Wiki ici chat sur Keybase.io
2023-11-04 14:27:28.064 Status: ZIGBEE: Started.
2023-11-04 14:27:28.064 Status: ZIGBEE: Entering work loop.
2023-11-04 14:27:28.066 Status: NotificationSystem: thread started...
2023-11-04 14:27:28.073 Status: EventSystem: reset all events...
2023-11-04 14:27:28.081 Status: dzVents: Write file: /opt/domoticz/userdata/scripts/dzVents/generated_scripts/On_presence.lua
2023-11-04 14:27:28.082 Status: dzVents: Write file: /opt/domoticz/userdata/scripts/dzVents/generated_scripts/on_presence_off.lua
2023-11-04 14:27:28.083 Status: dzVents: Write file: /opt/domoticz/userdata/scripts/dzVents/generated_scripts/on_presence_on.lua
2023-11-04 14:27:28.084 Status: dzVents: Write file: /opt/domoticz/userdata/scripts/dzVents/generated_scripts/global_data.lua
2023-11-04 14:27:28.084 Status: dzVents: Write file: /opt/domoticz/userdata/scripts/dzVents/generated_scripts/OnUnifiActivity.lua
2023-11-04 14:27:28.085 Status: dzVents: Write file: /opt/domoticz/userdata/scripts/dzVents/generated_scripts/out_of_frost.lua
2023-11-04 14:27:28.087 Status: dzVents: Write file: /opt/domoticz/userdata/scripts/dzVents/generated_scripts/thermostat_rdc.lua
2023-11-04 14:27:28.088 Status: dzVents: Write file: /opt/domoticz/userdata/scripts/dzVents/generated_scripts/thermostat_nais.lua
2023-11-04 14:27:28.089 Status: dzVents: Write file: /opt/domoticz/userdata/scripts/dzVents/generated_scripts/thermostat_parent.lua
2023-11-04 14:27:28.090 Status: dzVents: Write file: /opt/domoticz/userdata/scripts/dzVents/generated_scripts/on_switch_salon.lua
2023-11-04 14:27:28.091 Status: EventSystem: reset all device statuses...
2023-11-04 14:27:28.254 Status: Python EventSystem: Initializing event module.
2023-11-04 14:27:28.256 Status: EventSystem: Started
2023-11-04 14:27:28.256 Status: EventSystem: Queue thread started...
2023-11-04 14:27:28.394 Status: PluginSystem: 1 plugins started.
2023-11-04 14:27:29.064 Status: MQTT: Connecting to 192.168.20.6:1883
2023-11-04 14:27:29.266 Status: MQTT: connected to: 192.168.20.6:1883
2023-11-04 14:27:29.451 Status: ZIGBEE: Initialized version 7.1, author 'pipiche38'
2023-11-04 14:27:29.453 Status: ZIGBEE: Zigbee for Domoticz plugin starting
2023-11-04 14:27:29.453 Status: ZIGBEE: Z4D plugin requires python3 3.8 or above and you are running 3.9
2023-11-04 14:27:29.454 Status: ZIGBEE: Checking Python modules /opt/domoticz/userdata/plugins/Domoticz-Zigbee/requirements.txt
2023-11-04 14:27:30.308 ZIGBEE: load PluginConf
2023-11-04 14:27:30.309 ZIGBEE: Loading PluginConf - from Domoticz sqlite Db
2023-11-04 14:27:30.310 ZIGBEE: /opt/domoticz/userdata/plugins/Domoticz-Zigbee/Conf/PluginConf-09.json timestamp is 1699103604.0943222
2023-11-04 14:27:30.310 ZIGBEE: Dz PluginConf is older than Json Dz: 0 Json: 1699103604.0943222
2023-11-04 14:27:30.312 Status: ZIGBEE: PluginAnalytics set to 1
2023-11-04 14:27:30.312 Status: ZIGBEE: Livolo set to 1
2023-11-04 14:27:30.312 Status: ZIGBEE: Orvibo set to 1
2023-11-04 14:27:30.312 Status: ZIGBEE: channel set to 25
2023-11-04 14:27:30.312 Status: ZIGBEE: filename set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee/Conf/PluginConf-09.json
2023-11-04 14:27:30.312 Status: ZIGBEE: pluginHome set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee
2023-11-04 14:27:30.312 Status: ZIGBEE: homedirectory set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee
2023-11-04 14:27:30.312 Status: ZIGBEE: pluginData set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee/Data
2023-11-04 14:27:30.312 Status: ZIGBEE: pluginConfig set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee/Conf
2023-11-04 14:27:30.312 Status: ZIGBEE: pluginOTAFirmware set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee/OTAFirmware
2023-11-04 14:27:30.312 Status: ZIGBEE: pluginReports set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee/Reports
2023-11-04 14:27:30.313 Status: ZIGBEE: pluginWWW set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee/www
2023-11-04 14:27:30.313 Status: ZIGBEE: pluginLogs set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee/Logs
2023-11-04 14:27:30.313 Status: ZIGBEE: trackZclClustersIn set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: trackZclClustersOut set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: trackZdpClustersIn set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: trackZdpClustersOut set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: logThreadName set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: trackTransportError set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: ZiGateReactTime set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: showTimeOutMsg set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: coordinatorCmd set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: z4dCertifiedDevices set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: Input set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: ZclClusters set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: DeviceAnnoucement set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: