- For a full overview visit:
https://www.domoticz.com/wiki/Domoticz_ ... _-_Commits for details
- Implemented: Accept JWT tokens as authentication and Authorization Bearer tokens (either from internal or external IAM service)
- Implemented: Blinds, added option to schedule 0%
- Implemented: dzVents, OpenURL PATCH method
- Implemented: Enphase, redesign and added battery readings (Supports firmware V7)
- Implemented: Internal OAuth2/OIDC IAM service supporting 4 different flows (OAuth2 (RFC6749), PKCE extension (RFC7636) and JWT Tokens (RFC7519))
- Implemented: MQTT, added support for Lock status
- Implemented: MQTT, added support for wildcards in discovery topics
- Implemented: MQTT, climate preset mode
- Implemented: New 'auth' debug flag to see IAM related messages
- Implemented: Now 'Applications' can be registered to get secure access to Domoticz, see 'setup' menu (standard DomoticzUI app is registered by default)
- Implemented: P1 Meter, added number of (long) power failures, voltage sags/swells
- Implemented: SECURITY_SETUP.md describing the new/improved security setup
- Implemented: Support for basic OpenID Connect Discovery ('https://<DOMOTICZURL>/.well-known/openid-configuration')
- Implemented: Search option in Switches/Scenes/Temperature/Utility and Weather tab
- Implemented: The Security realm can be configured using the 'vhostname' option (default domoticz.com)
- Implemented: Timer, Grid option for selected switches and thermostat. Big thanks to syrhus/labelette91580 and xbeaudouin
- Implemented: User device selection now displays type/subtype
- Changed: All security related setting are now in 1 settings tab
- Changed: By default prompt for login to only allow secure access
- Changed: Default 'admin' user is generated with standard password (see Users)
- Changed: Dimmer, restores to previous Set Level state after Off
- Changed: Implicit adding local IP to 'trusted networks' has been removed. Needs to be set explicitly for security reasons!
- Changed: Lots of security related code cleanup and improvements
- Changed: Menu option for 'Users' moved to main 'Setup' menu list
- Changed: MQTT timeout increased to 2 minutes
- Changed: The following proxy headers are now properly supported 'Forwarded' (RFC7239), 'X-Forwarder-For' and 'X-Real-IP' (in that order)
- Changed: The secure server (HTTPS) sends proper CORS and Security headers
- Fixed: Dashboard, scenes/lights hidden when this was disabled in user settings
- Fixed: Dashboard, mobile display did not display P1 meter current return value correctly
- Fixed: Dashboard, not showing disabled sections (temperature/weather/utility) when a device has multiple properties (for instance temperature + weather)
- Fixed: Highcharts dropdown menu z-index problem
- Fixed: Logout now returns 204 instead of 401
- Fixed: Waterflow sensor custom icon
- Fixed: Making sure Custom icons are valid (when someone manually edits the database)
- Fixed: Mobile display text objects with long lines
- Fixed: MQTT-AD Climate, fixed setpoint temperature display
- Fixed: Navigation bar display issues on some mobile devices
- Fixed: Setpoint popup when using protection
