Dsl pour la réponse tardive.
Oui je les avais bien activé.
Ce qui ne vas pas c'est que quand je modifie le set point avec Domoticz la vanne reste fermée en permanence.
Peu importe si je mets un setpoint de 28 et que la température est de 22 elle resté fermée.
Par contre si je modifie le setpoint avec la molette, la vanne s'ouvre.
Voici quelques logs. J'espère que cette fois ci la partie schneider soit visible.
2021-11-15 22:44:01.135 Zigate: (Zigate) schneider_find_attribute_or_set NWKID:7948, EP:01, ClusterID:0201, attr:0012 ,defaultValue:2100, newValue:2100
2021-11-15 22:44:01.136 Zigate: (Zigate) schneider_find_attribute_or_set : found value 2750
2021-11-15 22:44:01.136 Zigate: (Zigate) schneider_find_attribute_or_set : setting new value 2100
2021-11-15 22:44:01.139 Zigate: (Zigate) importSchneiderZoning - Nothing to import from /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/schneider_zoning.json
2021-11-15 22:44:01.139 Zigate: (Zigate) schneider_thermostat_check_and_bind : 7948
2021-11-15 22:44:01.141 Zigate: (Zigate) importSchneiderZoning - Nothing to import from /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/schneider_zoning.json
2021-11-15 22:44:01.169 Zigate: (Zigate) UpdateDevice - (Zigate - iTRV_ThermoSetpoint) 0:21.00
2021-11-15 22:44:05.784 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 1a, MsgCRC: ff, Data: aa72e70b020400010020000100, LQI: 72
2021-11-15 22:44:05.784 Zigate: (Zigate) Decode8102 - Attribute Reports: [72e7:0b] MsgSQN: aa ClusterID: 0204 AttributeID: 0001 Status: 00 Type: 20 Size: 0001 ClusterData: >00<
2021-11-15 22:44:05.784 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [72e7:0b] ClusterID: 0204 MsgSQN: aa, i_sqn: None, AttributeID: 0001 Status: 00 Type: 20 Size: 0001 ClusterData: >00<
2021-11-15 22:44:05.791 Zigate: (Zigate) ReadCluster - 0204 - 72e7/0b AttrId: 0001 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 00
2021-11-15 22:44:05.791 Zigate: (Zigate) ReadCluster 0204 - Addr: 72e7 Ep: 0b AttrId: 0001 AttrType: 20 AttSize: 0001 Data: 00
2021-11-15 22:44:05.792 Zigate: (Zigate) ReadCluster 0204 - Lock Mode: 0
2021-11-15 22:44:05.836 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: 2a, Data: ab72e70b0201e0300020000128, LQI: 72
2021-11-15 22:44:05.837 Zigate: (Zigate) Decode8102 - Attribute Reports: [72e7:0b] MsgSQN: ab ClusterID: 0201 AttributeID: e030 Status: 00 Type: 20 Size: 0001 ClusterData: >28<
2021-11-15 22:44:05.837 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [72e7:0b] ClusterID: 0201 MsgSQN: ab, i_sqn: None, AttributeID: e030 Status: 00 Type: 20 Size: 0001 ClusterData: >28<
2021-11-15 22:44:05.846 Zigate: (Zigate) ReadCluster - 0201 - 72e7/0b AttrId: e030 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 28
2021-11-15 22:44:05.846 Zigate: (Zigate) ReadCluster - 0201 - 72e7/0b AttrId: e030 AttrType: 20 AttSize: 0001 Data: 28
2021-11-15 22:44:05.846 Zigate: (Zigate) readCluster - 0201 - 72e7/0b Schneider Valve Position 28
2021-11-15 22:44:05.854 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: 15, Data: ac72e70b0201e0310030000101, LQI: 72
2021-11-15 22:44:05.854 Zigate: (Zigate) Decode8102 - Attribute Reports: [72e7:0b] MsgSQN: ac ClusterID: 0201 AttributeID: e031 Status: 00 Type: 30 Size: 0001 ClusterData: >01<
2021-11-15 22:44:05.854 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [72e7:0b] ClusterID: 0201 MsgSQN: ac, i_sqn: None, AttributeID: e031 Status: 00 Type: 30 Size: 0001 ClusterData: >01<
2021-11-15 22:44:05.860 Zigate: (Zigate) ReadCluster - 0201 - 72e7/0b AttrId: e031 AttrType: 30 Attsize: 0001 Status: 00 AttrValue: 01
2021-11-15 22:44:05.860 Zigate: (Zigate) ReadCluster - 0201 - 72e7/0b AttrId: e031 AttrType: 30 AttSize: 0001 Data: 01
2021-11-15 22:44:05.861 Zigate: (Zigate) readCluster - 0201 - 72e7/0b Schneider Valve Calibration Status 01
2021-11-15 22:44:05.891 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 4f, Data: ad72e70b02010000002900020898, LQI: 72
2021-11-15 22:44:05.891 Zigate: (Zigate) Decode8102 - Attribute Reports: [72e7:0b] MsgSQN: ad ClusterID: 0201 AttributeID: 0000 Status: 00 Type: 29 Size: 0002 ClusterData: >0898<
2021-11-15 22:44:05.891 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 28 Read Attribute Response: [72e7:0b] ClusterID: 0201 MsgSQN: ad, i_sqn: None, AttributeID: 0000 Status: 00 Type: 29 Size: 0002 ClusterData: >0898<
2021-11-15 22:44:05.900 Zigate: (Zigate) ReadCluster - 0201 - 72e7/0b AttrId: 0000 AttrType: 29 Attsize: 0002 Status: 00 AttrValue: 0898
2021-11-15 22:44:05.902 Zigate: (Zigate) ReadCluster - 0201 - 72e7/0b AttrId: 0000 AttrType: 29 AttSize: 0002 Data: 0898
2021-11-15 22:44:05.909 Zigate: (Zigate) ReadCluster - 0201 - Local Temp: 22.0
2021-11-15 22:44:05.910 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: 35, Data: ae72e70b0201e0120030000100, LQI: 72
2021-11-15 22:44:05.911 Zigate: (Zigate) Decode8102 - Attribute Reports: [72e7:0b] MsgSQN: ae ClusterID: 0201 AttributeID: e012 Status: 00 Type: 30 Size: 0001 ClusterData: >00<
2021-11-15 22:44:05.911 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [72e7:0b] ClusterID: 0201 MsgSQN: ae, i_sqn: None, AttributeID: e012 Status: 00 Type: 30 Size: 0001 ClusterData: >00<
2021-11-15 22:44:05.920 Zigate: (Zigate) ReadCluster - 0201 - 72e7/0b AttrId: e012 AttrType: 30 Attsize: 0001 Status: 00 AttrValue: 00
2021-11-15 22:44:05.920 Zigate: (Zigate) ReadCluster - 0201 - 72e7/0b AttrId: e012 AttrType: 30 AttSize: 0001 Data: 00
2021-11-15 22:44:05.920 Zigate: (Zigate) readCluster - 0201 - 72e7/0b Schneider ATTRIBUTE_THERMOSTAT_OPEN_WINDOW_DETECTION_STATUS 00
2021-11-15 22:44:05.996 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: 0f, Data: 0677a80b0201e0120030000100, LQI: 144
2021-11-15 22:44:05.996 Zigate: (Zigate) Decode8102 - Attribute Reports: [77a8:0b] MsgSQN: 06 ClusterID: 0201 AttributeID: e012 Status: 00 Type: 30 Size: 0001 ClusterData: >00<
2021-11-15 22:44:05.996 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [77a8:0b] ClusterID: 0201 MsgSQN: 06, i_sqn: 18, AttributeID: e012 Status: 00 Type: 30 Size: 0001 ClusterData: >00<
2021-11-15 22:44:06.006 Zigate: (Zigate) ReadCluster - 0201 - 77a8/0b AttrId: e012 AttrType: 30 Attsize: 0001 Status: 00 AttrValue: 00
2021-11-15 22:44:06.006 Zigate: (Zigate) ReadCluster - 0201 - 77a8/0b AttrId: e012 AttrType: 30 AttSize: 0001 Data: 00
2021-11-15 22:44:06.007 Zigate: (Zigate) readCluster - 0201 - 77a8/0b Schneider ATTRIBUTE_THERMOSTAT_OPEN_WINDOW_DETECTION_STATUS 00
