[Fermé] soucis avec la mise a jour du plugin
taz5962
Message par taz5962 »
salut a tous
1. Une description du problème.
Qu'est-ce qui ne fonctionne pas ? mise a jour du plugin ne ce lance pas
2. Les versions utilisées
Version de DomoticZ : 2022.1
Version de Python : 3.7.3
Système sur lequel tourne DomoticZ avec le plugin : RPI4
Modèle de coordinateur : Sonoff CC1352/CC2652, Z-Stack 3
Version de coordinateur : USB
Version du firmware : 1217
Version du plugin 6.3.007
Branche du plugin : stable6
j'utilise déjà une ancienne version stable 6.3.007, ça faisait un moment que je le laisse tourner sans m'en occuper
j'ai voulu mettre a jour le plugin, mais quand je lance la mise a jour il m'annonce :
Starting Zigbee for Domoticz plugin Upgrade process.
(1) updating Zigbee for Domoticz plugin
Setup submodule.recurse
Problem while running command 'git pull --recurse-submodules'.
Git Status:
et la notification me dis de regarder dans les logs, que voici :
{"3":{"0":{"Time":"31/12/2022 21:41:11","Module":"DZDB","nwkid":"None","PluginHealth":"Startup","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":0},"Thread":"MainThread"},"1":{"Time":"31/12/2022 21:41:11","Module":"DZDB","nwkid":"None","PluginHealth":"Startup","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":0},"Thread":"MainThread"},"LastLog":1,"StartTime":"31/12/2022 21:41:11","FirmwareVersion":null,"FirmwareMajorVersion":null,"PluginVersion":["stable6-6.3.007"]},
"4":{"624":{"Time":"01/01/2023 08:15:51","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"625":{"Time":"01/01/2023 08:15:51","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"626":{"Time":"01/01/2023 08:16:31","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"627":{"Time":"01/01/2023 08:16:31","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"628":{"Time":"01/01/2023 08:17:01","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"629":{"Time":"01/01/2023 08:17:02","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"630":{"Time":"01/01/2023 08:17:32","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"631":{"Time":"01/01/2023 08:17:32","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"632":{"Time":"01/01/2023 08:18:02","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"633":{"Time":"01/01/2023 08:18:02","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"634":{"Time":"01/01/2023 08:18:42","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"635":{"Time":"01/01/2023 08:18:42","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"636":{"Time":"01/01/2023 08:19:12","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"637":{"Time":"01/01/2023 08:19:12","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"638":{"Time":"01/01/2023 08:20:22","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"639":{"Time":"01/01/2023 08:20:22","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"640":{"Time":"01/01/2023 08:21:12","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"641":{"Time":"01/01/2023 08:21:12","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"642":{"Time":"01/01/2023 08:21:43","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"643":{"Time":"01/01/2023 08:21:43","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"LastLog":643,"StartTime":"31/12/2022 22:32:12","FirmwareVersion":"1217","FirmwareMajorVersion":"21"},
"5":{"0":{"Time":"01/01/2023 08:17:23","Module":"DZDB","nwkid":"None","PluginHealth":"Startup","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":0},"Thread":"MainThread"},"1":{"Time":"01/01/2023 08:17:23","Module":"DZDB","nwkid":"None","PluginHealth":"Startup","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":0},"Thread":"MainThread"},"LastLog":1,"StartTime":"01/01/2023 08:17:23","FirmwareVersion":null,"FirmwareMajorVersion":null,"PluginVersion":["stable6-6.3.007"]},
"6":{"90785":{"Time":"21/02/2023 16:49:25","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90786":{"Time":"21/02/2023 16:56:53","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90787":{"Time":"21/02/2023 16:58:44","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90788":{"Time":"21/02/2023 16:58:44","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90789":{"Time":"21/02/2023 16:58:46","Module":"WebServer","nwkid":"None","PluginHealth":"Ready","message":"do_rest - Verb: GET, Command: plugin-log, Param: [] not found !!!","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"MainThread"},"90790":{"Time":"21/02/2023 16:59:19","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90791":{"Time":"21/02/2023 17:00:30","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90792":{"Time":"21/02/2023 17:01:10","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90793":{"Time":"21/02/2023 17:01:40","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90794":{"Time":"21/02/2023 17:03:00","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90795":{"Time":"21/02/2023 17:03:30","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90796":{"Time":"21/02/2023 17:04:21","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90797":{"Time":"21/02/2023 17:04:51","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90798":{"Time":"21/02/2023 17:05:17","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"MainThread"},"90799":{"Time":"21/02/2023 17:05:22","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"MainThread"},"90800":{"Time":"21/02/2023 17:05:22","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"MainThread"},"90801":{"Time":"21/02/2023 17:05:27","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"MainThread"},"90802":{"Time":"21/02/2023 17:05:41","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90803":{"Time":"21/02/2023 17:08:44","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90804":{"Time":"21/02/2023 17:08:44","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"LastLog":90804,"StartTime":"01/01/2023 08:32:54","FirmwareVersion":"1217","FirmwareMajorVersion":"21"},"LastLog":6}
que faire ?
Dernière modification par Keros le 13 avr. 2023, 22:45, modifié 3 fois.
Raison : Fermeture du sujet car sans réponses
Deufo
Re: soucis avec la mise a jour du plugin
Message par Deufo »
https://zigbeefordomoticz.github.io/wik ... C3%A9trage
API base url Renseigner l’adresse du serveur DomoticZ Adresse sous la forme http://username:password@127.0.0.1:port
Par défaut http://127.0.0.1:8080
taz5962
oui et ?
ça fonctionner avant et j'ai rien changer
tu me parle de l'API pour communiquer avec domoticz alors que c'est juste la mise a jour du plugin Zigbee4domoticz qui ne fonctionne pas
Dernière modification par taz5962 le 21 févr. 2023, 19:07, modifié 1 fois.
Deufo
Message par Deufo »
T'aurais pas mis à jour Domoticz en 2023.1 ?
C'est vrai qu'on n'a pas les infos demandées dans le sujet [A lire avant de poster] Guide pour bien formuler une demande.
Sinon as-tu essayé : https://zigbeefordomoticz.github.io/wik ... s-derreurs
taz5962
non du tout
tu te trompe sur l'erreur, domoticz et le plugin zigbee4domoticz fonctionnent parfaitement
c'est juste la mise a jour du plugin qui merde
Pourtant, tu as une erreur du 21/02/2023 16:49:25 qui indique You need to setup the URL Base to access the Domoticz JSON/API.
Tu aurais donc 2 soucis. Un avec la mise à jour et un deuxième pour le paramétrage du plugin.
taz5962
mon domoticz tourne
le plugin aussi, les devices sont bien appairer et fonctionnent
pourtant j'avais deja lancé une mise a jour du plugin sans soucis
et aucune mise a jour de domoticz, seulement l'apt update et upgrade du pi
Ok, on reprend.
Tu as essayé les commandes :
git reset --hard
git pull --force
Ajouter sudo devant si besoin.
Colle-nous le résultat de chaque commande ici stp.
taz5962
