Je fais une nouvelle installation domoticz sur un RPi3 bookworm 32bits
J'ai déjà installé Mosquitto, zigbee2MQTT et l'installation de domoticz bloque !!!
Il y a toujours le problème qu'il faut passer en SU pour pouvoir installer mais mon souci est après.
Quand tout est terminé je tombe sur cela :
root@PhilDom:/home/pi# curl -L install.domoticz.com | bash
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 16889 0 16889 0 0 22719 0 --:--:-- --:--:-- --:--:-- 22719
::: You are root.
::: Verifying free disk space...
::: Checking apt-get for upgraded packages.... done!
::: Your system is up to date! Continuing with Domoticz installation...
::: Checking for apt-utils... installed!
::: Checking for whiptail... installed!
::: Checking for git... installed!
::: Checking for curl... installed!
::: Checking for unzip... installed!
::: Checking for wget... installed!
::: Checking for sudo... installed!
::: Checking for cron... installed!
::: Checking for libudev-dev... installed!
::: Checking for libssl1.1... installed!
::: Checking for libcurl4... installed!
::: Checking for libusb-0.1... installed!
::: Downloading Domoticz
::: Current User: pi
HTTP Port: 80
HTTPS Port: 443
::: Destination folder=/home/pi/domoticz
--2025-09-02 15:45:36-- http://www.domoticz.com/download.php?channel=release&type=release&system=linux&machine=armv7l
Résolution de www.domoticz.com (www.domoticz.com)… 2606:4700:3030::6815:4001, 2606:4700:3030::6815:2001, 2606:4700:3030::6815:3001, ...
Connexion à www.domoticz.com (www.domoticz.com)|2606:4700:3030::6815:4001|:80… connecté.
requête HTTP transmise, en attente de la réponse… 301 Moved Permanently
Emplacement : https://www.domoticz.com/download.php?channel=release&type=release&system=linux&machine=armv7l [suivant]
--2025-09-02 15:45:36-- https://www.domoticz.com/download.php?channel=release&type=release&system=linux&machine=armv7l
Connexion à www.domoticz.com (www.domoticz.com)|2606:4700:3030::6815:4001|:443… connecté.
requête HTTP transmise, en attente de la réponse… 403 Forbidden
2025-09-02 15:45:37 erreur 403 : Forbidden.Où est le souci ???
Un peu d'aide serait la bienvenue
Merci par avance.