2021-11-15 22:44:06.050 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: 32, Data: 0777a80b0201e030002000010d, LQI: 147
2021-11-15 22:44:06.050 Zigate: (Zigate) Decode8102 - Attribute Reports: [77a8:0b] MsgSQN: 07 ClusterID: 0201 AttributeID: e030 Status: 00 Type: 20 Size: 0001 ClusterData: >0d<
2021-11-15 22:44:06.050 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [77a8:0b] ClusterID: 0201 MsgSQN: 07, i_sqn: 19, AttributeID: e030 Status: 00 Type: 20 Size: 0001 ClusterData: >0d<
2021-11-15 22:44:06.060 Zigate: (Zigate) ReadCluster - 0201 - 77a8/0b AttrId: e030 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 0d
2021-11-15 22:44:06.061 Zigate: (Zigate) ReadCluster - 0201 - 77a8/0b AttrId: e030 AttrType: 20 AttSize: 0001 Data: 0d
2021-11-15 22:44:06.061 Zigate: (Zigate) readCluster - 0201 - 77a8/0b Schneider Valve Position 0d
2021-11-15 22:44:06.067 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 1a, MsgCRC: ff, Data: 0877a80b020400010020000100, LQI: 144
2021-11-15 22:44:06.067 Zigate: (Zigate) Decode8102 - Attribute Reports: [77a8:0b] MsgSQN: 08 ClusterID: 0204 AttributeID: 0001 Status: 00 Type: 20 Size: 0001 ClusterData: >00<
2021-11-15 22:44:06.068 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [77a8:0b] ClusterID: 0204 MsgSQN: 08, i_sqn: 20, AttributeID: 0001 Status: 00 Type: 20 Size: 0001 ClusterData: >00<
2021-11-15 22:44:06.074 Zigate: (Zigate) ReadCluster - 0204 - 77a8/0b AttrId: 0001 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 00
2021-11-15 22:44:06.074 Zigate: (Zigate) ReadCluster 0204 - Addr: 77a8 Ep: 0b AttrId: 0001 AttrType: 20 AttSize: 0001 Data: 00
2021-11-15 22:44:06.074 Zigate: (Zigate) ReadCluster 0204 - Lock Mode: 0
2021-11-15 22:44:06.102 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 2b, Data: 0977a80b020100000029000208ca, LQI: 144
2021-11-15 22:44:06.103 Zigate: (Zigate) Decode8102 - Attribute Reports: [77a8:0b] MsgSQN: 09 ClusterID: 0201 AttributeID: 0000 Status: 00 Type: 29 Size: 0002 ClusterData: >08ca<
2021-11-15 22:44:06.103 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 28 Read Attribute Response: [77a8:0b] ClusterID: 0201 MsgSQN: 09, i_sqn: 22, AttributeID: 0000 Status: 00 Type: 29 Size: 0002 ClusterData: >08ca<
2021-11-15 22:44:06.111 Zigate: (Zigate) ReadCluster - 0201 - 77a8/0b AttrId: 0000 AttrType: 29 Attsize: 0002 Status: 00 AttrValue: 08ca
2021-11-15 22:44:06.112 Zigate: (Zigate) ReadCluster - 0201 - 77a8/0b AttrId: 0000 AttrType: 29 AttSize: 0002 Data: 08ca
2021-11-15 22:44:06.116 Zigate: (Zigate) ReadCluster - 0201 - Local Temp: 22.5
2021-11-15 22:44:06.155 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: 23, Data: 0a77a80b0201e0310030000103, LQI: 144
2021-11-15 22:44:06.155 Zigate: (Zigate) Decode8102 - Attribute Reports: [77a8:0b] MsgSQN: 0a ClusterID: 0201 AttributeID: e031 Status: 00 Type: 30 Size: 0001 ClusterData: >03<
2021-11-15 22:44:06.156 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [77a8:0b] ClusterID: 0201 MsgSQN: 0a, i_sqn: 23, AttributeID: e031 Status: 00 Type: 30 Size: 0001 ClusterData: >03<
2021-11-15 22:44:06.161 Zigate: (Zigate) ReadCluster - 0201 - 77a8/0b AttrId: e031 AttrType: 30 Attsize: 0001 Status: 00 AttrValue: 03
2021-11-15 22:44:06.162 Zigate: (Zigate) ReadCluster - 0201 - 77a8/0b AttrId: e031 AttrType: 30 AttSize: 0001 Data: 03
2021-11-15 22:44:06.162 Zigate: (Zigate) readCluster - 0201 - 77a8/0b Schneider Valve Calibration Status 03
2021-11-15 22:44:33.201 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: 59, Data: 0a098201000600000010000101, LQI: 66
2021-11-15 22:44:33.201 Zigate: (Zigate) Decode8102 - Attribute Reports: [0982:01] MsgSQN: 0a ClusterID: 0006 AttributeID: 0000 Status: 00 Type: 10 Size: 0001 ClusterData: >01<
2021-11-15 22:44:33.202 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [0982:01] ClusterID: 0006 MsgSQN: 0a, i_sqn: 23, AttributeID: 0000 Status: 00 Type: 10 Size: 0001 ClusterData: >01<
2021-11-15 22:44:33.208 Zigate: (Zigate) ReadCluster - 0006 - 0982/01 AttrId: 0000 AttrType: 10 Attsize: 0001 Status: 00 AttrValue: 01
2021-11-15 22:44:33.209 Zigate: (Zigate) ReadCluster - ClusterId=0006 - reception General: On/Off: 01
2021-11-15 22:44:42.301 Zigate: (Zigate) ReadCluster - fe03 - 7948/01 AttrId: 0020 AttrType: 42 Attsize: 0012 Status: 00 AttrValue: 4241542c322e37302c4f6e65205468697264
2021-11-15 22:44:42.301 Zigate: (Zigate) ReadCluster fe03 - 7948/01 Attribute: 0020 Type: 42 Size: 0012 Data: BAT,2.70,One Third
2021-11-15 22:44:42.302 Zigate: (Zigate) ZigateRead - MsgType: 0100, MsgLength: 28, MsgCRC: ff, Data: 797948020102010100000004001200000008001c, LQI: 168
2021-11-15 22:44:42.311 Zigate: (Zigate) Decode0100 - Mode: 79 NwkId: 7948 SrcEP: 02 DstEp: 01 ClusterId: 0201 Direction: 01 ManufSpec: 00 ManufCode: 0000 nbAttribute: 04
2021-11-15 22:44:42.311 Zigate: (Zigate) Schneider cmd 0x00 [79] Read Attribute Request on 0201/0012
2021-11-15 22:44:42.312 Zigate: (Zigate) Schneider receive attribute request: nwkid 7948 ep: 02 , clusterId: 0201, sqn: 79,rawAttr: 0012
2021-11-15 22:44:42.312 Zigate: (Zigate) schneider_find_attribute_or_set NWKID:7948, EP:01, ClusterID:0201, attr:0012 ,defaultValue:2000, newValue:None
2021-11-15 22:44:42.312 Zigate: (Zigate) schneider_find_attribute_or_set : found value 2100
2021-11-15 22:44:42.312 Zigate: (Zigate) schneider_thermostat_answer_attribute_request: nwkid 7948 ep: 01 , clusterId: 0201, sqn: 79, attr: 0012, dataType: 29, data: 0834
2021-11-15 22:44:42.313 Zigate: (Zigate) Schneider cmd 0x00 [79] Read Attribute Request on 0201/0000
2021-11-15 22:44:42.313 Zigate: (Zigate) Schneider receive attribute request: nwkid 7948 ep: 02 , clusterId: 0201, sqn: 79,rawAttr: 0000
2021-11-15 22:44:42.314 Zigate: (Zigate) schneider_thermostat_answer_attribute_request: nwkid 7948 ep: 01 , clusterId: 0201, sqn: 79, attr: 0000, dataType: 29, data: 08ca
2021-11-15 22:44:42.314 Zigate: (Zigate) Schneider cmd 0x00 [79] Read Attribute Request on 0201/0008
2021-11-15 22:44:42.315 Zigate: (Zigate) Schneider receive attribute request: nwkid 7948 ep: 02 , clusterId: 0201, sqn: 79,rawAttr: 0008
2021-11-15 22:44:42.315 Zigate: (Zigate) schneider_thermostat_answer_attribute_request: nwkid 7948 ep: 01 , clusterId: 0201, sqn: 79, attr: 0008, dataType: 20, data: 00
2021-11-15 22:44:42.316 Zigate: (Zigate) Schneider cmd 0x00 [79] Read Attribute Request on 0201/001c
2021-11-15 22:44:42.320 Zigate: (Zigate) Schneider receive attribute request: nwkid 7948 ep: 02 , clusterId: 0201, sqn: 79,rawAttr: 001c
