Personne pour m'aider
pi@raspberrypi:/dev $ lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINT
sda
├─sda1 vfat FAT32 boot AE82-4BC1
└─sda2 ext4 1.0 rootfs 6d2ff93e-eacd-415c-96d5-4611ad21e05f
mmcblk0
├─mmcblk0p1 vfat FAT32 boot AE82-4BC1 204,6M 20% /boot
└─mmcblk0p2 ext4 1.0 rootfs 6d2ff93e-eacd-415c-96d5-4611ad21e05f 19,1G 30% /
et
[i]sudo fdisk -l|grep mmcblk0[/i]
Disk /dev/mmcblk0: 29,72 GiB, 31914983424 bytes, 62333952 sectors
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 8192 532479 524288 256M c W95 FAT32 (LBA)
/dev/mmcblk0p2 532480 62333951 61801472 29,5G 83 Linux
Disk /dev/sda: 2 TiB, 2196578500608 bytes, 4290192384 sectors
/dev/sda1 8192 532479 524288 256M c W95 FAT32 (LBA)
/dev/sda2 532480 62333951 61801472 29,5G 83 Linux
mais j'ai cette erreur dans syslog
Mar 21 19:28:59 raspberrypi kernel: [206717.764177] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=DRIVER_OK cmd_age=0s
Mar 21 19:28:59 raspberrypi kernel: [206717.764222] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 ff b7 23 80 00 00 08 00
Mar 21 19:28:59 raspberrypi kernel: [206717.764237] I/O error, dev sda, sector 4290192256 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
Mar 21 19:28:59 raspberrypi kernel: [206717.764260] Buffer I/O error on dev sda, logical block 536274032, async page read
et cette erreur dans messages
Mar 20 20:03:22 raspberrypi kernel: [122381.506975] scsi 0:0:0:0: Direct-Access USB2.0 CARD-READER 1.01 PQ: 0 ANSI: 2
Mar 20 20:03:22 raspberrypi kernel: [122381.508993] sd 0:0:0:0: [sda] Media removed, stopped polling
Mar 20 20:03:22 raspberrypi kernel: [122381.510724] sd 0:0:0:0: [sda] Attached SCSI removable disk
Mar 20 20:03:22 raspberrypi kernel: [122381.554520] sd 0:0:0:0: Attached scsi generic sg0 type 0
Mar 20 20:03:22 raspberrypi kernel: [122381.604092] sd 0:0:0:0: [sda] 4290192384 512-byte logical blocks: (2.20 TB/2.00 TiB)
Mar 20 20:03:22 raspberrypi kernel: [122381.605310] sda: detected capacity change from 0 to 4290192384
Mar 20 20:03:22 raspberrypi kernel: [122381.628496] sda: sda1 sda2
Mar 20 20:03:22 raspberrypi kernel: [122381.650940] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=DRIVER_OK cmd_age=0s
Mar 20 20:03:22 raspberrypi kernel: [122381.650981] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 ff b7 23 80 00 00 08 00
je vois une différence comme si il manquait la structure ?
