[Résolu] Problème installation du plugin
Bibi49
Message par Bibi49 »
Edité le 11/03/2023
Probleme resolut avec l'utilisation de Python 3.9.2 de Bulleyes, et l'installation de python3-dev et python3-pip
J'ai une erreur lors de l'installation du plugin.
Dans la section 1 Installation manuelle sous linux
Etape 1B
Installer les paquets Python nécessaires avec la commande :
sudo pip3 install -r requirements.txt
pi@raspberrypi:~/domoticz/plugins $ cd Domoticz-Zigbee/
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ sudo pip3 install -r requirements.txt
  File "/usr/bin/pip3", line 33, in <module>
    sys.exit(load_entry_point('pip==20.3.4', 'console_scripts', 'pip3')())
  File "/usr/bin/pip3", line 25, in importlib_load_entry_point
    return next(matches).load()
  File "/usr/lib/python3.8/importlib/metadata.py", line 77, in load
    module = import_module(match.group('module'))
  File "/usr/lib/python3.8/importlib/__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
  File "<frozen importlib._bootstrap>", line 991, in _find_and_load
  File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 783, in exec_module
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "/usr/lib/python3/dist-packages/pip/_internal/cli/main.py", line 10, in <module>
    from pip._internal.cli.autocompletion import autocomplete
  File "/usr/lib/python3/dist-packages/pip/_internal/cli/autocompletion.py", line 9, in <module>
    from pip._internal.cli.main_parser import create_main_parser
  File "/usr/lib/python3/dist-packages/pip/_internal/cli/main_parser.py", line 7, in <module>
    from pip._internal.cli import cmdoptions
  File "/usr/lib/python3/dist-packages/pip/_internal/cli/cmdoptions.py", line 18, in <module>
    from distutils.util import strtobool
ModuleNotFoundError: No module named 'distutils.util'
Ma config :
Version de DomoticZ -> 2022.2
Système sur lequel tourne DomoticZ avec le plugin : -> RPI 2B sous Bullseye
Python Version: 3.8.7
Modèle de coordinateur : -> PHOSCON Conbee2
Version de coordinateur : -> USB
Version du firmware : -> FW deCONZ 0x26780700 (dernier en date)
Savez-vous ou je me suis planté? :oops:
Edit 18h26
apres avoir fini le tuto d'installation du plugin (j'ai essayé....), ci dessous le log de domoticz apres un reboot
2023-02-13 18:25:46.240 Status: Domoticz V2022.2 (c)2012-2022 GizMoCuz
2023-02-13 18:25:46.241 Status: Build Hash: eea9db734, Date: 2022-11-05 13:05:35
2023-02-13 18:25:46.241 Status: Startup Path: /home/pi/domoticz/
2023-02-13 18:25:46.942 Status: PluginSystem: Started, Python version '3.8.7', 2 plugin definitions loaded.
2023-02-13 18:25:46.983 Status: WebServer(HTTP) started on address: :: with port 8080
2023-02-13 18:25:47.045 Starting shared server on: :::6144
2023-02-13 18:25:47.038 Status: WebServer(SSL) started on address: :: with port 443
2023-02-13 18:25:47.045 Status: TCPServer: shared server started...
2023-02-13 18:25:47.047 Status: RxQueue: queue worker started...
2023-02-13 18:25:49.047 Conbee2: Worker thread started.
2023-02-13 18:25:49.047 Status: Conbee2: Entering work loop.
2023-02-13 18:25:49.047 Status: Conbee2: Started.
2023-02-13 18:25:49.081 Status: Raspberry: System: Raspberry Pi
2023-02-13 18:25:49.104 Status: Raspberry: Hardware Monitor: Started (OStype Raspberry Pi Linux)
2023-02-13 18:25:49.105 Status: meteo: Started...
2023-02-13 18:25:49.105 Status: NotificationSystem: thread started...
2023-02-13 18:25:49.106 Status: EventSystem: reset all events...
