1. Une description du problème.
Qu'est-ce qui ne fonctionne pas ? mise a jour du plugin ne ce lance pas
2. Les versions utilisées
Version de DomoticZ : 2022.1
Version de Python : 3.7.3
Système sur lequel tourne DomoticZ avec le plugin : RPI4
Modèle de coordinateur : Sonoff CC1352/CC2652, Z-Stack 3
Version de coordinateur : USB
Version du firmware : 1217
Version du plugin 6.3.007
Branche du plugin : stable6
j'utilise déjà une ancienne version stable 6.3.007, ça faisait un moment que je le laisse tourner sans m'en occuper
j'ai voulu mettre a jour le plugin, mais quand je lance la mise a jour il m'annonce :
Starting Zigbee for Domoticz plugin Upgrade process.
(1) updating Zigbee for Domoticz plugin
Setup submodule.recurse
Problem while running command 'git pull --recurse-submodules'.
Git Status:
et la notification me dis de regarder dans les logs, que voici :
{"3":{"0":{"Time":"31/12/2022 21:41:11","Module":"DZDB","nwkid":"None","PluginHealth":"Startup","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":0},"Thread":"MainThread"},"1":{"Time":"31/12/2022 21:41:11","Module":"DZDB","nwkid":"None","PluginHealth":"Startup","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":0},"Thread":"MainThread"},"LastLog":1,"StartTime":"31/12/2022 21:41:11","FirmwareVersion":null,"FirmwareMajorVersion":null,"PluginVersion":["stable6-6.3.007"]},
"4":{"624":{"Time":"01/01/2023 08:15:51","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"625":{"Time":"01/01/2023 08:15:51","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"626":{"Time":"01/01/2023 08:16:31","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"627":{"Time":"01/01/2023 08:16:31","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"628":{"Time":"01/01/2023 08:17:01","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"629":{"Time":"01/01/2023 08:17:02","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"630":{"Time":"01/01/2023 08:17:32","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"631":{"Time":"01/01/2023 08:17:32","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"632":{"Time":"01/01/2023 08:18:02","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"633":{"Time":"01/01/2023 08:18:02","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"634":{"Time":"01/01/2023 08:18:42","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"635":{"Time":"01/01/2023 08:18:42","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"636":{"Time":"01/01/2023 08:19:12","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"637":{"Time":"01/01/2023 08:19:12","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"638":{"Time":"01/01/2023 08:20:22","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"639":{"Time":"01/01/2023 08:20:22","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"640":{"Time":"01/01/2023 08:21:12","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"641":{"Time":"01/01/2023 08:21:12","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"642":{"Time":"01/01/2023 08:21:43","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"643":{"Time":"01/01/2023 08:21:43","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1672538100},"Thread":"ZigpyForwarder_2"},"LastLog":643,"StartTime":"31/12/2022 22:32:12","FirmwareVersion":"1217","FirmwareMajorVersion":"21"},
"5":{"0":{"Time":"01/01/2023 08:17:23","Module":"DZDB","nwkid":"None","PluginHealth":"Startup","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":0},"Thread":"MainThread"},"1":{"Time":"01/01/2023 08:17:23","Module":"DZDB","nwkid":"None","PluginHealth":"Startup","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":0},"Thread":"MainThread"},"LastLog":1,"StartTime":"01/01/2023 08:17:23","FirmwareVersion":null,"FirmwareMajorVersion":null,"PluginVersion":["stable6-6.3.007"]},
"6":{"90785":{"Time":"21/02/2023 16:49:25","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90786":{"Time":"21/02/2023 16:56:53","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90787":{"Time":"21/02/2023 16:58:44","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90788":{"Time":"21/02/2023 16:58:44","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90789":{"Time":"21/02/2023 16:58:46","Module":"WebServer","nwkid":"None","PluginHealth":"Ready","message":"do_rest - Verb: GET, Command: plugin-log, Param: [] not found !!!","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"MainThread"},"90790":{"Time":"21/02/2023 16:59:19","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90791":{"Time":"21/02/2023 17:00:30","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90792":{"Time":"21/02/2023 17:01:10","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90793":{"Time":"21/02/2023 17:01:40","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90794":{"Time":"21/02/2023 17:03:00","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90795":{"Time":"21/02/2023 17:03:30","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90796":{"Time":"21/02/2023 17:04:21","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90797":{"Time":"21/02/2023 17:04:51","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90798":{"Time":"21/02/2023 17:05:17","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"MainThread"},"90799":{"Time":"21/02/2023 17:05:22","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"MainThread"},"90800":{"Time":"21/02/2023 17:05:22","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"MainThread"},"90801":{"Time":"21/02/2023 17:05:27","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"MainThread"},"90802":{"Time":"21/02/2023 17:05:41","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90803":{"Time":"21/02/2023 17:08:44","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"90804":{"Time":"21/02/2023 17:08:44","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"You need to setup the URL Base to access the Domoticz JSON/API","PermitToJoin":{"Duration":0,"Starttime":1673679669},"Thread":"ZigpyForwarder_2"},"LastLog":90804,"StartTime":"01/01/2023 08:32:54","FirmwareVersion":"1217","FirmwareMajorVersion":"21"},"LastLog":6}