2021-11-15 22:44:42.320 Zigate: (Zigate) schneider_thermostat_answer_attribute_request: nwkid 7948 ep: 01 , clusterId: 0201, sqn: 79, attr: 001c, dataType: 30, data: 04
2021-11-15 22:44:42.397 Zigate: (Zigate) ZigateRead - MsgType: 8000, MsgLength: 0009, MsgCRC: bf, Data: 00a5053001a50103, LQI: 0
2021-11-15 22:44:42.757 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: 02, Data: 0b77a80b0201e0120030000100, LQI: 144
2021-11-15 22:44:42.757 Zigate: (Zigate) Decode8102 - Attribute Reports: [77a8:0b] MsgSQN: 0b ClusterID: 0201 AttributeID: e012 Status: 00 Type: 30 Size: 0001 ClusterData: >00<
2021-11-15 22:44:42.757 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [77a8:0b] ClusterID: 0201 MsgSQN: 0b, i_sqn: 24, AttributeID: e012 Status: 00 Type: 30 Size: 0001 ClusterData: >00<
2021-11-15 22:44:42.767 Zigate: (Zigate) ReadCluster - 0201 - 77a8/0b AttrId: e012 AttrType: 30 Attsize: 0001 Status: 00 AttrValue: 00
2021-11-15 22:44:42.767 Zigate: (Zigate) ReadCluster - 0201 - 77a8/0b AttrId: e012 AttrType: 30 AttSize: 0001 Data: 00
2021-11-15 22:44:42.767 Zigate: (Zigate) readCluster - 0201 - 77a8/0b Schneider ATTRIBUTE_THERMOSTAT_OPEN_WINDOW_DETECTION_STATUS 00
2021-11-15 22:44:42.774 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 0b, Data: 007948030201a3, LQI: 0
2021-11-15 22:44:42.812 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: 3a, Data: 0c77a80b0201e030002000010d, LQI: 144
2021-11-15 22:44:42.812 Zigate: (Zigate) Decode8102 - Attribute Reports: [77a8:0b] MsgSQN: 0c ClusterID: 0201 AttributeID: e030 Status: 00 Type: 20 Size: 0001 ClusterData: >0d<
2021-11-15 22:44:42.813 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [77a8:0b] ClusterID: 0201 MsgSQN: 0c, i_sqn: 25, AttributeID: e030 Status: 00 Type: 20 Size: 0001 ClusterData: >0d<
2021-11-15 22:44:42.821 Zigate: (Zigate) ReadCluster - 0201 - 77a8/0b AttrId: e030 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 0d
2021-11-15 22:44:42.822 Zigate: (Zigate) ReadCluster - 0201 - 77a8/0b AttrId: e030 AttrType: 20 AttSize: 0001 Data: 0d
2021-11-15 22:44:42.822 Zigate: (Zigate) readCluster - 0201 - 77a8/0b Schneider Valve Position 0d
2021-11-15 22:44:42.829 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: a3, Data: 7b7948010b05011c00200001ff, LQI: 168
2021-11-15 22:44:42.829 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 7b ClusterID: 0b05 AttributeID: 011c Status: 00 Type: 20 Size: 0001 ClusterData: >ff<
2021-11-15 22:44:42.829 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [7948:01] ClusterID: 0b05 MsgSQN: 7b, i_sqn: None, AttributeID: 011c Status: 00 Type: 20 Size: 0001 ClusterData: >ff<
2021-11-15 22:44:42.837 Zigate: (Zigate) ReadCluster - 0b05 - 7948/01 AttrId: 011c AttrType: 20 Attsize: 0001 Status: 00 AttrValue: ff
2021-11-15 22:44:42.838 Zigate: (Zigate) ReadCluster 0b05 - 7948/01 Attribute: 011c Type: 20 Size: 0001 Data: ff
2021-11-15 22:44:42.839 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: 89, Data: 7b7948010b05011d00280001dc, LQI: 168
2021-11-15 22:44:42.839 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 7b ClusterID: 0b05 AttributeID: 011d Status: 00 Type: 28 Size: 0001 ClusterData: >dc<
2021-11-15 22:44:42.839 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [7948:01] ClusterID: 0b05 MsgSQN: 7b, i_sqn: None, AttributeID: 011d Status: 00 Type: 28 Size: 0001 ClusterData: >dc<
2021-11-15 22:44:42.847 Zigate: (Zigate) ReadCluster - 0b05 - 7948/01 AttrId: 011d AttrType: 28 Attsize: 0001 Status: 00 AttrValue: dc
2021-11-15 22:44:42.848 Zigate: (Zigate) ReadCluster 0b05 - 7948/01 Attribute: 011d Type: 28 Size: 0001 Data: dc
2021-11-15 22:44:42.849 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: a9, Data: 7c7948010b05e001002100020000, LQI: 165
2021-11-15 22:44:42.849 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 7c ClusterID: 0b05 AttributeID: e001 Status: 00 Type: 21 Size: 0002 ClusterData: >0000<
2021-11-15 22:44:42.849 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 28 Read Attribute Response: [7948:01] ClusterID: 0b05 MsgSQN: 7c, i_sqn: None, AttributeID: e001 Status: 00 Type: 21 Size: 0002 ClusterData: >0000<
2021-11-15 22:44:42.856 Zigate: (Zigate) ReadCluster - 0b05 - 7948/01 AttrId: e001 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0000
2021-11-15 22:44:42.856 Zigate: (Zigate) ReadCluster 0b05 - 7948/01 Attribute: e001 Type: 21 Size: 0002 Data: 0000
2021-11-15 22:44:42.868 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 0d, Data: 007948010000a4, LQI: 0
2021-11-15 22:44:42.876 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 1a, MsgCRC: ff, Data: 0d77a80b020400010020000100, LQI: 144
2021-11-15 22:44:42.876 Zigate: (Zigate) Decode8102 - Attribute Reports: [77a8:0b] MsgSQN: 0d ClusterID: 0204 AttributeID: 0001 Status: 00 Type: 20 Size: 0001 ClusterData: >00<
2021-11-15 22:44:42.876 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [77a8:0b] ClusterID: 0204 MsgSQN: 0d, i_sqn: 26, AttributeID: 0001 Status: 00 Type: 20 Size: 0001 ClusterData: >00<
2021-11-15 22:44:42.883 Zigate: (Zigate) ReadCluster - 0204 - 77a8/0b AttrId: 0001 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 00
2021-11-15 22:44:42.883 Zigate: (Zigate) ReadCluster 0204 - Addr: 77a8 Ep: 0b AttrId: 0001 AttrType: 20 AttSize: 0001 Data: 00
2021-11-15 22:44:42.884 Zigate: (Zigate) ReadCluster 0204 - Lock Mode: 0
2021-11-15 22:44:42.885 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 0f, Data: 007948010201a5, LQI: 0
2021-11-15 22:44:42.892 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 2c, Data: 0e77a80b020100000029000208ca, LQI: 144
2021-11-15 22:44:42.892 Zigate: (Zigate) Decode8102 - Attribute Reports: [77a8:0b] MsgSQN: 0e ClusterID: 0201 AttributeID: 0000 Status: 00 Type: 29 Size: 0002 ClusterData: >08ca<
2021-11-15 22:44:42.892 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 28 Read Attribute Response: [77a8:0b] ClusterID: 0201 MsgSQN: 0e, i_sqn: 27, AttributeID: 0000 Status: 00 Type: 29 Size: 0002 ClusterData: >08ca<
2021-11-15 22:44:42.901 Zigate: (Zigate) ReadCluster - 0201 - 77a8/0b AttrId: 0000 AttrType: 29 Attsize: 0002 Status: 00 AttrValue: 08ca
2021-11-15 22:44:42.903 Zigate: (Zigate) ReadCluster - 0201 - 77a8/0b AttrId: 0000 AttrType: 29 AttSize: 0002 Data: 08ca
2021-11-15 22:44:42.908 Zigate: (Zigate) ReadCluster - 0201 - Local Temp: 22.5
2021-11-15 22:44:42.917 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: 26, Data: 0f77a80b0201e0310030000103, LQI: 144