BasicOutput set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: Binding set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: ConfigureReporting set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: WriteAttributes set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: ReadAttributes set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: Thermostats set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: Transport set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: Transport8000 set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: Transport8002 set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: Transport8011 set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: TransportWrter set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: TransportFrwder set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: TransportRder set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: TransportProto set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: TransportTcpip set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: TransportSerial set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: TransportZigpy set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: TransportError set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: Zigpy set to 1
2023-11-04 14:27:30.313 Status: ZIGBEE: ZigpyZigate set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: ZigpyZNP set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: ZigpydeCONZ set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: ZigpyEZSP set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: TransportPluginEncoder set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: Cluster set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: Heartbeat set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: Widget set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: WidgetCreation set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: Plugin set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: Database set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: Command set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: Pairing set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: NetworkMap set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: NetworkEnergy set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: Groups set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: OTA set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: IAS set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: DZDB set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: WebServer set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: Ikea set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: Legrand set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: Lumi set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: Heiman set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: Livolo set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: Tuya0601 set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: AbstractDz set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: CasaIA set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: Enki set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: Orvibo set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: Pluzzy set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: PollControl set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: PluginTools set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: PDM set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: inRawAPS set to 1
2023-11-04 14:27:30.314 Status: ZIGBEE: outRawAPS set to 1
2023-11-04 14:27:30.315 Status: ZIGBEE: zdpCommand set to 1
2023-11-04 14:27:30.315 Status: ZIGBEE: zclCommand set to 1
2023-11-04 14:27:30.315 Status: ZIGBEE: zdpDecoder set to 1
2023-11-04 14:27:30.315 Status: ZIGBEE: zclDecoder set to 1
2023-11-04 14:27:30.315 Status: ZIGBEE: zigateCommand set to 1
2023-11-04 14:27:30.315 Status: ZIGBEE: ThreadForwarder set to 1
2023-11-04 14:27:30.315 Status: ZIGBEE: ThreadDomoticz set to 1
2023-11-04 14:27:30.315 Status: ZIGBEE: ThreadWriter set to 1
2023-11-04 14:27:30.315 Status: ZIGBEE: ThreadCommunication set to 1
2023-11-04 14:27:30.315 Status: ZIGBEE: ZLinky set to 1
2023-11-04 14:27:30.315 Status: ZIGBEE: ControllerInRawMode set to True
2023-11-04 14:27:30.315 Status: ZIGBEE: expJsonDatabase set to 0
2023-11-04 14:27:30.315 ZIGBEE: Installing plugin custom page /opt/domoticz/www/templates/ZIGBEE.html
2023-11-04 14:27:30.319 ZIGBEE: Starting LoggingManagement thread
2023-11-04 14:27:30.319 ZIGBEE: zigpy_login_mode(30)
2023-11-04 14:27:30.322 ZIGBEE: zigpy_login_mode(10)
2023-11-04 14:27:30.325 ZIGBEE: start_logging_thread
2023-11-04 14:27:30.326 ZIGBEE: logging_thread - listening
2023-11-04 14:27:30.327 Status: ZIGBEE: Please watch plugin log into /opt/domoticz/userdata/plugins/Domoticz-Zigbee/Logs/PluginZigbee_09.log
2023-11-04 14:27:30.340 Status: ZIGBEE: [ MainThread 464] Zigbee for Domoticz (z4d) plugin stable7-7.1.004 started
