 Status: (ZiGate) --> Config for LUMI/lumi.remote.b1acn01
2020-02-24 12:03:50.322 Status: (ZiGate) --> Config for LUMI/lumi.sensor_switch.aq2
2020-02-24 12:03:50.323 Status: (ZiGate) --> Config for LUMI/lumi.sensor_switch
2020-02-24 12:03:50.323 Status: (ZiGate) --> Config for LUMI/lumi.sensor_motion
2020-02-24 12:03:50.323 Status: (ZiGate) --> Config for LUMI/lumi.sensor_magnet
2020-02-24 12:03:50.323 Status: (ZiGate) --> Config for LUMI/lumi.sensor_smoke
2020-02-24 12:03:50.323 Status: (ZiGate) --> Config for LUMI/lumi.remote.b286acn01
2020-02-24 12:03:50.323 Status: (ZiGate) --> Config for LUMI/lumi.sensor_ht
2020-02-24 12:03:50.323 Status: (ZiGate) --> Config for LUMI/lumi.sensor_magnet.aq2
2020-02-24 12:03:50.323 Status: (ZiGate) --> Config for LUMI/lumi.remote.b686opcn01
2020-02-24 12:03:50.323 Status: (ZiGate) --> Config for LUMI/lumi.sensor_cube
2020-02-24 12:03:50.323 Status: (ZiGate) --> Config for LUMI/lumi.ctrl_ln2.aq1
2020-02-24 12:03:50.323 Status: (ZiGate) --> Config for LUMI/lumi.weather
2020-02-24 12:03:50.323 Status: (ZiGate) --> Config for LUMI/lumi.sensor_86sw2
2020-02-24 12:03:50.323 Status: (ZiGate) --> Config for LUMI/lumi.sen_ill.mgl01
2020-02-24 12:03:50.324 Status: (ZiGate) --> Config for LUMI/lumi.light.aqcn02
2020-02-24 12:03:50.324 Status: (ZiGate) --> Config for LUMI/lumi.vibration.aq1
2020-02-24 12:03:50.324 Status: (ZiGate) --> Config for LUMI/lumi.remote.b186acn01
2020-02-24 12:03:50.324 Status: (ZiGate) --> Config for LUMI/lumi.sensor_switch.aq3
2020-02-24 12:03:50.324 Status: (ZiGate) --> Config for LUMI/lumi.ctrl_neutral2
2020-02-24 12:03:50.324 Status: (ZiGate) --> Config for LUMI/lumi.sensor_wleak.aq1
2020-02-24 12:03:50.324 Status: (ZiGate) --> Config for LUMI/lumi.sensor_cube.aqgl01
2020-02-24 12:03:50.324 Status: (ZiGate) --> Config for LUMI/lumi.sensor_86sw1
2020-02-24 12:03:50.324 Status: (ZiGate) --> Config for LUMI/lumi.plug
2020-02-24 12:03:50.324 Status: (ZiGate) --> Config for LUMI/lumi.relay.c2acn01
2020-02-24 12:03:50.324 Status: (ZiGate) --> Config for LUMI/lumi.ctrl_neutral1
2020-02-24 12:03:50.324 Status: (ZiGate) --> Config for LUMI/lumi.sensor_motion.aq2
2020-02-24 12:03:50.324 Status: (ZiGate) load ListOfDevice
2020-02-24 12:03:50.324 Status: (ZiGate) Transport mode: USB
2020-02-24 12:03:50.325 Status: (ZiGate) Connection Name: Zigate, Transport: Serial, Address: /dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0
2020-02-24 12:03:50.325 Status: (ZiGate) Connection open: Name: 'ZiGate', Transport: 'Serial', Protocol: 'None', Address: '/dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0', Port: '', Baud: 115200, Connected: False, Parent: 'None'
2020-02-24 12:03:50.341 Status: (ZiGate) Trigger a Topology Scan
2020-02-24 12:03:50.341 Status: (ZiGate) Trigger a Energy Level Scan
2020-02-24 12:03:50.442 Status: (ZiGate) Major Version Num: 0003
2020-02-24 12:03:50.442 Status: (ZiGate) Installer Version Number: 031c
2020-02-24 12:03:50.745 Error: (ZiGate) Zigate not correctly initialized
2020-02-24 12:03:50.845 Status: (ZiGate) Number of devices recently active in Zigate = 0
2020-02-24 12:03:52.066 (RFXCom) Temp (Congélateur)
2020-02-24 12:03:55.198 (RFXCom) Temp + Humidity (sonde Cuisine)
2020-02-24 12:03:58.699 (RFXCom) Temp + Humidity (sonde Salon)
2020-02-24 12:04:00.133 Status: LUA: Aube programmée à : 06:50
2020-02-24 12:04:00.363 (ZiGate) Switch Blue Led On
2020-02-24 12:04:00.363 Status: (ZiGate) Zigate set to Certification : CE
2020-02-24 12:04:00.363 Status: (ZiGate) Start Web Server connection
2020-02-24 12:04:00.368 Status: (ZiGate) Web backend for Web User Interface started on port: 9440