2023-02-13 18:25:49.111 Status: EventSystem: reset all device statuses...
2023-02-13 18:25:49.315 Status: Python EventSystem: Initializing event module.
2023-02-13 18:25:49.316 Status: EventSystem: Started
2023-02-13 18:25:49.316 Status: EventSystem: Queue thread started...
2023-02-13 18:25:49.565 Status: PluginSystem: 1 plugins started.
2023-02-13 18:25:51.127 Raspberry: Temp (TH Raspberry Pi)
2023-02-13 18:25:51.829 Error: PyDomoticz_Error, illegal operation, Plugin has not started yet.
2023-02-13 18:25:51.953 Error: Conbee2: (Zigate) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/Domoticz-Zigbee/:/usr/lib/python38.zip:/usr/lib/python3.8:/usr/lib/python3.8/lib-dynload:/usr/local/lib/python3.8/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.8/dist-packages'.
2023-02-13 18:25:51.980 Error: Conbee2: Traceback (most recent call last):
2023-02-13 18:25:51.980 Error: Conbee2: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 123, in <module>
2023-02-13 18:25:51.980 Error: Conbee2: from Modules.input import ZigateRead
2023-02-13 18:25:51.980 Error: Conbee2: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/input.py", line 69, in <module>
2023-02-13 18:25:51.980 Error: Conbee2: from Zigbee.decode8002 import decode8002_and_process
2023-02-13 18:25:51.980 Error: Conbee2: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Zigbee/decode8002.py", line 11, in <module>
2023-02-13 18:25:51.980 Error: Conbee2: from Zigbee.zclDecoders import zcl_decoders
2023-02-13 18:25:51.980 Error: Conbee2: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Zigbee/zclDecoders.py", line 8, in <module>
2023-02-13 18:25:51.981 Error: Conbee2: from distutils.command.build import build
2023-02-13 18:25:51.981 Error: Conbee2: ModuleNotFoundError: No module named 'distutils.command'
Dernière modification par Bibi49 le 11 mars 2023, 22:00, modifié 1 fois.
RPI 2 -> Bullseye Lite
DomoticZ -> 2024.7
RFXCom 433E -> Pro1 1041
DongleP - Z-Stack 3.30+ (build 20240710) /Z4D 7.1.025 [7.489]
CC1101 433Mhz "Itron EverBlue Cyble"
PiTInfo v1.4
USB->ùSD = Rpi-clones
pipiche
Re: Probleme installation du plugin
Message par pipiche »
can you try
sudo apt-get update
sudo apt-get install python3.8-distutils
then
Bibi49
c'est grave docteur?
pi@raspberrypi:~ $ sudo apt-get update
Atteint :1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
Atteint :2 http://archive.raspberrypi.org/debian bullseye InRelease
pi@raspberrypi:~ $ sudo apt-get install python3.8-distutils
Construction de l'arbre des dépendances... Fait
E: Impossible de trouver le paquet python3.8-distutils
E: Impossible de trouver de paquet correspondant à l'expression rationnelle « py        thon3.8-distutils »
pi@raspberrypi:~ $
La version de python 3.8.7 n'est pas la bonne?
DomoticZ -> 2024.7
PiTInfo v1.4
pipiche
peux-tu faire ca alors
sudo apt-get install python3-distutils
et également
python3 --version
Bibi49
Merci de m'aider :)
pi@raspberrypi:~ $ sudo apt-get install python3-distutils
python3-distutils est déjà la version la plus récente (3.9.2-1).
python3-distutils passé en « installé manuellement ».
Les paquets suivants ont été installés automatiquement et ne sont plus nécessaires :
  javascript-common libjs-jquery libjs-sphinxdoc libjs-underscore
Veuillez utiliser « sudo apt autoremove » pour les supprimer.