2023-11-04 14:27:30.340 Status: [web:8080] Incoming connection from: 127.0.0.1
2023-11-04 14:27:30.373 Status: ZIGBEE: [ MainThread 464] Loading ZCL Cluster definitions
2023-11-04 14:27:30.375 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0000 - (V1) Basic loaded
2023-11-04 14:27:30.376 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0001 - (V1) Power loaded
2023-11-04 14:27:30.377 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0002 - (V1) Device Temperature Configuration loaded
2023-11-04 14:27:30.378 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0003 - (V1) Identify loaded
2023-11-04 14:27:30.380 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0004 - (V1) Groups loaded
2023-11-04 14:27:30.382 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0005 - (V1) Scenes loaded
2023-11-04 14:27:30.384 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0006 - (V1) On/Off loaded
2023-11-04 14:27:30.386 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0007 - (V1) On/Off Switch Configuration loaded
2023-11-04 14:27:30.387 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0008 - (V1) Level loaded
2023-11-04 14:27:30.389 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0009 - (V1) Alarms loaded
2023-11-04 14:27:30.391 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 000a - (V1) Time loaded
2023-11-04 14:27:30.393 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 000d - (V1) Analog Output loaded
2023-11-04 14:27:30.394 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 000f - (V1) Binary Input loaded
2023-11-04 14:27:30.396 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0013 - (V1) Multistate Output loaded
2023-11-04 14:27:30.398 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0019 - (V1) OTA Upgrade loaded
2023-11-04 14:27:30.399 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0020 - (V1) Poll Control loaded
2023-11-04 14:27:30.401 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0102 - (V1) Window Covering loaded
2023-11-04 14:27:30.403 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0202 - (V1) Fan Control loaded
2023-11-04 14:27:30.405 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0204 - (V1) Thermostat User Interface Configuration loaded
2023-11-04 14:27:30.407 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0300 - (V1) Color Control loaded
2023-11-04 14:27:30.409 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0301 - (V1) Ballast Configuration loaded
2023-11-04 14:27:30.411 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0400 - (V1) Illuminance Level Sensing loaded
2023-11-04 14:27:30.413 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0402 - (V1) Temperature Measurement loaded
2023-11-04 14:27:30.414 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0403 - (V1) Pressure Measurement loaded
2023-11-04 14:27:30.416 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0405 - (V1) Relative Humidity Measurement loaded
2023-11-04 14:27:30.418 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0406 - (V1) Occupancy Sensing loaded
2023-11-04 14:27:30.422 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0700 - (V1) Price loaded
2023-11-04 14:27:30.425 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0702 - (V1) Metering (Smart Energy) loaded
2023-11-04 14:27:30.427 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0b01 - (V1) Meter Identification loaded
2023-11-04 14:27:30.429 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0b04 - (V1) Electrical Measurement loaded
2023-11-04 14:27:30.431 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster 0b05 - (V1) Diagnostics loaded
2023-11-04 14:27:30.433 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster e000 - (V1) Tuya E000 Private Cluster loaded
2023-11-04 14:27:30.435 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster e001 - (V1) Tuya E001 Private Cluster loaded
2023-11-04 14:27:30.437 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster e002 - (V1) Tuya E002 Private Cluster loaded
2023-11-04 14:27:30.439 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster fcc0 - (V1) LUMI Private Cluster loaded
2023-11-04 14:27:30.441 Status: ZIGBEE: [ MainThread 464] - ZCL Cluster ff66 - (V1) Lixee Zlinky private cluster loaded
2023-11-04 14:27:30.449 Status: ZIGBEE: [ MainThread 464] DeviceConf loaded - 16 confs loaded
2023-11-04 14:27:30.461 Status: ZIGBEE: [ MainThread 464] Local-Device conf loaded - 21 confs loaded
2023-11-04 14:27:30.970 Status: ZIGBEE: [ MainThread 464] Certified Devices loaded - 518 confs loaded
2023-11-04 14:27:30.973 Status: ZIGBEE: [ MainThread 464] load ListOfDevice
2023-11-04 14:27:30.976 Status: ZIGBEE: [ MainThread 464] 1 Entries loaded from /opt/domoticz/userdata/plugins/Domoticz-Zigbee/Data/DeviceList-9.txt
2023-11-04 14:27:30.985 Status: ZIGBEE: [ MainThread 464] Transport mode: ZigpyEZSP
2023-11-04 14:27:32.182 Status: ZIGBEE: [ MainThread 464] Start Zigpy Transport on EZSP
2023-11-04 14:27:32.196 Status: ZIGBEE: [ZigpyForwarder_9 487] ZigpyTransport: thread_processing_and_sending Thread start.