2020-02-24 12:04:00.369 Status: (ZiGate) Plugin with Zigate firmware 031c correctly initialized
2020-02-24 12:04:00.375 Error: Domoticz(pid:20626, tid:20629('PluginMgr')) received fatal signal 11 (Segmentation fault)
2020-02-24 12:04:00.375 Error: siginfo address=0x5092, address=0x7f3a6272dfbf
2020-02-24 12:04:00.382 Error: Failed to start gdb, will use backtrace() for printing stack frame
2020-02-24 12:04:00.388 Error: #0 /home/serviceuser/domoticz/domoticz() [0x737683]
2020-02-24 12:04:00.388 Error: #1 /home/serviceuser/domoticz/domoticz : signal_handler(int, siginfo_t*, void*) + 0x295 [0x7381a5]
2020-02-24 12:04:00.388 Error: #2 /lib/x86_64-linux-gnu/libpthread.so.0 : + 0x110e0 [0x7f3a6272e0e0]
2020-02-24 12:04:00.388 Error: #3 /lib/x86_64-linux-gnu/libpthread.so.0 : raise + 0xcf [0x7f3a6272dfbf]
2020-02-24 12:04:00.388 Error: #4 /lib/x86_64-linux-gnu/libpthread.so.0 : + 0x110e0 [0x7f3a6272e0e0]
2020-02-24 12:04:00.388 Error: #5 /lib/x86_64-linux-gnu/libc.so.6 : + 0x129596 [0x7f3a61b80596]
2020-02-24 12:04:00.388 Error: #6 /home/serviceuser/domoticz/domoticz() [0xc586e9]
2020-02-24 12:04:00.388 Error: #7 /home/serviceuser/domoticz/domoticz : lh_insert + 0x4c [0xc5899c]
2020-02-24 12:04:00.388 Error: #8 /home/serviceuser/domoticz/domoticz : OBJ_NAME_add + 0x63 [0xc21833]
2020-02-24 12:04:00.388 Error: #9 /home/serviceuser/domoticz/domoticz : EVP_add_digest + 0x56 [0xc60236]
2020-02-24 12:04:00.388 Error: #10 /usr/lib/x86_64-linux-gnu/libcrypto.so.1.1 : + 0x1554fb [0x7f3a1acb94fb]
2020-02-24 12:04:00.388 Error: #11 /usr/lib/x86_64-linux-gnu/libcrypto.so.1.1 : + 0x16ca79 [0x7f3a1acd0a79]
2020-02-24 12:04:00.388 Error: #12 /lib/x86_64-linux-gnu/libpthread.so.0 : + 0xe759 [0x7f3a6272b759]
2020-02-24 12:04:00.388 Error: #13 /usr/lib/x86_64-linux-gnu/libcrypto.so.1.1 : CRYPTO_THREAD_run_once + 0x9 [0x7f3a1ad27759]
2020-02-24 12:04:00.388 Error: #14 /usr/lib/x86_64-linux-gnu/libcrypto.so.1.1 : OPENSSL_init_crypto + 0x273 [0x7f3a1acd0fb3]
2020-02-24 12:04:00.388 Error: #15 /usr/lib/python3.5/lib-dynload/_hashlib.cpython-35m-x86_64-linux-gnu.so : PyInit__hashlib + 0x21 [0x7f3a342abb11]
2020-02-24 12:04:00.388 Error: #16 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : _PyImport_LoadDynamicModuleWithSpec + 0x180 [0x7f3a5dbcf710]
2020-02-24 12:04:00.388 Error: #17 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : + 0x209fe7 [0x7f3a5dbd2fe7]
2020-02-24 12:04:00.388 Error: #18 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyCFunction_Call + 0xc9 [0x7f3a5da3a259]
2020-02-24 12:04:00.388 Error: #19 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x78f2 [0x7f3a5db6aff2]
2020-02-24 12:04:00.388 Error: #20 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : + 0x264074 [0x7f3a5dc2d074]
2020-02-24 12:04:00.388 Error: #21 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x63df [0x7f3a5db69adf]
2020-02-24 12:04:00.388 Error: #22 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x7fad [0x7f3a5db6b6ad]
2020-02-24 12:04:00.388 Error: #23 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x7fad [0x7f3a5db6b6ad]
2020-02-24 12:04:00.388 Error: #24 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x7fad [0x7f3a5db6b6ad]
2020-02-24 12:04:00.388 Error: #25 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x7fad [0x7f3a5db6b6ad]
2020-02-24 12:04:00.388 Error: #26 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : + 0x264074 [0x7f3a5dc2d074]
2020-02-24 12:04:00.388 Error: #27 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalCodeEx + 0x23 [0x7f3a5dc2d153]