2021-11-15 22:44:42.917 Zigate: (Zigate) Decode8102 - Attribute Reports: [77a8:0b] MsgSQN: 0f ClusterID: 0201 AttributeID: e031 Status: 00 Type: 30 Size: 0001 ClusterData: >03<
2021-11-15 22:44:42.917 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [77a8:0b] ClusterID: 0201 MsgSQN: 0f, i_sqn: 28, AttributeID: e031 Status: 00 Type: 30 Size: 0001 ClusterData: >03<
2021-11-15 22:44:42.945 Zigate: (Zigate) ReadCluster - 0201 - 77a8/0b AttrId: e031 AttrType: 30 Attsize: 0001 Status: 00 AttrValue: 03
2021-11-15 22:44:42.945 Zigate: (Zigate) ReadCluster - 0201 - 77a8/0b AttrId: e031 AttrType: 30 AttSize: 0001 Data: 03
2021-11-15 22:44:42.945 Zigate: (Zigate) readCluster - 0201 - 77a8/0b Schneider Valve Calibration Status 03
2021-11-15 22:44:42.946 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 1a, MsgCRC: ff, Data: af72e70b020400010020000100, LQI: 72
2021-11-15 22:44:42.946 Zigate: (Zigate) Decode8102 - Attribute Reports: [72e7:0b] MsgSQN: af ClusterID: 0204 AttributeID: 0001 Status: 00 Type: 20 Size: 0001 ClusterData: >00<
2021-11-15 22:44:42.946 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [72e7:0b] ClusterID: 0204 MsgSQN: af, i_sqn: None, AttributeID: 0001 Status: 00 Type: 20 Size: 0001 ClusterData: >00<
2021-11-15 22:44:42.949 Zigate: (Zigate) ReadCluster - 0204 - 72e7/0b AttrId: 0001 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 00
2021-11-15 22:44:42.949 Zigate: (Zigate) ReadCluster 0204 - Addr: 72e7 Ep: 0b AttrId: 0001 AttrType: 20 AttSize: 0001 Data: 00
2021-11-15 22:44:42.950 Zigate: (Zigate) ReadCluster 0204 - Lock Mode: 0
2021-11-15 22:44:42.996 Zigate: (Zigate) ZigateRead - MsgType: 8000, MsgLength: 0009, MsgCRC: bc, Data: 00a6053001a60001, LQI: 0
2021-11-15 22:44:42.996 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: 31, Data: b072e70b0201e0300020000128, LQI: 72
2021-11-15 22:44:42.996 Zigate: (Zigate) Decode8102 - Attribute Reports: [72e7:0b] MsgSQN: b0 ClusterID: 0201 AttributeID: e030 Status: 00 Type: 20 Size: 0001 ClusterData: >28<
2021-11-15 22:44:42.997 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [72e7:0b] ClusterID: 0201 MsgSQN: b0, i_sqn: None, AttributeID: e030 Status: 00 Type: 20 Size: 0001 ClusterData: >28<
2021-11-15 22:44:43.003 Zigate: (Zigate) ReadCluster - 0201 - 72e7/0b AttrId: e030 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 28
2021-11-15 22:44:43.003 Zigate: (Zigate) ReadCluster - 0201 - 72e7/0b AttrId: e030 AttrType: 20 AttSize: 0001 Data: 28
2021-11-15 22:44:43.003 Zigate: (Zigate) readCluster - 0201 - 72e7/0b Schneider Valve Position 28
2021-11-15 22:44:43.005 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: 08, Data: b172e70b0201e0310030000101, LQI: 72
2021-11-15 22:44:43.005 Zigate: (Zigate) Decode8102 - Attribute Reports: [72e7:0b] MsgSQN: b1 ClusterID: 0201 AttributeID: e031 Status: 00 Type: 30 Size: 0001 ClusterData: >01<
2021-11-15 22:44:43.005 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [72e7:0b] ClusterID: 0201 MsgSQN: b1, i_sqn: None, AttributeID: e031 Status: 00 Type: 30 Size: 0001 ClusterData: >01<
2021-11-15 22:44:43.009 Zigate: (Zigate) ReadCluster - 0201 - 72e7/0b AttrId: e031 AttrType: 30 Attsize: 0001 Status: 00 AttrValue: 01
2021-11-15 22:44:43.009 Zigate: (Zigate) ReadCluster - 0201 - 72e7/0b AttrId: e031 AttrType: 30 AttSize: 0001 Data: 01
2021-11-15 22:44:43.009 Zigate: (Zigate) readCluster - 0201 - 72e7/0b Schneider Valve Calibration Status 01
2021-11-15 22:44:43.047 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 50, Data: b272e70b02010000002900020898, LQI: 72
2021-11-15 22:44:43.047 Zigate: (Zigate) Decode8102 - Attribute Reports: [72e7:0b] MsgSQN: b2 ClusterID: 0201 AttributeID: 0000 Status: 00 Type: 29 Size: 0002 ClusterData: >0898<
2021-11-15 22:44:43.047 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 28 Read Attribute Response: [72e7:0b] ClusterID: 0201 MsgSQN: b2, i_sqn: None, AttributeID: 0000 Status: 00 Type: 29 Size: 0002 ClusterData: >0898<
2021-11-15 22:44:43.054 Zigate: (Zigate) ReadCluster - 0201 - 72e7/0b AttrId: 0000 AttrType: 29 Attsize: 0002 Status: 00 AttrValue: 0898
2021-11-15 22:44:43.054 Zigate: (Zigate) ReadCluster - 0201 - 72e7/0b AttrId: 0000 AttrType: 29 AttSize: 0002 Data: 0898
2021-11-15 22:44:43.056 Zigate: (Zigate) ReadCluster - 0201 - Local Temp: 22.0
2021-11-15 22:44:43.057 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: 28, Data: b372e70b0201e0120030000100, LQI: 72
2021-11-15 22:44:43.057 Zigate: (Zigate) Decode8102 - Attribute Reports: [72e7:0b] MsgSQN: b3 ClusterID: 0201 AttributeID: e012 Status: 00 Type: 30 Size: 0001 ClusterData: >00<
2021-11-15 22:44:43.057 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [72e7:0b] ClusterID: 0201 MsgSQN: b3, i_sqn: None, AttributeID: e012 Status: 00 Type: 30 Size: 0001 ClusterData: >00<
2021-11-15 22:44:43.062 Zigate: (Zigate) ReadCluster - 0201 - 72e7/0b AttrId: e012 AttrType: 30 Attsize: 0001 Status: 00 AttrValue: 00
2021-11-15 22:44:43.062 Zigate: (Zigate) ReadCluster - 0201 - 72e7/0b AttrId: e012 AttrType: 30 AttSize: 0001 Data: 00
2021-11-15 22:44:43.062 Zigate: (Zigate) readCluster - 0201 - 72e7/0b Schneider ATTRIBUTE_THERMOSTAT_OPEN_WINDOW_DETECTION_STATUS 00
2021-11-15 22:44:43.252 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 0c, Data: 007948010201a6, LQI: 0
2021-11-15 22:44:43.374 Zigate: (Zigate) ZigateRead - MsgType: 8000, MsgLength: 0009, MsgCRC: bc, Data: 00a7053001a70001, LQI: 0
2021-11-15 22:44:44.274 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 76, MsgCRC: ff, Data: 7d794801fe0300200042002f4144432c313335362c313336342c312c3232352c323235302c323130302c302c302c302c3233332c3233302c323337, LQI: 168
2021-11-15 22:44:44.274 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 7d ClusterID: fe03 AttributeID: 0020 Status: 00 Type: 42 Size: 002f ClusterData: >4144432c313335362c313336342c312c3232352c323235302c323130302c302c302c302c3233332c3233302c323337<
2021-11-15 22:44:44.274 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 118 Read Attribute Response: [7948:01] ClusterID: fe03 MsgSQN: 7d, i_sqn: None, AttributeID: 0020 Status: 00 Type: 42 Size: 002f ClusterData: >4144432c313335362c313336342c312c3232352c323235302c323130302c302c302c302c3233332c3233302c323337<
2021-11-15 22:44:44.281 Zigate: (Zigate) ReadCluster - fe03 - 7948/01 AttrId: 0020 AttrType: 42 Attsize: 002f Status: 00 AttrValue: 4144432c313335362c313336342c312c3232352c323235302c323130302c302c302c302c3233332c3233302c323337
2021-11-15 22:44:44.281 Zigate: (Zigate) ReadCluster fe03 - 7948/01 Attribute: 0020 Type: 42 Size: 002f Data: ADC,1356,1364,1,225,2250,2100,0,0,0,233,230,237
