[Résolu] prise Wiser CCTFR6500
Re: [Conbee2] prise Wiser CCTFR6500
essayes
sudo python3 -m pip install pip wheel pyopenssl --upgrade
puis refait le
Bibi49
Message par Bibi49 »
le sudo python3 -m pip install pip wheel pyopenssl --upgrade a ete lancer depuis "/home/pi/ et depuis /home/pi/domoticz/plugins/Domoticz-Zigbee/ (idem dans les deux cas)
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ sudo service domoticz.sh stop
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ sudo python3 -m pip install pip wheel pyopenssl --upgrade
  File "/usr/lib/python3.9/runpy.py", line 197, in _run_module_as_main
    return _run_code(code, main_globals, None,
  File "/usr/lib/python3.9/runpy.py", line 87, in _run_code
    exec(code, run_globals)
  File "/usr/lib/python3/dist-packages/pip/__main__.py", line 23, in <module>
    from pip._internal.cli.main import main as _main  # isort:skip # noqa
  File "/usr/lib/python3/dist-packages/pip/_internal/cli/main.py", line 10, in <module>
    from pip._internal.cli.autocompletion import autocomplete
  File "/usr/lib/python3/dist-packages/pip/_internal/cli/autocompletion.py", line 9, in <module>
    from pip._internal.cli.main_parser import create_main_parser
  File "/usr/lib/python3/dist-packages/pip/_internal/cli/main_parser.py", line 7, in <module>
    from pip._internal.cli import cmdoptions
  File "/usr/lib/python3/dist-packages/pip/_internal/cli/cmdoptions.py", line 23, in <module>
    from pip._vendor.packaging.utils import canonicalize_name
  File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 94, in <module>
    vendored("requests.packages.urllib3.contrib.pyopenssl")
  File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 36, in vendored
    __import__(modulename, globals(), locals(), level=0)
  File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
  File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 664, in _load_unlocked
  File "<frozen importlib._bootstrap>", line 627, in _load_backward_compatible
  File "<frozen zipimport>", line 259, in load_module
  File "/usr/share/python-wheels/urllib3-1.26.5-py2.py3-none-any.whl/urllib3/contrib/pyopenssl.py", line 50, in <module>
  File "/usr/lib/python3/dist-packages/OpenSSL/__init__.py", line 8, in <module>
    from OpenSSL import crypto, SSL
  File "/usr/lib/python3/dist-packages/OpenSSL/crypto.py", line 1556, in <module>
    class X509StoreFlags(object):
  File "/usr/lib/python3/dist-packages/OpenSSL/crypto.py", line 1577, in X509StoreFlags
    CB_ISSUER_CHECK = _lib.X509_V_FLAG_CB_ISSUER_CHECK
AttributeError: module 'lib' has no attribute 'X509_V_FLAG_CB_ISSUER_CHECK'
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ sudo python3 -m pip install -r requirements.txt --upgrade
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ sudo service domoticz.sh start
toujours la meme erreur dans le log de Domoticz
2023-03-07 11:34:26.838 Error: Conbee2: (Zigate) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/Domoticz-Zigbee/:/usr/lib/python39.zip:/usr/lib/python3.9:/usr/lib/python3.9/lib-dynload:/usr/local/lib/python3.9/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.9/dist-packages'.
2023-03-07 11:34:26.843 Error: Conbee2: Traceback (most recent call last):
2023-03-07 11:34:26.844 Error: Conbee2: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 97, in <module>
2023-03-07 11:34:26.844 Error: Conbee2: import z4d_certified_devices
2023-03-07 11:34:26.844 Error: Conbee2: ModuleNotFoundError: No module named 'z4d_certified_devices'
je commence a me demander si je vais pas attendre la reception d'un autres pi pour tester avec une version "neuve et propre"...
C'est peut être la version de bulleyes Lite du 21/02/23 qui pose soucis ?
RPI 2 -> Bullseye Lite
DomoticZ -> 2024.7
RFXCom 433E -> Pro1 1041
PiTInfo v1.4
USB->ùSD = Rpi-clones
ah tu es en bullseye Lite . Oui je crois qu'il y a un soucis il manque des packages
Bibi49
Bon, je vais tout réinstaller mais avant j'ai quelques questions :
- Quel version de Raspbian choisir ? Raspberry Pi OS with desktop (Size: 924MB) ou Raspberry Pi OS with desktop and recommended software (Size: 2,752MB) (Bulleyes 32bits du 21/02/23 dans les deux cas)
-j'ai fais une sauvegarde avec cp -r /home/pi/domoticz/plugins/Domoticz-Zigbee /home/pi
Mais certains fichiers refuse d'être transféré de /home/pi vers mon PC (dont PluginConf-06.json). J'ai essayé de convertir le dossier "Domoticz-Zigbee" en archive .tgz mais l'archive est incomplète sur mon PC (archive.tgz\Domoticz-Zigbee\Conf\ici je n'ai que le dossier "Certified" et le fichier "DeviseConf.txt" ). Si vous connaissez un moyen de recuperer la sauvegarde sur mon PC, je suis preneur :)
DomoticZ -> 2024.7
PiTInfo v1.4
A partir de la racine du plugin, tu peux faire
sudo tar cvf monbackup.tar .
et ensuite tu transferes le fichier monbackup.tar vers to pc
De préférence fais la sauvegarde domoticz en meme temps
Bibi49
OK Merci
Téléchargement puis installation de la version full OS.
Je testerais ultérieurement la version "Raspberry Pi OS with desktop (Size: 924MB)" pour savoir si elle est suffisante.
Resultat : Toujours meme erreurs....
solution -> https://stackoverflow.com/questions/738 ... suer-check (3eme solution)
sudo apt remove python3-pip
wget https://bootstrap.pypa.io/get-pip.py
sudo python3 get-pip.py
sudo reboot
pip install pyopenssl --upgrade
a présent, je suis en version Plugin: 6.4.304 [1.5], une maj est proposé mais elle ne fonctionne pas (en automatique).
Dois-je la lancer manuellement ou je reste sur cette version ?
DomoticZ -> 2024.7
PiTInfo v1.4
Bibi49
pipiche a écrit : 01 mars 2023, 20:09
Peux-tu une fois sur develop faire tourner en activant le debug : ZclClusters
c'est dans Outils/Debogage/trackZclClusters ?
DomoticZ -> 2024.7
PiTInfo v1.4
Oui ...
Bibi49
Resultat :
tension affiché 369V (entre 234 et 240 Volts réel)
Ampérage affiché 5A (normalement environ 3.15A)
les Kw/H sont resté bloqué a 0.001Kw/H -> tester sur 5 minutes
Plugin: 6.4.304 [1.5] en rouge (mise a jour disponible) mais ne fonctionne pas en automatique ou manuellement en ligne de commande :
cd /home/pi/domoticz/plugins/Domoticz-Zigbee/
git submodule update --init --recursive
sudo chmod +x plugin.py
export.json
(32.35 Kio) Téléchargé 65 fois
DomoticZ -> 2024.7
PiTInfo v1.4
peux-tu mettre les logs, dire que ca ne fonctionne pas ne permet pas d'avoir un diagnostic.