2020-02-24 12:04:00.388 Error: #28 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : + 0xf7558 [0x7f3a5dac0558]
2020-02-24 12:04:00.388 Error: #29 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyObject_Call + 0x47 [0x7f3a5db9ca37]
2020-02-24 12:04:00.388 Error: #30 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : _PyObject_CallMethodIdObjArgs + 0x22b [0x7f3a5db9ee1b]
2020-02-24 12:04:00.388 Error: #31 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyImport_ImportModuleLevelObject + 0x81a [0x7f3a5dbd0ffa]
2020-02-24 12:04:00.388 Error: #32 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : + 0x1a6248 [0x7f3a5db6f248]
2020-02-24 12:04:00.388 Error: #33 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyCFunction_Call + 0xe9 [0x7f3a5da3a279]
2020-02-24 12:04:00.388 Error: #34 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyObject_Call + 0x47 [0x7f3a5db9ca37]
2020-02-24 12:04:00.388 Error: #35 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_CallObjectWithKeywords + 0x47 [0x7f3a5dc2bb77]
2020-02-24 12:04:00.388 Error: #36 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x40cb [0x7f3a5db677cb]
2020-02-24 12:04:00.388 Error: #37 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : + 0x264074 [0x7f3a5dc2d074]
2020-02-24 12:04:00.388 Error: #38 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalCodeEx + 0x23 [0x7f3a5dc2d153]
2020-02-24 12:04:00.388 Error: #39 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalCode + 0x1b [0x7f3a5db6345b]
2020-02-24 12:04:00.388 Error: #40 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : + 0x1a72cd [0x7f3a5db702cd]
2020-02-24 12:04:00.388 Error: #41 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyCFunction_Call + 0xc9 [0x7f3a5da3a259]
2020-02-24 12:04:00.388 Error: #42 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x78f2 [0x7f3a5db6aff2]
2020-02-24 12:04:00.388 Error: #43 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : + 0x264074 [0x7f3a5dc2d074]
2020-02-24 12:04:00.388 Error: #44 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x63df [0x7f3a5db69adf]
2020-02-24 12:04:00.388 Error: #45 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x7fad [0x7f3a5db6b6ad]
2020-02-24 12:04:00.388 Error: #46 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x7fad [0x7f3a5db6b6ad]
2020-02-24 12:04:00.388 Error: #47 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x7fad [0x7f3a5db6b6ad]
2020-02-24 12:04:00.388 Error: #48 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : + 0x264074 [0x7f3a5dc2d074]
2020-02-24 12:04:00.388 Error: #49 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalCodeEx + 0x23 [0x7f3a5dc2d153]
2020-02-24 12:04:00.388 Error: #50 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : + 0xf7558 [0x7f3a5dac0558]
2020-02-24 12:04:00.388 Error: #51 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyObject_Call + 0x47 [0x7f3a5db9ca37]
2020-02-24 12:04:00.388 Error: #52 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : _PyObject_CallMethodIdObjArgs + 0x22b [0x7f3a5db9ee1b]
2020-02-24 12:04:00.388 Error: #53 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyImport_ImportModuleLevelObject + 0x81a [0x7f3a5dbd0ffa]
2020-02-24 12:04:00.388 Error: #54 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : + 0x1a6248 [0x7f3a5db6f248]
2020-02-24 12:04:00.388 Error: #55 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyCFunction_Call + 0xe9 [0x7f3a5da3a279]
2020-02-24 12:04:00.388 Error: #56 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyObject_Call + 0x47 [0x7f3a5db9ca37]
2020-02-24 12:04:00.388 Error: #57 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_CallObjectWithKeywords + 0x47 [0x7f3a5dc2bb77]
