sudo python3 -m pip install pip wheel pyopenssl --upgradeCode : Tout sélectionner
sudo python3 -m pip install -r requirements.txt --upgradeCode : Tout sélectionner
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ sudo service domoticz.sh stop
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ sudo python3 -m pip install pip wheel pyopenssl --upgrade
File "/usr/lib/python3.9/runpy.py", line 197, in _run_module_as_main
return _run_code(code, main_globals, None,
File "/usr/lib/python3.9/runpy.py", line 87, in _run_code
exec(code, run_globals)
File "/usr/lib/python3/dist-packages/pip/__main__.py", line 23, in <module>
from pip._internal.cli.main import main as _main # isort:skip # noqa
File "/usr/lib/python3/dist-packages/pip/_internal/cli/main.py", line 10, in <module>
from pip._internal.cli.autocompletion import autocomplete
File "/usr/lib/python3/dist-packages/pip/_internal/cli/autocompletion.py", line 9, in <module>
from pip._internal.cli.main_parser import create_main_parser
File "/usr/lib/python3/dist-packages/pip/_internal/cli/main_parser.py", line 7, in <module>
from pip._internal.cli import cmdoptions
File "/usr/lib/python3/dist-packages/pip/_internal/cli/cmdoptions.py", line 23, in <module>
from pip._vendor.packaging.utils import canonicalize_name
File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 94, in <module>
vendored("requests.packages.urllib3.contrib.pyopenssl")
File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 36, in vendored
__import__(modulename, globals(), locals(), level=0)
File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 664, in _load_unlocked
File "<frozen importlib._bootstrap>", line 627, in _load_backward_compatible
File "<frozen zipimport>", line 259, in load_module
File "/usr/share/python-wheels/urllib3-1.26.5-py2.py3-none-any.whl/urllib3/contrib/pyopenssl.py", line 50, in <module>
File "/usr/lib/python3/dist-packages/OpenSSL/__init__.py", line 8, in <module>
from OpenSSL import crypto, SSL
File "/usr/lib/python3/dist-packages/OpenSSL/crypto.py", line 1556, in <module>
class X509StoreFlags(object):
File "/usr/lib/python3/dist-packages/OpenSSL/crypto.py", line 1577, in X509StoreFlags
CB_ISSUER_CHECK = _lib.X509_V_FLAG_CB_ISSUER_CHECK
AttributeError: module 'lib' has no attribute 'X509_V_FLAG_CB_ISSUER_CHECK'
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ sudo python3 -m pip install -r requirements.txt --upgrade
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ sudo service domoticz.sh start
2023-03-07 11:34:26.838 Error: Conbee2: (Zigate) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/Domoticz-Zigbee/:/usr/lib/python39.zip:/usr/lib/python3.9:/usr/lib/python3.9/lib-dynload:/usr/local/lib/python3.9/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.9/dist-packages'.
2023-03-07 11:34:26.843 Error: Conbee2: Traceback (most recent call last):
2023-03-07 11:34:26.844 Error: Conbee2: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 97, in <module>
2023-03-07 11:34:26.844 Error: Conbee2: import z4d_certified_devices
2023-03-07 11:34:26.844 Error: Conbee2: ModuleNotFoundError: No module named 'z4d_certified_devices'Code : Tout sélectionner
sudo tar cvf monbackup.tar .c'est dans Outils/Debogage/trackZclClusters ?pipiche a écrit : 01 mars 2023, 20:09
Peux-tu une fois sur develop faire tourner en activant le debug : ZclClusters