2023-11-04 14:27:32.197 Status: ZIGBEE: [ MainThread 464] Start Web Server connection
2023-11-04 14:27:32.216 Status: ZIGBEE: [ MainThread 464] Web backend for Web User Interface started on port: 9440
2023-11-04 14:27:32.420 Status: ZIGBEE: [ MainThread 464] Plugin looks to upgrade the Certified Device package
2023-11-04 14:27:32.777 Status: ZIGBEE: [ ZigpyCom_9 486] Started radio ezsp port: /dev/ttyACM0
2023-11-04 14:27:34.158 Status: ZIGBEE: [ ZigpyCom_9 486] Bellows Radio register default Ep
2023-11-04 14:27:34.581 ZIGBEE: Zigate receive message processing time Max: 1 ms with an of average: 1 ms
2023-11-04 14:27:34.900 Status: ZIGBEE: [ZigpyForwarder_9 487] Number of devices recently active in Coordinator = 0
2023-11-04 14:27:34.938 ZIGBEE: Zigate Thread Serial Read Max: 0 ms with an of average: 0 ms
2023-11-04 14:27:34.941 Status: ZIGBEE: [ ZigpyCom_9 486] EZSP Radio manufacturer:
2023-11-04 14:27:34.942 Status: ZIGBEE: [ ZigpyCom_9 486] EZSP Radio board name:
2023-11-04 14:27:34.943 Status: ZIGBEE: [ ZigpyCom_9 486] EmberZNet version: 6.10.3.0 build 297
2023-11-04 14:27:34.946 Status: ZIGBEE: [ ZigpyCom_9 486] Network settings
2023-11-04 14:27:34.948 Status: ZIGBEE: [ ZigpyCom_9 486] Device IEEE: e0:79:8d:ff:fe:c7:b7:1b
2023-11-04 14:27:34.949 Status: ZIGBEE: [ ZigpyCom_9 486] Device NWK: 0x0000
2023-11-04 14:27:34.951 ZIGBEE: Zigate receive message processing time Max: 10 ms with an of average: 1 ms
2023-11-04 14:27:34.953 Status: ZIGBEE: [ ZigpyCom_9 486] Network Update Id: 0x0000
2023-11-04 14:27:34.955 Status: ZIGBEE: [ ZigpyCom_9 486] PAN ID: 0xCF51
2023-11-04 14:27:34.956 Status: ZIGBEE: [ ZigpyCom_9 486] Extended PAN ID: 60:61:e1:21:8b:c4:e7:9f
2023-11-04 14:27:34.957 Status: ZIGBEE: [ ZigpyCom_9 486] Channel: 25
2023-11-04 14:27:34.972 Status: ZIGBEE: [ZigpyForwarder_9 487] Untested Zigbee adaptater model. If this is a Sonoff USB Dongle E that is known issue, otherwise please report to the Zigbee for Domoticz team
2023-11-04 14:27:34.973 Status: ZIGBEE: [ZigpyForwarder_9 487] Installer Version Number: 6.10.3.0 build 297
2023-11-04 14:27:34.974 Status: ZIGBEE: [ZigpyForwarder_9 487] Branch Version: ==> Unknown Silicon Labs <==
2023-11-04 14:27:34.979 Status: ZIGBEE: [ZigpyForwarder_9 487] Zigbee Coordinator ieee: e0798dfffec7b71b , short addr: 0000
2023-11-04 14:27:34.981 Status: ZIGBEE: [ZigpyForwarder_9 487] Network state UP, PANID: cf51 extPANID: 0x6061e1218bc4e79f Channel: 25
2023-11-04 14:27:35.495 Status: ZIGBEE: [ MainThread 464] Domoticz Widgets usage is at 1.2 % (252 units free)
2023-11-04 14:27:44.062 Status: ZIGBEE: [ MainThread 464] Request Disabling Accepting new Hardware
2023-11-04 14:27:44.112 ZIGBEE: Zigate Thread Serial Read Max: 33 ms with an of average: 16 ms
2023-11-04 14:27:49.085 Status: ZIGBEE: [ MainThread 464] coordinator set to Certification : 1/CE -> CE
2023-11-04 14:27:49.138 ZIGBEE: Zigate Thread Serial Read Max: 33 ms with an of average: 11 ms
2023-11-04 14:27:49.139 ZIGBEE: Zigate Thread Serial Read Max: 33 ms with an of average: 8 ms
2023-11-04 14:27:50.869 Status: ZIGBEE: [ MainThread 464] ota_scan_folder Following Firmware have been loaded
2023-11-04 14:27:50.872 Status: ZIGBEE: [ MainThread 464] Plugin with Zigpy, Coordinator Unknown Silicon Labs firmware UNK - 6.10.3.0 build 297 correctly initialized
2023-11-04 14:28:45.419 Status: [web:8080] Incoming connection from: 192.168.20.139
2023-11-04 14:28:45.424 Status: [web:8080] Incoming connection from: 192.168.20.139
2023-11-04 14:29:07.734 ZIGBEE: URL INFOS {'type': 'command', 'param': 'updatehardware', 'htype': '94', 'idx': 9, 'name': 'ZIGBEE', 'address': '0.0.0.0', 'port': '9999', 'serialport': '/dev/ttyACM0', 'Mode1': 'ZigpyEZSP', 'Mode2': 'USB', 'Mode3': 'False', 'Mode4': '9440', 'Mode5': 'http://127.0.0.1:8080', 'Mode6': '-1', 'extra': 'Zigate', 'enabled': 'true', 'datatimeout': '0', 'loglevel': 7}
2023-11-04 14:29:07.736 Status: ZIGBEE: Plugin Restart command : http://127.0.0.1:8080/json.htm?type=command¶m=updatehardware&htype=94&idx=9&name=ZIGBEE&address=0.0.0.0&port=9999&serialport=%2Fdev%2FttyACM0&Mode1=ZigpyEZSP&Mode2=USB&Mode3=False&Mode4=9440&Mode5=http%3A%2F%2F127.0.0.1%3A8080&Mode6=-1&extra=Zigate&enabled=true&datatimeout=0&loglevel=7
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
2023-11-04 14:29:07.812 Status: ZIGBEE: Stop directive received.