2020-02-24 12:04:00.388 Error: #58 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x40cb [0x7f3a5db677cb]
2020-02-24 12:04:00.388 Error: #59 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : + 0x264074 [0x7f3a5dc2d074]
2020-02-24 12:04:00.388 Error: #60 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalCodeEx + 0x23 [0x7f3a5dc2d153]
2020-02-24 12:04:00.388 Error: #61 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalCode + 0x1b [0x7f3a5db6345b]
2020-02-24 12:04:00.388 Error: #62 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : + 0x1a72cd [0x7f3a5db702cd]
2020-02-24 12:04:00.388 Error: #63 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyCFunction_Call + 0xc9 [0x7f3a5da3a259]
2020-02-24 12:04:00.388 Error: #64 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x78f2 [0x7f3a5db6aff2]
2020-02-24 12:04:00.388 Error: #65 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : + 0x264074 [0x7f3a5dc2d074]
2020-02-24 12:04:00.388 Error: #66 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x63df [0x7f3a5db69adf]
2020-02-24 12:04:00.388 Error: #67 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x7fad [0x7f3a5db6b6ad]
2020-02-24 12:04:00.388 Error: #68 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x7fad [0x7f3a5db6b6ad]
2020-02-24 12:04:00.388 Error: #69 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x7fad [0x7f3a5db6b6ad]
2020-02-24 12:04:00.388 Error: #70 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : + 0x264074 [0x7f3a5dc2d074]
2020-02-24 12:04:00.388 Error: #71 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalCodeEx + 0x23 [0x7f3a5dc2d153]
2020-02-24 12:04:00.388 Error: #72 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : + 0xf7558 [0x7f3a5dac0558]
2020-02-24 12:04:00.388 Error: #73 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyObject_Call + 0x47 [0x7f3a5db9ca37]
2020-02-24 12:04:00.388 Error: #74 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : _PyObject_CallMethodIdObjArgs + 0x22b [0x7f3a5db9ee1b]
2020-02-24 12:04:00.388 Error: #75 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyImport_ImportModuleLevelObject + 0x81a [0x7f3a5dbd0ffa]
2020-02-24 12:04:00.388 Error: #76 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : + 0x1a6248 [0x7f3a5db6f248]
2020-02-24 12:04:00.388 Error: #77 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyCFunction_Call + 0xe9 [0x7f3a5da3a279]
2020-02-24 12:04:00.388 Error: #78 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyObject_Call + 0x47 [0x7f3a5db9ca37]
2020-02-24 12:04:00.388 Error: #79 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_CallObjectWithKeywords + 0x47 [0x7f3a5dc2bb77]
2020-02-24 12:04:00.388 Error: #80 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x40cb [0x7f3a5db677cb]
2020-02-24 12:04:00.388 Error: #81 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : + 0x264074 [0x7f3a5dc2d074]
2020-02-24 12:04:00.388 Error: #82 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalCodeEx + 0x23 [0x7f3a5dc2d153]
2020-02-24 12:04:00.388 Error: #83 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalCode + 0x1b [0x7f3a5db6345b]
2020-02-24 12:04:00.388 Error: #84 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : + 0x1a72cd [0x7f3a5db702cd]
2020-02-24 12:04:00.388 Error: #85 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyCFunction_Call + 0xc9 [0x7f3a5da3a259]
2020-02-24 12:04:00.388 Error: #86 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x78f2 [0x7f3a5db6aff2]
2020-02-24 12:04:00.388 Error: #87 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : + 0x264074 [0x7f3a5dc2d074]
