#!/bin/bash
cd /home/pi/freebox
# Domoticz server
DOMOTICZ_SERVER="192.168.0.16:8080"
# Freebox Server idx
FREEBOX_FW_IDX="87"
FREEBOX_UPTIME_IDX="88"
FREEBOX_UP_MAX_IDX="89"
FREEBOX_DOWN_MAX_IDX="90"
FREEBOX_DISKSPACE_IDX="91"
# Password admin domoticz à modifier
pwd=toto
function show_time () {
num=$1
min=0
hour=0
day=0
if((num>59));then
((sec=num%60))
((num=num/60))
if((num>59));then
((min=num%60))
((num=num/60))
if((num>23));then
((hour=num%24))
((day=num/24))
((hour=num))
fi
((min=num))
fi
((sec=num))
fi
echo "$day"%20jours%20"$hour"%20heures%20"$min"%20mn%20"$sec"%20secs
MY_APP_ID="Domoticz.app"
MY_APP_TOKEN="U+u/UZppnIMOa4JdXZRo8PWgg5ATX5F3iBCa/AMgLTQuermsisDoV0FES3UqkaT0"
# source the freeboxos-bash-api
source ./freeboxos_bash_api.sh
# login
login_freebox "$MY_APP_ID" "$MY_APP_TOKEN"
# get xDSL data
answer=$(call_freebox_api '/connection/xdsl')
#echo " answer : ${answer} "
#echo " "
# extract max upload xDSL rate
up_max_rate=$(get_json_value_for_key "$answer" 'result.up.maxrate')%20kb/s
down_max_rate=$(get_json_value_for_key "$answer" 'result.down.maxrate')%20kb/s
uptime=$(get_json_value_for_key "$answer" 'result.status.uptime')
uptimefreebox=$(show_time ${uptime})
echo "Uptime : ${uptimefreebox} "
echo "Max Upload xDSL rate: ${up_max_rate} "
echo "Max Download xDSL rate: ${down_max_rate} "
answer=$(call_freebox_api '/system')
#uptimefreebox=$(get_json_value_for_key "$answer" 'result.uptime')
fwfreebox=$(get_json_value_for_key "$answer" 'result.firmware_version')
#echo "Uptime : ${uptimefreebox} "
echo "Firmware : ${fwfreebox} "
answer=$(call_freebox_api '/storage/disk')
answer=$(echo ${answer} | sed -e "s/\[//g" | sed -e "s/\]//g")
freediskspace=$(get_json_value_for_key "$answer" 'result.partitions.free_bytes')
freediskspace=$(echo $((${freediskspace}/1024/1024)))
freediskspace=$(echo "${freediskspace}%20MBytes")
echo "Free space HD : ${freediskspace} "
#Envoi des valeurs vers les devices virtuels
# Send data to Domoticz
curl --silent -s -i -H "Accept: application/json" "http://admin:toto@$DOMOTICZ_SERVER/json.htm?type=command¶m=udevice&idx=$FREEBOX_FW_IDX&nvalue=0&svalue=$fwfreebox"
curl --silent -s -i -H "Accept: application/json" "http://admin:toto@$DOMOTICZ_SERVER/json.htm?type=command¶m=udevice&idx=88&nvalue=0&svalue=$uptimefreebox"
curl --silent -s -i -H "Accept: application/json" "http://admin:toto@$DOMOTICZ_SERVER/json.htm?type=command¶m=udevice&idx=89&nvalue=0&svalue=$up_max_rate"
curl --silent -s -i -H "Accept: application/json" "http://admin:toto@$DOMOTICZ_SERVER/json.htm?type=command¶m=udevice&idx=90&nvalue=0&svalue=$down_max_rate"
curl --silent -s -i -H "Accept: application/json" "http://admin:toto@$DOMOTICZ_SERVER/json.htm?type=command¶m=udevice&idx=91&nvalue=0&svalue=$freediskspace"