2021-11-15 22:44:44.330 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 5e, MsgCRC: ff, Data: 7e794801fe03002000420023414c472c31622c312c3231302c3232352c2d31352c302c302c32352c313237302c3030, LQI: 168
2021-11-15 22:44:44.331 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 7e ClusterID: fe03 AttributeID: 0020 Status: 00 Type: 42 Size: 0023 ClusterData: >414c472c31622c312c3231302c3232352c2d31352c302c302c32352c313237302c3030<
2021-11-15 22:44:44.331 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 94 Read Attribute Response: [7948:01] ClusterID: fe03 MsgSQN: 7e, i_sqn: None, AttributeID: 0020 Status: 00 Type: 42 Size: 0023 ClusterData: >414c472c31622c312c3231302c3232352c2d31352c302c302c32352c313237302c3030<
2021-11-15 22:44:44.339 Zigate: (Zigate) ReadCluster - fe03 - 7948/01 AttrId: 0020 AttrType: 42 Attsize: 0023 Status: 00 AttrValue: 414c472c31622c312c3231302c3232352c2d31352c302c302c32352c313237302c3030
2021-11-15 22:44:44.340 Zigate: (Zigate) ReadCluster fe03 - 7948/01 Attribute: 0020 Type: 42 Size: 0023 Data: ALG,1b,1,210,225,-15,0,0,25,1270,00
2021-11-15 22:44:44.341 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 81, Data: 7f794801020100000029000208ca, LQI: 168
2021-11-15 22:44:44.341 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 7f ClusterID: 0201 AttributeID: 0000 Status: 00 Type: 29 Size: 0002 ClusterData: >08ca<
2021-11-15 22:44:44.341 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 28 Read Attribute Response: [7948:01] ClusterID: 0201 MsgSQN: 7f, i_sqn: None, AttributeID: 0000 Status: 00 Type: 29 Size: 0002 ClusterData: >08ca<
2021-11-15 22:44:44.351 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: 0000 AttrType: 29 Attsize: 0002 Status: 00 AttrValue: 08ca
2021-11-15 22:44:44.351 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: 0000 AttrType: 29 AttSize: 0002 Data: 08ca
2021-11-15 22:44:44.362 Zigate: (Zigate) ReadCluster - 0201 - Local Temp: 22.5
2021-11-15 22:44:44.363 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 6d, Data: 7f79480102010012002900020834, LQI: 168
2021-11-15 22:44:44.363 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 7f ClusterID: 0201 AttributeID: 0012 Status: 00 Type: 29 Size: 0002 ClusterData: >0834<
2021-11-15 22:44:44.365 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 28 Read Attribute Response: [7948:01] ClusterID: 0201 MsgSQN: 7f, i_sqn: None, AttributeID: 0012 Status: 00 Type: 29 Size: 0002 ClusterData: >0834<
2021-11-15 22:44:44.374 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: 0012 AttrType: 29 Attsize: 0002 Status: 00 AttrValue: 0834
2021-11-15 22:44:44.375 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: 0012 AttrType: 29 AttSize: 0002 Data: 0834
2021-11-15 22:44:44.375 Zigate: (Zigate) ReadCluster - 0201 - Heating Setpoint: 2100 ==> 21.0
2021-11-15 22:44:44.376 Zigate: (Zigate) ReadCluster - 0201 - Request update on Domoticz 7948 not a Schneider, not a Eurotronics
2021-11-15 22:44:44.393 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: 40, Data: 7f794801020100080020000100, LQI: 168
2021-11-15 22:44:44.394 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 7f ClusterID: 0201 AttributeID: 0008 Status: 00 Type: 20 Size: 0001 ClusterData: >00<
2021-11-15 22:44:44.394 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [7948:01] ClusterID: 0201 MsgSQN: 7f, i_sqn: None, AttributeID: 0008 Status: 00 Type: 20 Size: 0001 ClusterData: >00<
2021-11-15 22:44:44.404 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: 0008 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 00
2021-11-15 22:44:44.404 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: 0008 AttrType: 20 AttSize: 0001 Data: 00
2021-11-15 22:44:44.404 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 Pi Heating Demand: 00
2021-11-15 22:44:44.415 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: c5, Data: 007948010201e0120020000100, LQI: 168
2021-11-15 22:44:44.415 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 00 ClusterID: 0201 AttributeID: e012 Status: 00 Type: 20 Size: 0001 ClusterData: >00<
2021-11-15 22:44:44.415 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [7948:01] ClusterID: 0201 MsgSQN: 00, i_sqn: 9, AttributeID: e012 Status: 00 Type: 20 Size: 0001 ClusterData: >00<
2021-11-15 22:44:44.424 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: e012 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 00
2021-11-15 22:44:44.425 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: e012 AttrType: 20 AttSize: 0001 Data: 00
2021-11-15 22:44:44.426 Zigate: (Zigate) readCluster - 0201 - 7948/01 Schneider ATTRIBUTE_THERMOSTAT_OPEN_WINDOW_DETECTION_STATUS 00
2021-11-15 22:44:44.439 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: c0, Data: 007948010201e0130020000104, LQI: 168
2021-11-15 22:44:44.439 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 00 ClusterID: 0201 AttributeID: e013 Status: 00 Type: 20 Size: 0001 ClusterData: >04<
2021-11-15 22:44:44.439 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [7948:01] ClusterID: 0201 MsgSQN: 00, i_sqn: 9, AttributeID: e013 Status: 00 Type: 20 Size: 0001 ClusterData: >04<
2021-11-15 22:44:44.450 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: e013 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 04
2021-11-15 22:44:44.450 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: e013 AttrType: 20 AttSize: 0001 Data: 04
2021-11-15 22:44:44.450 Zigate: (Zigate) readCluster - 0201 - 7948/01 Schneider ATTRIBUTE_THERMOSTAT_OPEN_WINDOW_DETECTION_THRESHOLD 04
2021-11-15 22:44:44.451 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 9a, Data: 007948010201e014002100020258, LQI: 168
2021-11-15 22:44:44.452 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 00 ClusterID: 0201 AttributeID: e014 Status: 00 Type: 21 Size: 0002 ClusterData: >0258<
2021-11-15 22:44:44.452 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 28 Read Attribute Response: [7948:01] ClusterID: 0201 MsgSQN: 00, i_sqn: 9, AttributeID: e014 Status: 00 Type: 21 Size: 0002 ClusterData: >0258<
2021-11-15 22:44:44.460 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: e014 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0258
2021-11-15 22:44:44.460 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: e014 AttrType: 21 AttSize: 0002 Data: 0258
2021-11-15 22:44:44.461 Zigate: (Zigate) readCluster - 0201 - 7948/01 Schneider ATTRIBUTE_THERMOSTAT_OPEN_WINDOW_DETECTION_INTERVAL 0258
