Edité le 11/03/2023
Probleme resolut avec l'utilisation de Python 3.9.2 de Bulleyes, et l'installation de python3-dev et python3-pip
J'ai une erreur lors de l'installation du plugin.
Dans la section 1 Installation manuelle sous linux
Etape 1B
Installer les paquets Python nécessaires avec la commande :
sudo pip3 install -r requirements.txt
pi@raspberrypi:~/domoticz/plugins $ cd Domoticz-Zigbee/
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ sudo pip3 install -r requirements.txt
File "/usr/bin/pip3", line 33, in <module>
sys.exit(load_entry_point('pip==20.3.4', 'console_scripts', 'pip3')())
File "/usr/bin/pip3", line 25, in importlib_load_entry_point
return next(matches).load()
File "/usr/lib/python3.8/importlib/metadata.py", line 77, in load
module = import_module(match.group('module'))
File "/usr/lib/python3.8/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
File "<frozen importlib._bootstrap>", line 991, in _find_and_load
File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 783, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/usr/lib/python3/dist-packages/pip/_internal/cli/main.py", line 10, in <module>
from pip._internal.cli.autocompletion import autocomplete
File "/usr/lib/python3/dist-packages/pip/_internal/cli/autocompletion.py", line 9, in <module>
from pip._internal.cli.main_parser import create_main_parser
File "/usr/lib/python3/dist-packages/pip/_internal/cli/main_parser.py", line 7, in <module>
from pip._internal.cli import cmdoptions
File "/usr/lib/python3/dist-packages/pip/_internal/cli/cmdoptions.py", line 18, in <module>
from distutils.util import strtobool
ModuleNotFoundError: No module named 'distutils.util'
Version de DomoticZ -> 2022.2
Système sur lequel tourne DomoticZ avec le plugin : -> RPI 2B sous Bullseye
Python Version: 3.8.7
Modèle de coordinateur : -> PHOSCON Conbee2
Version de coordinateur : -> USB
Version du firmware : -> FW deCONZ 0x26780700 (dernier en date)
Savez-vous ou je me suis planté?
Edit 18h26
apres avoir fini le tuto d'installation du plugin (j'ai essayé....), ci dessous le log de domoticz apres un reboot
2023-02-13 18:25:46.240 Status: Domoticz V2022.2 (c)2012-2022 GizMoCuz
2023-02-13 18:25:46.241 Status: Build Hash: eea9db734, Date: 2022-11-05 13:05:35
2023-02-13 18:25:46.241 Status: Startup Path: /home/pi/domoticz/
2023-02-13 18:25:46.942 Status: PluginSystem: Started, Python version '3.8.7', 2 plugin definitions loaded.
2023-02-13 18:25:46.983 Status: WebServer(HTTP) started on address: :: with port 8080
2023-02-13 18:25:47.045 Starting shared server on: :::6144
2023-02-13 18:25:47.038 Status: WebServer(SSL) started on address: :: with port 443
2023-02-13 18:25:47.045 Status: TCPServer: shared server started...
2023-02-13 18:25:47.047 Status: RxQueue: queue worker started...
2023-02-13 18:25:49.047 Conbee2: Worker thread started.
2023-02-13 18:25:49.047 Status: Conbee2: Entering work loop.
2023-02-13 18:25:49.047 Status: Conbee2: Started.
2023-02-13 18:25:49.081 Status: Raspberry: System: Raspberry Pi
2023-02-13 18:25:49.104 Status: Raspberry: Hardware Monitor: Started (OStype Raspberry Pi Linux)
2023-02-13 18:25:49.105 Status: meteo: Started...
2023-02-13 18:25:49.105 Status: NotificationSystem: thread started...
2023-02-13 18:25:49.106 Status: EventSystem: reset all events...
2023-02-13 18:25:49.111 Status: EventSystem: reset all device statuses...
2023-02-13 18:25:49.315 Status: Python EventSystem: Initializing event module.
2023-02-13 18:25:49.316 Status: EventSystem: Started
2023-02-13 18:25:49.316 Status: EventSystem: Queue thread started...
2023-02-13 18:25:49.565 Status: PluginSystem: 1 plugins started.
2023-02-13 18:25:51.127 Raspberry: Temp (TH Raspberry Pi)
2023-02-13 18:25:51.829 Error: PyDomoticz_Error, illegal operation, Plugin has not started yet.
2023-02-13 18:25:51.953 Error: Conbee2: (Zigate) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/Domoticz-Zigbee/:/usr/lib/python38.zip:/usr/lib/python3.8:/usr/lib/python3.8/lib-dynload:/usr/local/lib/python3.8/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.8/dist-packages'.
2023-02-13 18:25:51.980 Error: Conbee2: Traceback (most recent call last):
2023-02-13 18:25:51.980 Error: Conbee2: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 123, in <module>
2023-02-13 18:25:51.980 Error: Conbee2: from Modules.input import ZigateRead
2023-02-13 18:25:51.980 Error: Conbee2: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/input.py", line 69, in <module>
2023-02-13 18:25:51.980 Error: Conbee2: from Zigbee.decode8002 import decode8002_and_process
2023-02-13 18:25:51.980 Error: Conbee2: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Zigbee/decode8002.py", line 11, in <module>
2023-02-13 18:25:51.980 Error: Conbee2: from Zigbee.zclDecoders import zcl_decoders
2023-02-13 18:25:51.980 Error: Conbee2: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Zigbee/zclDecoders.py", line 8, in <module>
2023-02-13 18:25:51.981 Error: Conbee2: from distutils.command.build import build
2023-02-13 18:25:51.981 Error: Conbee2: ModuleNotFoundError: No module named 'distutils.command'