2020-02-24 12:04:00.388 Error: #88 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x63df [0x7f3a5db69adf]
2020-02-24 12:04:00.388 Error: #89 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x7fad [0x7f3a5db6b6ad]
2020-02-24 12:04:00.388 Error: #90 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x7fad [0x7f3a5db6b6ad]
2020-02-24 12:04:00.388 Error: #91 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x7fad [0x7f3a5db6b6ad]
2020-02-24 12:04:00.388 Error: #92 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : + 0x264074 [0x7f3a5dc2d074]
2020-02-24 12:04:00.388 Error: #93 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalCodeEx + 0x23 [0x7f3a5dc2d153]
2020-02-24 12:04:00.388 Error: #94 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : + 0xf7558 [0x7f3a5dac0558]
2020-02-24 12:04:00.388 Error: #95 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyObject_Call + 0x47 [0x7f3a5db9ca37]
2020-02-24 12:04:00.388 Error: #96 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : _PyObject_CallMethodIdObjArgs + 0x22b [0x7f3a5db9ee1b]
2020-02-24 12:04:00.388 Error: #97 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyImport_ImportModuleLevelObject + 0x81a [0x7f3a5dbd0ffa]
2020-02-24 12:04:00.388 Error: #98 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : + 0x1a6248 [0x7f3a5db6f248]
2020-02-24 12:04:00.388 Error: #99 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyCFunction_Call + 0xe9 [0x7f3a5da3a279]
2020-02-24 12:04:00.388 Error: #100 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyObject_Call + 0x47 [0x7f3a5db9ca37]
2020-02-24 12:04:00.388 Error: #101 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_CallObjectWithKeywords + 0x47 [0x7f3a5dc2bb77]
2020-02-24 12:04:00.388 Error: #102 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x40cb [0x7f3a5db677cb]
2020-02-24 12:04:00.388 Error: #103 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x7fad [0x7f3a5db6b6ad]
2020-02-24 12:04:00.388 Error: #104 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalFrameEx + 0x7fad [0x7f3a5db6b6ad]
2020-02-24 12:04:00.388 Error: #105 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : + 0x264074 [0x7f3a5dc2d074]
2020-02-24 12:04:00.388 Error: #106 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_EvalCodeEx + 0x23 [0x7f3a5dc2d153]
2020-02-24 12:04:00.388 Error: #107 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : + 0xf7558 [0x7f3a5dac0558]
2020-02-24 12:04:00.388 Error: #108 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyObject_Call + 0x47 [0x7f3a5db9ca37]
2020-02-24 12:04:00.389 Error: #109 /usr/lib/x86_64-linux-gnu/libpython3.5m.so : PyEval_CallObjectWithKeywords + 0x47 [0x7f3a5dc2bb77]
2020-02-24 12:04:00.389 Error: #110 /home/serviceuser/domoticz/domoticz : Plugins::CPlugin::Callback(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*) + 0xa3 [0xade313]
2020-02-24 12:04:00.389 Error: #111 /home/serviceuser/domoticz/domoticz : Plugins::CCallbackBase::Callback(_object*) + 0x6d [0x6b3ced]
2020-02-24 12:04:00.389 Error: #112 /home/serviceuser/domoticz/domoticz : Plugins::CPluginMessageBase::Process() + 0x33 [0x6b3f23]
2020-02-24 12:04:00.389 Error: #113 /home/serviceuser/domoticz/domoticz : Plugins::CPluginSystem::Do_Work() + 0xb80 [0xaeb680]
2020-02-24 12:04:00.389 Error: #114 /home/serviceuser/domoticz/domoticz() [0xf48c8f]
2020-02-24 12:04:00.389 Error: #115 /lib/x86_64-linux-gnu/libpthread.so.0 : + 0x74a4 [0x7f3a627244a4]
2020-02-24 12:04:00.389 Error: #116 /lib/x86_64-linux-gnu/libc.so.6 : clone + 0x3f [0x7f3a61b3fd0f]