2021-11-15 22:44:44.462 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: b9, Data: 007948010201e015002100020078, LQI: 168
2021-11-15 22:44:44.462 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 00 ClusterID: 0201 AttributeID: e015 Status: 00 Type: 21 Size: 0002 ClusterData: >0078<
2021-11-15 22:44:44.462 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 28 Read Attribute Response: [7948:01] ClusterID: 0201 MsgSQN: 00, i_sqn: 9, AttributeID: e015 Status: 00 Type: 21 Size: 0002 ClusterData: >0078<
2021-11-15 22:44:44.466 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: e015 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0078
2021-11-15 22:44:44.466 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: e015 AttrType: 21 AttSize: 0002 Data: 0078
2021-11-15 22:44:44.467 Zigate: (Zigate) readCluster - 0201 - 7948/01 unknown attribute: e015 21 0002 0078
2021-11-15 22:44:44.467 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: d9, Data: 017948010b05011c00200001ff, LQI: 168
2021-11-15 22:44:44.467 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 01 ClusterID: 0b05 AttributeID: 011c Status: 00 Type: 20 Size: 0001 ClusterData: >ff<
2021-11-15 22:44:44.467 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [7948:01] ClusterID: 0b05 MsgSQN: 01, i_sqn: 10, AttributeID: 011c Status: 00 Type: 20 Size: 0001 ClusterData: >ff<
2021-11-15 22:44:44.472 Zigate: (Zigate) ReadCluster - 0b05 - 7948/01 AttrId: 011c AttrType: 20 Attsize: 0001 Status: 00 AttrValue: ff
2021-11-15 22:44:44.472 Zigate: (Zigate) ReadCluster 0b05 - 7948/01 Attribute: 011c Type: 20 Size: 0001 Data: ff
2021-11-15 22:44:44.472 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: f3, Data: 017948010b05011d00280001dc, LQI: 168
2021-11-15 22:44:44.473 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 01 ClusterID: 0b05 AttributeID: 011d Status: 00 Type: 28 Size: 0001 ClusterData: >dc<
2021-11-15 22:44:44.473 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [7948:01] ClusterID: 0b05 MsgSQN: 01, i_sqn: 10, AttributeID: 011d Status: 00 Type: 28 Size: 0001 ClusterData: >dc<
2021-11-15 22:44:44.477 Zigate: (Zigate) ReadCluster - 0b05 - 7948/01 AttrId: 011d AttrType: 28 Attsize: 0001 Status: 00 AttrValue: dc
2021-11-15 22:44:44.477 Zigate: (Zigate) ReadCluster 0b05 - 7948/01 Attribute: 011d Type: 28 Size: 0001 Data: dc
2021-11-15 22:44:44.478 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: da, Data: 027948010b05e001002100020000, LQI: 168
2021-11-15 22:44:44.478 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 02 ClusterID: 0b05 AttributeID: e001 Status: 00 Type: 21 Size: 0002 ClusterData: >0000<
2021-11-15 22:44:44.478 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 28 Read Attribute Response: [7948:01] ClusterID: 0b05 MsgSQN: 02, i_sqn: 11, AttributeID: e001 Status: 00 Type: 21 Size: 0002 ClusterData: >0000<
2021-11-15 22:44:44.482 Zigate: (Zigate) ReadCluster - 0b05 - 7948/01 AttrId: e001 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0000
2021-11-15 22:44:44.482 Zigate: (Zigate) ReadCluster 0b05 - 7948/01 Attribute: e001 Type: 21 Size: 0002 Data: 0000
2021-11-15 22:44:44.483 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 02, Data: 007948010201a8, LQI: 0
Le ID du device est 7948.
Il y a une ligne dans le log que m'a interpellé, car elle indique que ce n'est pas du schneider.
Et voici un log de l'erreur remonté si je tourne la molette pour faire monter le set point:
21-11-15 23:07:08.995 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 28 Read Attribute Response: [7948:01] ClusterID: 0201 MsgSQN: 2e, i_sqn: 208, AttributeID: e015 Status: 00 Type: 21 Size: 0002 ClusterData: >0078<
2021-11-15 23:07:08.998 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: e015 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0078
2021-11-15 23:07:08.998 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: e015 AttrType: 21 AttSize: 0002 Data: 0078
2021-11-15 23:07:08.998 Zigate: (Zigate) readCluster - 0201 - 7948/01 unknown attribute: e015 21 0002 0078
2021-11-15 23:07:08.848 Error: Zigate: (Zigate) change_setpoint_for_time -- Unknown action: 0102 setpoint: 2800 duration: 60
2021-11-15 23:07:09.363 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 60 Read Attribute Response: [7948:01] ClusterID: fe03 MsgSQN: 31, i_sqn: 219, AttributeID: 0020 Status: 00 Type: 42 Size: 0012 ClusterData: >4241542c322e37302c4f6e65205468697264<
2021-11-15 23:07:09.367 Zigate: (Zigate) ReadCluster - fe03 - 7948/01 AttrId: 0020 AttrType: 42 Attsize: 0012 Status: 00 AttrValue: 4241542c322e37302c4f6e65205468697264
2021-11-15 23:07:09.367 Zigate: (Zigate) ReadCluster fe03 - 7948/01 Attribute: 0020 Type: 42 Size: 0012 Data: BAT,2.70,One Third
2021-11-15 23:07:09.368 Zigate: (Zigate) ZigateRead - MsgType: 0100, MsgLength: 28, MsgCRC: ff, Data: 327948020102010100000004001200000008001c, LQI: 141
2021-11-15 23:07:09.373 Zigate: (Zigate) Decode0100 - Mode: 32 NwkId: 7948 SrcEP: 02 DstEp: 01 ClusterId: 0201 Direction: 01 ManufSpec: 00 ManufCode: 0000 nbAttribute: 04
2021-11-15 23:07:09.373 Zigate: (Zigate) Schneider cmd 0x00 [32] Read Attribute Request on 0201/0012
2021-11-15 23:07:09.373 Zigate: (Zigate) Schneider receive attribute request: nwkid 7948 ep: 02 , clusterId: 0201, sqn: 32,rawAttr: 0012
2021-11-15 23:07:09.374 Zigate: (Zigate) schneider_find_attribute_or_set NWKID:7948, EP:01, ClusterID:0201, attr:0012 ,defaultValue:2000, newValue:None
2021-11-15 23:07:09.374 Zigate: (Zigate) schneider_find_attribute_or_set : found value 2800
2021-11-15 23:07:09.374 Zigate: (Zigate) schneider_thermostat_answer_attribute_request: nwkid 7948 ep: 01 , clusterId: 0201, sqn: 32, attr: 0012, dataType: 29, data: 0AF0
2021-11-15 23:07:09.374 Zigate: (Zigate) Schneider cmd 0x00 [32] Read Attribute Request on 0201/0000
2021-11-15 23:07:09.374 Zigate: (Zigate) Schneider receive attribute request: nwkid 7948 ep: 02 , clusterId: 0201, sqn: 32,rawAttr: 0000
2021-11-15 23:07:09.374 Zigate: (Zigate) schneider_thermostat_answer_attribute_request: nwkid 7948 ep: 01 , clusterId: 0201, sqn: 32, attr: 0000, dataType: 29, data: 08c0
2021-11-15 23:07:09.375 Zigate: (Zigate) Schneider cmd 0x00 [32] Read Attribute Request on 0201/0008
2021-11-15 23:07:09.375 Zigate: (Zigate) Schneider receive attribute request: nwkid 7948 ep: 02 , clusterId: 0201, sqn: 32,rawAttr: 0008
2021-11-15 23:07:09.375 Zigate: (Zigate) schneider_thermostat_answer_attribute_request: nwkid 7948 ep: 01 , clusterId: 0201, sqn: 32, attr: 0008, dataType: 20, data: 00