2023-11-04 14:29:07.816 ZIGBEE: onStop()
2023-11-04 14:29:07.828 Status: ZIGBEE: [ MainThread 464] Shuting down co-routine
2023-11-04 14:29:07.830 Status: ZIGBEE: [ZigpyForwarder_9 487] ZigpyTransport: thread_processing_and_sending Thread stop.
2023-11-04 14:29:14.975 Status: ZIGBEE: [ ZigpyCom_9 486] Coordinator backup is available: /opt/domoticz/userdata/plugins/Domoticz-Zigbee/Data/Coordinator-09.backup
2023-11-04 14:29:16.986 Status: ZIGBEE: Statistics on message
2023-11-04 14:29:16.986 Status: ZIGBEE: PDM load(s) : 0
2023-11-04 14:29:16.986 Status: ZIGBEE: ZiGate reacting time
2023-11-04 14:29:16.986 Status: ZIGBEE: Max : 0 sec
2023-11-04 14:29:16.986 Status: ZIGBEE: Average : 0 sec
2023-11-04 14:29:16.986 Status: ZIGBEE: ZiGate processing time on Rx
2023-11-04 14:29:16.986 Status: ZIGBEE: Max : 10 sec
2023-11-04 14:29:16.986 Status: ZIGBEE: Average : 1 sec
2023-11-04 14:29:16.986 Status: ZIGBEE: Sent:
2023-11-04 14:29:16.986 Status: ZIGBEE: TX commands : 1
2023-11-04 14:29:16.986 Status: ZIGBEE: Max Load (Queue) : 1
2023-11-04 14:29:16.986 Status: ZIGBEE: Max aPDU (Queue) : 0
2023-11-04 14:29:16.986 Status: ZIGBEE: Max nPDU (Queue) : 0
2023-11-04 14:29:16.986 Status: ZIGBEE: TX failed : 0 (0.0%)
2023-11-04 14:29:16.986 Status: ZIGBEE: TX timeout : 0 (0.0%)
2023-11-04 14:29:16.986 Status: ZIGBEE: TX data timeout : 0 (0.0%)
2023-11-04 14:29:16.986 Status: ZIGBEE: TX reTransmit : 0 (0.0%)
2023-11-04 14:29:16.986 Status: ZIGBEE: TX APS Failure : 0 (0.0%)
2023-11-04 14:29:16.986 Status: ZIGBEE: TX APS Ack : 0 (0.0%)
2023-11-04 14:29:16.986 Status: ZIGBEE: TX APS Nck : 0 (0.0%)
2023-11-04 14:29:16.986 Status: ZIGBEE: Received:
2023-11-04 14:29:16.986 Status: ZIGBEE: RX frame : 11
2023-11-04 14:29:16.987 Status: ZIGBEE: RX crc errors : 0 (0.0%)
2023-11-04 14:29:16.987 Status: ZIGBEE: RX lentgh errors : 0 (0.0%)
2023-11-04 14:29:16.987 Status: ZIGBEE: RX clusters : 0
2023-11-04 14:29:16.987 Status: ZIGBEE: RX clusters KO : 0
2023-11-04 14:29:16.987 Status: ZIGBEE: Operating time : 0 Hours 1 Mins 46 Secs
2023-11-04 14:29:16.992 ZIGBEE: logging_thread - ended
2023-11-04 14:29:16.997 ZIGBEE: Logging Thread shutdown
2023-11-04 14:29:16.997 ZIGBEE: onStop called (6) Close Logging Management
2023-11-04 14:29:17.277 Status: ZIGBEE: Exiting work loop.
2023-11-04 14:29:17.321 Status: ZIGBEE: Stopping threads.
2023-11-04 14:29:17.321 Status: ZIGBEE: Stopped.
2023-11-04 14:29:17.321 Status: ZIGBEE: Entering work loop.
2023-11-04 14:29:17.322 ZIGBEE: Worker thread started.
2023-11-04 14:29:17.322 Status: ZIGBEE: Started.