0 mis à jour, 0 nouvellement installés, 0 à enlever et 0 non mis à jour.
pi@raspberrypi:~ $ python3 --version
Python 3.8.7
pi@raspberrypi:~ $
edit,
J'ai suivi le tuto pour Python (https://zigbeefordomoticz.github.io/wik ... lseye.html ) avant d'installer le plugin...
ça peut être la source du problème ?
Edit 2
si ça peut être utile :
pi@raspberrypi:~ $ dpkg -l | grep python3.9
ii  libpython3.9:armhf                   3.9.2-1+rpi1                     armhf        Shared Python runtime library (version 3.9)
ii  libpython3.9-minimal:armhf           3.9.2-1+rpi1                     armhf        Minimal subset of the Python language (version 3.9)
ii  libpython3.9-stdlib:armhf            3.9.2-1+rpi1                     armhf        Interactive high-level object-oriented language (standard library, version 3.9)
ii  python3.9                            3.9.2-1+rpi1                     armhf        Interactive high-level object-oriented language (version 3.9)
ii  python3.9-minimal                    3.9.2-1+rpi1                     armhf        Minimal subset of the Python language (version 3.9)
pi@raspberrypi:~ $ dpkg -l | grep python3.8
ii  libpython3.8:armhf                   3.8.7-1                          armhf        Shared Python runtime library (version 3.8)
ii  libpython3.8-dev:armhf               3.8.7-1                          armhf        Header files and a static library for Python (v3.8)
ii  libpython3.8-minimal:armhf           3.8.7-1                          armhf        Minimal subset of the Python language (version 3.8)
ii  libpython3.8-stdlib:armhf            3.8.7-1                          armhf        Interactive high-level object-oriented language (standard library, version 3.8)
ii  python3.8                            3.8.7-1                          armhf        Interactive high-level object-oriented language (version 3.8)
ii  python3.8-dev                        3.8.7-1                          armhf        Header files and a static library for Python (v3.8)
ii  python3.8-minimal                    3.8.7-1                          armhf        Minimal subset of the Python language (version 3.8)
pi@raspberrypi:~ $
DomoticZ -> 2024.7
PiTInfo v1.4
pipiche
du coup que donne
Pourquoi as-tu installé python3.8 ? alors que python3.9 etait déjà là ?
Bibi49
pour python, j'avais lu qu'il y avait quelque problème avec la 3.9...
pi@raspberrypi:~ $ sudo pip3 install -r requirements.txt
pi@raspberrypi:~ $
Je repasse Python en 3.9 ?
DomoticZ -> 2024.7
PiTInfo v1.4
pipiche
Je pense qu'il y-a un mic-mac python39/38 et ca explique les problèmes.
Pour ma part je pense que le problème python39 est reglé,
Bibi49
retour a Python 3.9.2 en cours...
sudo pip3 install -r requirements.txt a l'ai de fonctionner avec py3.9.2
edit
  Downloading https://www.piwheels.org/simple/pyrsistent/pyrsistent-0.19.3-cp39-cp39-linux_armv7l.whl (102 kB)
     |████████████████████████████████| 102 kB 1.3 MB/s
Requirement already satisfied: setuptools in /usr/lib/python3/dist-packages (from pure-pcapy3->-r requirements.txt (line 14)) (52.0.0)
Building wheels for collected packages: cryptography
  Building wheel for cryptography (PEP 517) ... error
  ERROR: Command errored out with exit status 1:
   command: /usr/bin/python3 /tmp/tmpk0uo3coc_in_process.py build_wheel /tmp/tmpkcv3a6jd
       cwd: /tmp/pip-install-q6ph1mbv/cryptography_efdedadc179444379d7a8d2b6e0b87bc
  Complete output (190 lines):
  running bdist_wheel
  running build
  running build_py
  creating build
  creating build/lib.linux-armv7l-cpython-39
  creating build/lib.linux-armv7l-cpython-39/cryptography
  copying src/cryptography/fernet.py -> build/lib.linux-armv7l-cpython-39/cryptography
  copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-cpython-39/cryptography
  copying src/cryptography/__about__.py -> build/lib.linux-armv7l-cpython-39/cryptography
  copying src/cryptography/utils.py -> build/lib.linux-armv7l-cpython-39/cryptography
  copying src/cryptography/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat
  copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat
  copying src/cryptography/hazmat/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat
  creating build/lib.linux-armv7l-cpython-39/cryptography/x509
  copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
  copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
  copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
  copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
  copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
  copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
  copying src/cryptography/x509/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
  copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends
  copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings
  copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/types.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/twofactor
  copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/twofactor
  copying src/cryptography/hazmat/primitives/twofactor/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/twofactor
  copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/twofactor
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/pkcs7.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/dsa.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ed448.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/hashes.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ed25519.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/dh.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/poly1305.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/x448.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/x25519.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/hmac.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/openssl
  copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/openssl
  copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/openssl
  copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/openssl
  running egg_info
  writing src/cryptography.egg-info/PKG-INFO
  writing dependency_links to src/cryptography.egg-info/dependency_links.txt
  writing requirements to src/cryptography.egg-info/requires.txt
  writing top-level names to src/cryptography.egg-info/top_level.txt
  reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
  reading manifest template 'MANIFEST.in'
  no previously-included directories found matching 'docs/_build'
  warning: no previously-included files found matching 'vectors'
  warning: no previously-included files matching '*' found under directory 'vectors'
  warning: no previously-included files matching '*' found under directory '.github'
  warning: no previously-included files found matching 'release.py'
  warning: no previously-included files found matching '.readthedocs.yml'
  warning: no previously-included files found matching 'ci-constraints-requirements.txt'
  warning: no previously-included files found matching 'tox.ini'
  warning: no previously-included files found matching 'mypy.ini'
  adding license file 'LICENSE'
  adding license file 'LICENSE.APACHE'
  adding license file 'LICENSE.BSD'
  adding license file 'LICENSE.PSF'
  writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
  /tmp/pip-build-env-76u8fny8/overlay/lib/python3.9/site-packages/setuptools/command/build_py.py:202: SetuptoolsDeprecationWarning:     Installing 'cryptography.hazmat.bindings._rust' as data is deprecated, please list it in `packages`.
      # Package would be ignored #
      Python recognizes 'cryptography.hazmat.bindings._rust' as an importable package,
      but it is not listed in the `packages` configuration of setuptools.
      'cryptography.hazmat.bindings._rust' has been automatically added to the distribution only
      because it may contain data files, but this behavior is likely to change
      in future versions of setuptools (and therefore is considered deprecated).
      Please make sure that 'cryptography.hazmat.bindings._rust' is included as a package by using
      the `packages` configuration field or the proper discovery methods
      (for example by using `find_namespace_packages(...)`/`find_namespace:`
      instead of `find_packages(...)`/`find:`).
      You can read more about "package discovery" and "data files" on setuptools
      documentation page.
    check.warn(importable)
  copying src/cryptography/py.typed -> build/lib.linux-armv7l-cpython-39/cryptography
  copying src/cryptography/hazmat/bindings/_openssl.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
  copying src/cryptography/hazmat/bindings/_rust/__init__.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
  copying src/cryptography/hazmat/bindings/_rust/asn1.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
  copying src/cryptography/hazmat/bindings/_rust/ocsp.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
  copying src/cryptography/hazmat/bindings/_rust/pkcs7.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
  copying src/cryptography/hazmat/bindings/_rust/x509.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
  running build_ext
  running build_rust
      =============================DEBUG ASSISTANCE=============================
      If you are seeing a compilation error please try the following steps to
      successfully install cryptography:
      1) Upgrade to the latest pip and try again. This will fix errors for most
         users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
      2) Read https://cryptography.io/en/latest/installation/ for specific
         instructions for your platform.