2021-11-15 23:07:09.375 Zigate: (Zigate) Schneider cmd 0x00 [32] Read Attribute Request on 0201/001c
2021-11-15 23:07:09.376 Zigate: (Zigate) Schneider receive attribute request: nwkid 7948 ep: 02 , clusterId: 0201, sqn: 32,rawAttr: 001c
2021-11-15 23:07:09.376 Zigate: (Zigate) schneider_thermostat_answer_attribute_request: nwkid 7948 ep: 01 , clusterId: 0201, sqn: 32, attr: 001c, dataType: 30, data: 04
2021-11-15 23:07:09.484 Zigate: (Zigate) ZigateRead - MsgType: 8000, MsgLength: 0009, MsgCRC: bf, Data: 004b0530014b0002, LQI: 0
2021-11-15 23:07:09.899 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: e2, Data: 0079480302014a, LQI: 0
2021-11-15 23:07:09.906 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: e1, Data: 0079480102014b, LQI: 0
2021-11-15 23:07:10.017 Zigate: (Zigate) ZigateRead - MsgType: 8000, MsgLength: 0009, MsgCRC: bc, Data: 004c0530014c0001, LQI: 0
2021-11-15 23:07:10.381 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: e6, Data: 0079480102014c, LQI: 0
2021-11-15 23:07:10.507 Zigate: (Zigate) ZigateRead - MsgType: 8000, MsgLength: 0009, MsgCRC: bc, Data: 004d0530014d0001, LQI: 0
2021-11-15 23:07:10.869 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: e7, Data: 0079480102014d, LQI: 0
2021-11-15 23:07:10.987 Zigate: (Zigate) ZigateRead - MsgType: 8000, MsgLength: 0009, MsgCRC: bd, Data: 004e0530014e0101, LQI: 0
2021-11-15 23:07:11.398 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 7a, MsgCRC: ff, Data: 33794801fe030020004200314144432c313336382c313337322c312c3232342c323234302c323830302c302c3530302c302c3232382c3232372c323337, LQI: 165
2021-11-15 23:07:11.398 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 33 ClusterID: fe03 AttributeID: 0020 Status: 00 Type: 42 Size: 0031 ClusterData: >4144432c313336382c313337322c312c3232342c323234302c323830302c302c3530302c302c3232382c3232372c323337<
2021-11-15 23:07:11.399 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 122 Read Attribute Response: [7948:01] ClusterID: fe03 MsgSQN: 33, i_sqn: 229, AttributeID: 0020 Status: 00 Type: 42 Size: 0031 ClusterData: >4144432c313336382c313337322c312c3232342c323234302c323830302c302c3530302c302c3232382c3232372c323337<
2021-11-15 23:07:11.413 Zigate: (Zigate) ReadCluster - fe03 - 7948/01 AttrId: 0020 AttrType: 42 Attsize: 0031 Status: 00 AttrValue: 4144432c313336382c313337322c312c3232342c323234302c323830302c302c3530302c302c3232382c3232372c323337
2021-11-15 23:07:11.413 Zigate: (Zigate) ReadCluster fe03 - 7948/01 Attribute: 0020 Type: 42 Size: 0031 Data: ADC,1368,1372,1,224,2240,2800,0,500,0,228,227,237
2021-11-15 23:07:11.414 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 68, MsgCRC: ff, Data: 34794801fe03002000420028414c472c32642c312c3238302c3232342c35362c3530302c3530302c32362c313737302c31303030, LQI: 168
2021-11-15 23:07:11.415 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 34 ClusterID: fe03 AttributeID: 0020 Status: 00 Type: 42 Size: 0028 ClusterData: >414c472c32642c312c3238302c3232342c35362c3530302c3530302c32362c313737302c31303030<
2021-11-15 23:07:11.417 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 104 Read Attribute Response: [7948:01] ClusterID: fe03 MsgSQN: 34, i_sqn: 230, AttributeID: 0020 Status: 00 Type: 42 Size: 0028 ClusterData: >414c472c32642c312c3238302c3232342c35362c3530302c3530302c32362c313737302c31303030<
2021-11-15 23:07:11.430 Zigate: (Zigate) ReadCluster - fe03 - 7948/01 AttrId: 0020 AttrType: 42 Attsize: 0028 Status: 00 AttrValue: 414c472c32642c312c3238302c3232342c35362c3530302c3530302c32362c313737302c31303030
2021-11-15 23:07:11.430 Zigate: (Zigate) ReadCluster fe03 - 7948/01 Attribute: 0020 Type: 42 Size: 0028 Data: ALG,2d,1,280,224,56,500,500,26,1770,1000
2021-11-15 23:07:11.431 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: c1, Data: 35794801020100000029000208c0, LQI: 168
2021-11-15 23:07:11.431 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 35 ClusterID: 0201 AttributeID: 0000 Status: 00 Type: 29 Size: 0002 ClusterData: >08c0<
2021-11-15 23:07:11.432 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 28 Read Attribute Response: [7948:01] ClusterID: 0201 MsgSQN: 35, i_sqn: 231, AttributeID: 0000 Status: 00 Type: 29 Size: 0002 ClusterData: >08c0<
2021-11-15 23:07:11.441 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: 0000 AttrType: 29 Attsize: 0002 Status: 00 AttrValue: 08c0
2021-11-15 23:07:11.441 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: 0000 AttrType: 29 AttSize: 0002 Data: 08c0
2021-11-15 23:07:11.452 Zigate: (Zigate) ReadCluster - 0201 - Local Temp: 22.4
2021-11-15 23:07:11.453 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: e1, Data: 3579480102010012002900020af0, LQI: 168
2021-11-15 23:07:11.453 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 35 ClusterID: 0201 AttributeID: 0012 Status: 00 Type: 29 Size: 0002 ClusterData: >0af0<
2021-11-15 23:07:11.454 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 28 Read Attribute Response: [7948:01] ClusterID: 0201 MsgSQN: 35, i_sqn: 231, AttributeID: 0012 Status: 00 Type: 29 Size: 0002 ClusterData: >0af0<
2021-11-15 23:07:11.464 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: 0012 AttrType: 29 Attsize: 0002 Status: 00 AttrValue: 0af0
2021-11-15 23:07:11.464 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: 0012 AttrType: 29 AttSize: 0002 Data: 0af0
2021-11-15 23:07:11.465 Zigate: (Zigate) ReadCluster - 0201 - Heating Setpoint: 2800 ==> 28.0
2021-11-15 23:07:11.466 Zigate: (Zigate) ReadCluster - 0201 - Request update on Domoticz 7948 not a Schneider, not a Eurotronics
2021-11-15 23:07:11.475 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: 6e, Data: 35794801020100080020000164, LQI: 168
2021-11-15 23:07:11.475 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 35 ClusterID: 0201 AttributeID: 0008 Status: 00 Type: 20 Size: 0001 ClusterData: >64<
2021-11-15 23:07:11.475 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [7948:01] ClusterID: 0201 MsgSQN: 35, i_sqn: 231, AttributeID: 0008 Status: 00 Type: 20 Size: 0001 ClusterData: >64<
2021-11-15 23:07:11.483 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: 0008 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 64
2021-11-15 23:07:11.484 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: 0008 AttrType: 20 AttSize: 0001 Data: 64
2021-11-15 23:07:11.484 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 Pi Heating Demand: 64
2021-11-15 23:07:11.502 Zigate: (Zigate) UpdateDevice - (Zigate - iTRV_Valve-086bd7fffef3c0fd-01) 100:100