100 50 100 50 0 0 5 0 0:00:10 0:00:09 0:00:01 15
"status" : "OK",
"title" : "UpdateHardware"
2023-11-04 14:29:18.278 Status: ZIGBEE: Initialized version 7.1, author 'pipiche38'
2023-11-04 14:29:18.280 Status: ZIGBEE: Zigbee for Domoticz plugin starting
2023-11-04 14:29:18.280 Status: ZIGBEE: Z4D plugin requires python3 3.8 or above and you are running 3.9
2023-11-04 14:29:18.280 Status: ZIGBEE: Checking Python modules /opt/domoticz/userdata/plugins/Domoticz-Zigbee/requirements.txt
2023-11-04 14:29:19.133 ZIGBEE: load PluginConf
2023-11-04 14:29:19.135 ZIGBEE: Loading PluginConf - from Domoticz sqlite Db
2023-11-04 14:29:19.135 ZIGBEE: /opt/domoticz/userdata/plugins/Domoticz-Zigbee/Conf/PluginConf-09.json timestamp is 1699103604.0943222
2023-11-04 14:29:19.135 ZIGBEE: Dz PluginConf is older than Json Dz: 0 Json: 1699103604.0943222
2023-11-04 14:29:19.137 Status: ZIGBEE: PluginAnalytics set to 1
2023-11-04 14:29:19.137 Status: ZIGBEE: Livolo set to 1
2023-11-04 14:29:19.137 Status: ZIGBEE: Orvibo set to 1
2023-11-04 14:29:19.137 Status: ZIGBEE: channel set to 25
2023-11-04 14:29:19.137 Status: ZIGBEE: filename set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee/Conf/PluginConf-09.json
2023-11-04 14:29:19.137 Status: ZIGBEE: pluginHome set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee
2023-11-04 14:29:19.137 Status: ZIGBEE: homedirectory set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee
2023-11-04 14:29:19.137 Status: ZIGBEE: pluginData set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee/Data
2023-11-04 14:29:19.137 Status: ZIGBEE: pluginConfig set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee/Conf
2023-11-04 14:29:19.137 Status: ZIGBEE: pluginOTAFirmware set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee/OTAFirmware
2023-11-04 14:29:19.137 Status: ZIGBEE: pluginReports set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee/Reports
2023-11-04 14:29:19.137 Status: ZIGBEE: pluginWWW set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee/www
2023-11-04 14:29:19.137 Status: ZIGBEE: pluginLogs set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee/Logs
2023-11-04 14:29:19.137 Status: ZIGBEE: trackZclClustersIn set to 1
2023-11-04 14:29:19.137 Status: ZIGBEE: trackZclClustersOut set to 1
2023-11-04 14:29:19.137 Status: ZIGBEE: trackZdpClustersIn set to 1
2023-11-04 14:29:19.137 Status: ZIGBEE: trackZdpClustersOut set to 1
2023-11-04 14:29:19.137 Status: ZIGBEE: logThreadName set to 1
2023-11-04 14:29:19.137 Status: ZIGBEE: trackTransportError set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: ZiGateReactTime set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: showTimeOutMsg set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: coordinatorCmd set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: z4dCertifiedDevices set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: Input set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: ZclClusters set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: DeviceAnnoucement set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: BasicOutput set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: Binding set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: ConfigureReporting set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: WriteAttributes set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: ReadAttributes set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: Thermostats set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: Transport set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: Transport8000 set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: Transport8002 set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: Transport8011 set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: TransportWrter set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: TransportFrwder set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: TransportRder set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: TransportProto set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: TransportTcpip set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: TransportSerial set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: TransportZigpy set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: TransportError set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: Zigpy set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: ZigpyZigate set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: ZigpyZNP set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: ZigpydeCONZ set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: ZigpyEZSP set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: TransportPluginEncoder set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: Cluster set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: Heartbeat set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: Widget set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: WidgetCreation set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: Plugin set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: Database set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: Command set to 1
2023-11-04 14:29:19.138 Status: ZIGBEE: Pairing set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: NetworkMap set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: NetworkEnergy set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: Groups set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: OTA set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: IAS set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: DZDB set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: WebServer set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: Ikea set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: Legrand set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: Lumi set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: Heiman set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: Livolo set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: Tuya0601 set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: AbstractDz set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: CasaIA set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: Enki set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: Orvibo set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: Pluzzy set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: PollControl set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: PluginTools set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: PDM set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: inRawAPS set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: outRawAPS set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: zdpCommand set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: zclCommand set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: zdpDecoder set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: zclDecoder set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: zigateCommand set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: ThreadForwarder set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: ThreadDomoticz set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: ThreadWriter set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: ThreadCommunication set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: ZLinky set to 1