      3) Check our frequently asked questions for more information:
         https://cryptography.io/en/latest/faq/
      4) Ensure you have a recent Rust toolchain installed:
         https://cryptography.io/en/latest/installation/#rust
      Python: 3.9.2
      platform: Linux-5.15.84-v7+-armv7l-with-glibc2.31
      pip: n/a
      setuptools: 67.2.0
      setuptools_rust: 1.5.2
      rustc: n/a
  error: can't find Rust compiler
  If you are using an outdated pip version, it is possible a prebuilt wheel is available for this package but pip is not able to install from it. Installing from the wheel would avoid the need for a Rust compiler.
  To update pip, run:
      pip install --upgrade pip
  and then retry package installation.
  If you did intend to build this package from source, try installing a Rust compiler from your system package manager and ensure it is on the PATH during installation. Alternatively, rustup (available at https://rustup.rs) is the recommended way to download and update the Rust compiler toolchain.
  This package requires Rust >=1.48.0.
  ERROR: Failed building wheel for cryptography
Failed to build cryptography
ERROR: Could not build wheels for cryptography which use PEP 517 and cannot be installed directly
tout est rouge, meme le bonhomme derrière l'écran :lol:
Je sens la réinstallation complète sans tripoter Python ce coup la
Edit 23h25
Bullseye réinstallé (lite 32-bit) puis Domoticz
python3dev, sudo apt install git-all, pip install --upgrade pip, et j'en passe....
l'installation du plugin bloque encore sur :
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Ignoring pyserial-asyncio: markers 'platform_system == "Windows"' don't match your environment
Collecting aiohttp
  Using cached https://www.piwheels.org/simple/aiohttp/aiohttp-3.8.4-cp39-cp39-linux_armv7l.whl (926 kB)
Collecting aiosignal
  Using cached https://www.piwheels.org/simple/aiosignal/aiosignal-1.3.1-py3-none-any.whl (7.6 kB)
Collecting aiosqlite>=0.16.0
  Using cached https://www.piwheels.org/simple/aiosqlite/aiosqlite-0.18.0-py3-none-any.whl (15 kB)
Collecting async-timeout
  Using cached https://www.piwheels.org/simple/async-timeout/async_timeout-4.0.2-py3-none-any.whl (5.8 kB)
Collecting attrs
  Using cached https://www.piwheels.org/simple/attrs/attrs-22.2.0-py3-none-any.whl (60 kB)
Collecting click
  Using cached https://www.piwheels.org/simple/click/click-8.1.3-py3-none-any.whl (96 kB)
Collecting click-log>=0.2.1
  Using cached https://www.piwheels.org/simple/click-log/click_log-0.4.0-py2.py3-none-any.whl (4.5 kB)
Collecting crccheck
  Using cached https://www.piwheels.org/simple/crccheck/crccheck-1.3.0-py3-none-any.whl (21 kB)
Collecting coloredlogs
  Using cached https://www.piwheels.org/simple/coloredlogs/coloredlogs-15.0.1-py2.py3-none-any.whl (46 kB)
Collecting jsonschema
  Using cached https://www.piwheels.org/simple/jsonschema/jsonschema-4.17.3-py3-none-any.whl (90 kB)
Collecting frozenlist
  Using cached https://www.piwheels.org/simple/frozenlist/frozenlist-1.3.3-cp39-cp39-linux_armv7l.whl (136 kB)
Collecting multidict
  Using cached https://www.piwheels.org/simple/multidict/multidict-6.0.4-cp39-cp39-linux_armv7l.whl (109 kB)
Collecting pure-pcapy3
  Using cached https://www.piwheels.org/simple/pure-pcapy3/pure_pcapy3-1.0.1-py3-none-any.whl (6.1 kB)
Collecting pyserial>=3.5
  Using cached https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)
Collecting pyserial-asyncio