2021-11-15 23:07:11.505 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: f3, Data: 367948010201e0120020000100, LQI: 168
2021-11-15 23:07:11.505 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 36 ClusterID: 0201 AttributeID: e012 Status: 00 Type: 20 Size: 0001 ClusterData: >00<
2021-11-15 23:07:11.506 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [7948:01] ClusterID: 0201 MsgSQN: 36, i_sqn: 244, AttributeID: e012 Status: 00 Type: 20 Size: 0001 ClusterData: >00<
2021-11-15 23:07:11.513 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: e012 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 00
2021-11-15 23:07:11.514 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: e012 AttrType: 20 AttSize: 0001 Data: 00
2021-11-15 23:07:11.514 Zigate: (Zigate) readCluster - 0201 - 7948/01 Schneider ATTRIBUTE_THERMOSTAT_OPEN_WINDOW_DETECTION_STATUS 00
2021-11-15 23:07:11.517 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: f6, Data: 367948010201e0130020000104, LQI: 168
2021-11-15 23:07:11.517 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 36 ClusterID: 0201 AttributeID: e013 Status: 00 Type: 20 Size: 0001 ClusterData: >04<
2021-11-15 23:07:11.518 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [7948:01] ClusterID: 0201 MsgSQN: 36, i_sqn: 244, AttributeID: e013 Status: 00 Type: 20 Size: 0001 ClusterData: >04<
2021-11-15 23:07:11.523 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: e013 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 04
2021-11-15 23:07:11.523 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: e013 AttrType: 20 AttSize: 0001 Data: 04
2021-11-15 23:07:11.523 Zigate: (Zigate) readCluster - 0201 - 7948/01 Schneider ATTRIBUTE_THERMOSTAT_OPEN_WINDOW_DETECTION_THRESHOLD 04
2021-11-15 23:07:11.524 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: ac, Data: 367948010201e014002100020258, LQI: 168
2021-11-15 23:07:11.524 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 36 ClusterID: 0201 AttributeID: e014 Status: 00 Type: 21 Size: 0002 ClusterData: >0258<
2021-11-15 23:07:11.524 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 28 Read Attribute Response: [7948:01] ClusterID: 0201 MsgSQN: 36, i_sqn: 244, AttributeID: e014 Status: 00 Type: 21 Size: 0002 ClusterData: >0258<
2021-11-15 23:07:11.529 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: e014 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0258
2021-11-15 23:07:11.529 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: e014 AttrType: 21 AttSize: 0002 Data: 0258
2021-11-15 23:07:11.529 Zigate: (Zigate) readCluster - 0201 - 7948/01 Schneider ATTRIBUTE_THERMOSTAT_OPEN_WINDOW_DETECTION_INTERVAL 0258
2021-11-15 23:07:11.530 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 8f, Data: 367948010201e015002100020078, LQI: 168
2021-11-15 23:07:11.530 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 36 ClusterID: 0201 AttributeID: e015 Status: 00 Type: 21 Size: 0002 ClusterData: >0078<
2021-11-15 23:07:11.530 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 28 Read Attribute Response: [7948:01] ClusterID: 0201 MsgSQN: 36, i_sqn: 244, AttributeID: e015 Status: 00 Type: 21 Size: 0002 ClusterData: >0078<
2021-11-15 23:07:11.536 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: e015 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0078
2021-11-15 23:07:11.537 Zigate: (Zigate) ReadCluster - 0201 - 7948/01 AttrId: e015 AttrType: 21 AttSize: 0002 Data: 0078
2021-11-15 23:07:11.537 Zigate: (Zigate) readCluster - 0201 - 7948/01 unknown attribute: e015 21 0002 0078
2021-11-15 23:07:11.537 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: ec, Data: 377948010b05011c00200001fc, LQI: 168
2021-11-15 23:07:11.537 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 37 ClusterID: 0b05 AttributeID: 011c Status: 00 Type: 20 Size: 0001 ClusterData: >fc<
2021-11-15 23:07:11.538 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [7948:01] ClusterID: 0b05 MsgSQN: 37, i_sqn: 265, AttributeID: 011c Status: 00 Type: 20 Size: 0001 ClusterData: >fc<
2021-11-15 23:07:11.548 Zigate: (Zigate) ReadCluster - 0b05 - 7948/01 AttrId: 011c AttrType: 20 Attsize: 0001 Status: 00 AttrValue: fc
2021-11-15 23:07:11.549 Zigate: (Zigate) ReadCluster 0b05 - 7948/01 Attribute: 011c Type: 20 Size: 0001 Data: fc
2021-11-15 23:07:11.554 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: c2, Data: 377948010b05011d00280001db, LQI: 168
2021-11-15 23:07:11.554 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 37 ClusterID: 0b05 AttributeID: 011d Status: 00 Type: 28 Size: 0001 ClusterData: >db<
2021-11-15 23:07:11.554 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [7948:01] ClusterID: 0b05 MsgSQN: 37, i_sqn: 265, AttributeID: 011d Status: 00 Type: 28 Size: 0001 ClusterData: >db<
2021-11-15 23:07:11.560 Zigate: (Zigate) ReadCluster - 0b05 - 7948/01 AttrId: 011d AttrType: 28 Attsize: 0001 Status: 00 AttrValue: db
2021-11-15 23:07:11.560 Zigate: (Zigate) ReadCluster 0b05 - 7948/01 Attribute: 011d Type: 28 Size: 0001 Data: db
2021-11-15 23:07:11.561 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: ed, Data: 387948010b05e001002100020000, LQI: 165
2021-11-15 23:07:11.561 Zigate: (Zigate) Decode8102 - Attribute Reports: [7948:01] MsgSQN: 38 ClusterID: 0b05 AttributeID: e001 Status: 00 Type: 21 Size: 0002 ClusterData: >0000<
2021-11-15 23:07:11.561 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 28 Read Attribute Response: [7948:01] ClusterID: 0b05 MsgSQN: 38, i_sqn: 278, AttributeID: e001 Status: 00 Type: 21 Size: 0002 ClusterData: >0000<
2021-11-15 23:07:11.576 Zigate: (Zigate) ReadCluster - 0b05 - 7948/01 AttrId: e001 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0000
2021-11-15 23:07:11.576 Zigate: (Zigate) ReadCluster 0b05 - 7948/01 Attribute: e001 Type: 21 Size: 0002 Data: 0000
2021-11-15 23:07:11.576 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: e4, Data: 0079480102014e, LQI: 0
2021-11-15 23:07:14.036 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 1a, MsgCRC: ff, Data: 6572e70b020400010020000100, LQI: 69
2021-11-15 23:07:14.037 Zigate: (Zigate) Decode8102 - Attribute Reports: [72e7:0b] MsgSQN: 65 ClusterID: 0204 AttributeID: 0001 Status: 00 Type: 20 Size: 0001 ClusterData: >00<
2021-11-15 23:07:14.037 Zigate: (Zigate) scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [72e7:0b] ClusterID: 0204 MsgSQN: 65, i_sqn: None, AttributeID: 0001 Status: 00 Type: 20 Size: 0001 ClusterData: >00<