2023-11-04 14:29:19.139 Status: ZIGBEE: ControllerInRawMode set to True
2023-11-04 14:29:19.139 Status: ZIGBEE: expJsonDatabase set to 0
2023-11-04 14:29:19.140 ZIGBEE: Installing plugin custom page /opt/domoticz/www/templates/ZIGBEE.html
2023-11-04 14:29:19.140 ZIGBEE: Starting LoggingManagement thread
2023-11-04 14:29:19.140 ZIGBEE: zigpy_login_mode(30)
2023-11-04 14:29:19.142 ZIGBEE: zigpy_login_mode(10)
2023-11-04 14:29:19.143 ZIGBEE: start_logging_thread
2023-11-04 14:29:19.147 ZIGBEE: logging_thread - listening
2023-11-04 14:29:19.147 Status: ZIGBEE: Please watch plugin log into /opt/domoticz/userdata/plugins/Domoticz-Zigbee/Logs/PluginZigbee_09.log
2023-11-04 14:29:19.156 Status: ZIGBEE: [ MainThread 522] Zigbee for Domoticz (z4d) plugin stable7-7.1.004 started
2023-11-04 14:29:19.189 Status: ZIGBEE: [ MainThread 522] Loading ZCL Cluster definitions
2023-11-04 14:29:19.190 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0000 - (V1) Basic loaded
2023-11-04 14:29:19.192 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0001 - (V1) Power loaded
2023-11-04 14:29:19.193 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0002 - (V1) Device Temperature Configuration loaded
2023-11-04 14:29:19.195 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0003 - (V1) Identify loaded
2023-11-04 14:29:19.196 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0004 - (V1) Groups loaded
2023-11-04 14:29:19.197 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0005 - (V1) Scenes loaded
2023-11-04 14:29:19.199 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0006 - (V1) On/Off loaded
2023-11-04 14:29:19.200 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0007 - (V1) On/Off Switch Configuration loaded
2023-11-04 14:29:19.202 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0008 - (V1) Level loaded
2023-11-04 14:29:19.203 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0009 - (V1) Alarms loaded
2023-11-04 14:29:19.205 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 000a - (V1) Time loaded
2023-11-04 14:29:19.206 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 000d - (V1) Analog Output loaded
2023-11-04 14:29:19.208 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 000f - (V1) Binary Input loaded
2023-11-04 14:29:19.209 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0013 - (V1) Multistate Output loaded
2023-11-04 14:29:19.211 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0019 - (V1) OTA Upgrade loaded
2023-11-04 14:29:19.212 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0020 - (V1) Poll Control loaded
2023-11-04 14:29:19.214 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0102 - (V1) Window Covering loaded
2023-11-04 14:29:19.215 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0202 - (V1) Fan Control loaded
2023-11-04 14:29:19.216 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0204 - (V1) Thermostat User Interface Configuration loaded
2023-11-04 14:29:19.218 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0300 - (V1) Color Control loaded
2023-11-04 14:29:19.219 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0301 - (V1) Ballast Configuration loaded
2023-11-04 14:29:19.221 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0400 - (V1) Illuminance Level Sensing loaded
2023-11-04 14:29:19.222 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0402 - (V1) Temperature Measurement loaded
2023-11-04 14:29:19.223 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0403 - (V1) Pressure Measurement loaded
2023-11-04 14:29:19.225 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0405 - (V1) Relative Humidity Measurement loaded
2023-11-04 14:29:19.226 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0406 - (V1) Occupancy Sensing loaded
2023-11-04 14:29:19.229 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0700 - (V1) Price loaded
2023-11-04 14:29:19.231 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0702 - (V1) Metering (Smart Energy) loaded
2023-11-04 14:29:19.233 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0b01 - (V1) Meter Identification loaded
2023-11-04 14:29:19.234 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0b04 - (V1) Electrical Measurement loaded
2023-11-04 14:29:19.236 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster 0b05 - (V1) Diagnostics loaded
2023-11-04 14:29:19.238 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster e000 - (V1) Tuya E000 Private Cluster loaded
2023-11-04 14:29:19.239 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster e001 - (V1) Tuya E001 Private Cluster loaded
2023-11-04 14:29:19.240 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster e002 - (V1) Tuya E002 Private Cluster loaded
2023-11-04 14:29:19.242 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster fcc0 - (V1) LUMI Private Cluster loaded
2023-11-04 14:29:19.243 Status: ZIGBEE: [ MainThread 522] - ZCL Cluster ff66 - (V1) Lixee Zlinky private cluster loaded
2023-11-04 14:29:19.247 Status: ZIGBEE: [ MainThread 522] DeviceConf loaded - 16 confs loaded
2023-11-04 14:29:19.255 Status: ZIGBEE: [ MainThread 522] Local-Device conf loaded - 21 confs loaded
2023-11-04 14:29:19.742 Status: ZIGBEE: [ MainThread 522] Certified Devices loaded - 518 confs loaded
2023-11-04 14:29:19.744 Status: ZIGBEE: [ MainThread 522] load ListOfDevice
2023-11-04 14:29:19.747 Status: ZIGBEE: [ MainThread 522] 1 Entries loaded from /opt/domoticz/userdata/plugins/Domoticz-Zigbee/Data/DeviceList-9.txt
2023-11-04 14:29:19.756 Status: ZIGBEE: [ MainThread 522] Transport mode: ZigpyEZSP
context.c:56: warning: mpd_setminalloc: ignoring request to set MPD_MINALLOC a second time
2023-11-04 14:29:20.751 Status: ZIGBEE: [ MainThread 522] Start Zigpy Transport on EZSP
2023-11-04 14:29:20.766 Status: ZIGBEE: [ZigpyForwarder_9 525] ZigpyTransport: thread_processing_and_sending Thread start.