  Using cached https://www.piwheels.org/simple/pyserial-asyncio/pyserial_asyncio-0.6-py3-none-any.whl (7.5 kB)
Collecting pyusb>=1.2.1
  Using cached https://www.piwheels.org/simple/pyusb/pyusb-1.2.1-py3-none-any.whl (58 kB)
Collecting typing-extensions
  Using cached https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.4.0-py3-none-any.whl (26 kB)
Collecting voluptuous
  Using cached https://www.piwheels.org/simple/voluptuous/voluptuous-0.13.1-py3-none-any.whl (35 kB)
Collecting yarl
  Using cached https://www.piwheels.org/simple/yarl/yarl-1.8.2-cp39-cp39-linux_armv7l.whl (205 kB)
Collecting cryptography
  Using cached cryptography-39.0.1.tar.gz (603 kB)
  Installing build dependencies ... done
  Getting requirements to build wheel ... done
    Preparing wheel metadata ... done
Collecting dnspython==2.2.1
  Using cached https://www.piwheels.org/simple/dnspython/dnspython-2.2.1-py3-none-any.whl (269 kB)
Collecting charset-normalizer<4.0,>=2.0
  Using cached https://www.piwheels.org/simple/charset-normalizer/charset_normalizer-3.0.1-py3-none-any.whl (45 kB)
Requirement already satisfied: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl->-r requirements.txt (line 21)) (2.10)
Collecting humanfriendly>=9.1
  Using cached https://www.piwheels.org/simple/humanfriendly/humanfriendly-10.0-py2.py3-none-any.whl (89 kB)
Collecting cffi>=1.12
  Using cached https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp39-cp39-linux_armv7l.whl (364 kB)
Collecting pycparser
  Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)
Collecting pyrsistent!=0.17.0,!=0.17.1,!=0.17.2,>=0.14.0
  Using cached https://www.piwheels.org/simple/pyrsistent/pyrsistent-0.19.3-cp39-cp39-linux_armv7l.whl (102 kB)
   command: /usr/bin/python3 /tmp/tmpbyn1asl2_in_process.py build_wheel /tmp/tmpazj06syg
       cwd: /tmp/pip-install-cp_h90ys/cryptography_68eda5f18c7c4161b2ee391e0ce7bdb6
  Complete output (187 lines):
  running bdist_wheel
  running build
  running build_py
  creating build
  running egg_info
  /tmp/pip-build-env-rjl1j6o1/overlay/lib/python3.9/site-packages/setuptools/command/build_py.py:202: SetuptoolsDeprecationWarning:     Installing 'cryptography.hazmat.bindings._rust' as data is deprecated, please list it in `packages`.
      documentation page.
  running build_ext
  running build_rust
  cargo rustc --lib --message-format=json-render-diagnostics --manifest-path src/rust/Cargo.toml --release -v --features pyo3/extension-module pyo3/abi3-py36 -- --crate-type cdylib
      Updating crates.io index
  error: failed to get `asn1` as a dependency of package `cryptography-rust v0.1.0 (/tmp/pip-install-cp_h90ys/cryptography_68eda5f18c7c4161b2ee391e0ce7bdb6/src/rust)`
  Caused by:
    failed to fetch `https://github.com/rust-lang/crates.io-index`
  Caused by:
    error inflating zlib stream; class=Zlib (5)
      Python: 3.9.2
      pip: n/a
      setuptools: 67.2.0
      rustc: 1.48.0 (471d696c7 2020-12-10)
  error: `cargo rustc --lib --message-format=json-render-diagnostics --manifest-path src/rust/Cargo.toml --release -v --features 'pyo3/extension-module pyo3/abi3-py36' -- --crate-type cdylib` failed with code 101
Je commence a croire que c'est la version lite qui pose problème...
Si j'ai le courage, demain j'installe la version Desktop .
DomoticZ -> 2024.7
PiTInfo v1.4
Deufo
Message par Deufo »
Ca fonctionne très bien avec la version lite, c'est juste cryptography qui peut être un peu pénible car les dernières versions nécessitent un compilateur rust pour s'installer correctement.