2023-11-04 14:29:20.771 Status: ZIGBEE: [ MainThread 522] Start Web Server connection
2023-11-04 14:29:20.782 Status: ZIGBEE: [ MainThread 522] Web backend for Web User Interface started on port: 9440
2023-11-04 14:29:20.912 Status: ZIGBEE: [ MainThread 522] Plugin looks to upgrade the Certified Device package
2023-11-04 14:29:21.330 Status: ZIGBEE: [ ZigpyCom_9 524] Started radio ezsp port: /dev/ttyACM0
2023-11-04 14:29:22.737 Status: ZIGBEE: [ ZigpyCom_9 524] Bellows Radio register default Ep
2023-11-04 14:29:23.158 ZIGBEE: Zigate receive message processing time Max: 1 ms with an of average: 1 ms
2023-11-04 14:29:23.450 Status: ZIGBEE: [ZigpyForwarder_9 525] Number of devices recently active in Coordinator = 0
2023-11-04 14:29:23.491 ZIGBEE: Zigate Thread Serial Read Max: 1 ms with an of average: 1 ms
2023-11-04 14:29:23.493 Status: ZIGBEE: [ ZigpyCom_9 524] EZSP Radio manufacturer:
2023-11-04 14:29:23.497 Status: ZIGBEE: [ ZigpyCom_9 524] EZSP Radio board name:
2023-11-04 14:29:23.501 Status: ZIGBEE: [ ZigpyCom_9 524] EmberZNet version: 6.10.3.0 build 297
2023-11-04 14:29:23.508 Status: ZIGBEE: [ ZigpyCom_9 524] Network settings
2023-11-04 14:29:23.511 Status: ZIGBEE: [ ZigpyCom_9 524] Device IEEE: e0:79:8d:ff:fe:c7:b7:1b
2023-11-04 14:29:23.513 ZIGBEE: Zigate receive message processing time Max: 16 ms with an of average: 2 ms
2023-11-04 14:29:23.517 Status: ZIGBEE: [ ZigpyCom_9 524] Device NWK: 0x0000
2023-11-04 14:29:23.519 Status: ZIGBEE: [ ZigpyCom_9 524] Network Update Id: 0x0000
2023-11-04 14:29:23.521 Status: ZIGBEE: [ ZigpyCom_9 524] PAN ID: 0xCF51
2023-11-04 14:29:23.522 Status: ZIGBEE: [ ZigpyCom_9 524] Extended PAN ID: 60:61:e1:21:8b:c4:e7:9f
2023-11-04 14:29:23.525 Status: ZIGBEE: [ ZigpyCom_9 524] Channel: 25
2023-11-04 14:29:23.560 Status: ZIGBEE: [ZigpyForwarder_9 525] Untested Zigbee adaptater model. If this is a Sonoff USB Dongle E that is known issue, otherwise please report to the Zigbee for Domoticz team
2023-11-04 14:29:23.562 Status: ZIGBEE: [ZigpyForwarder_9 525] Installer Version Number: 6.10.3.0 build 297
2023-11-04 14:29:23.564 Status: ZIGBEE: [ZigpyForwarder_9 525] Branch Version: ==> Unknown Silicon Labs <==
2023-11-04 14:29:23.585 Status: ZIGBEE: [ZigpyForwarder_9 525] Zigbee Coordinator ieee: e0798dfffec7b71b , short addr: 0000
2023-11-04 14:29:23.588 Status: ZIGBEE: [ZigpyForwarder_9 525] Network state UP, PANID: cf51 extPANID: 0x6061e1218bc4e79f Channel: 25
2023-11-04 14:29:23.641 Status: ZIGBEE: [ MainThread 522] Domoticz Widgets usage is at 1.2 % (252 units free)
Pour ce faire j ai ajouter:
cryptography==40.0.2
Dans requirement
et sudo python3 pip install cryptography==40.0.2 --upgrade dans le customstart.sh de docker
023-11-04 14:49:05.352 Status: ZIGBEE: [ MainThread 593] Request Accepting new Hardware for 240 seconds
2023-11-04 14:49:05.479 ZIGBEE: Zigate Thread Serial Read Max: 48 ms with an of average: 22 ms
pas de pairing
Dans les fait si ce dongle n'est pas compatible my bad mais pouvez vous m indiquer une clé zigbee compatible domoticz ? Zigate sucks , au pire je recommande un clé Zigate, mais toutes la regulation du chauffage est basé sur cela et avant l hivers j ai besoin d une solution.
Tu fais comme tu veux mais modifier le requirements.txt est une mauvaise idée
La clef est-elle Connectée via une rallonge usb ? Si non, alors mets une rallonge.
Si c’est un Pi4, ne pas utiliser les ports Usb3
