[Résolu] Ma zigate ne répond plus
calouis
Re: Ma zigate ne répond plus
Message par calouis »
pour info mon sudo nano /etc/udev/rules.d/99-usb-serial.rules donne ceci :
SUBSYSTEM=="tty", ATTRS{idVendor}=="067b", ATTRS{idProduct}=="2303", SYMLINK+="ttyUSB-Zigate"
SUBSYSTEM=="tty", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6015", SYMLINK+="ttyUSB-RFXComXL"
SUBSYSTEM=="tty", ATTRS{idVendor}=="0658", ATTRS{idProduct}=="0200", SYMLINK+="ttyUSB-Zwave"
_ Raspberry Pi3 Stretch + Domoticz V4.11214
_ dzVents Version: 2.4.28
_ Python 3.5.3
_ usbZwave
_ RFX433XL USB Version: Pro XL1/1035
_ GW Xiaomi
_ station meteo Oregon & Netatmo
_ LMS
_ Yeelight
_ Tradfri
_ Zigate plugin 4.11.012 + Version : 031d
calouis
pipiche a écrit : 02 déc. 2020, 15:01
calouis a écrit : 02 déc. 2020, 14:53
pi@Pi3_Domo:~ $ ls -l /dev/ttyUSB-Zigate
lrwxrwxrwx 1 root root 7 déc  2 14:45 /dev/ttyUSB-Zigate -> ttyUSB1
En gros tu pointes sur ton control usb-RFXCOM qui est sur ttyUSB1 !!
Je te recommande dans Domoticz de changer le port et de mettre:
usb-Prolific_Technology_Inc._USB-Serial_Controller-if00-port0
a la place de ttyUSB1
Pas mieux
2020-12-02 15:12:18.694 Sunrise: 08:34:00 SunSet: 16:53:00
2020-12-02 15:12:18.694 Day length: 08:19:00 Sun at south: 12:43:00
2020-12-02 15:12:18.694 Civil twilight start: 07:56:00 Civil twilight end: 17:30:00
2020-12-02 15:12:18.694 Nautical twilight start: 07:15:00 Nautical twilight end: 18:12:00
2020-12-02 15:12:18.694 Astronomical twilight start: 06:36:00 Astronomical twilight end: 18:51:00
2020-12-02 15:12:18.779 Active notification Subsystems: pushover (1/13)
2020-12-02 15:12:18.804 Starting shared server on: :::6144
2020-12-02 15:12:18.659 Status: Domoticz V4.11214 (c)2012-2019 GizMoCuz
2020-12-02 15:12:18.659 Status: Build Hash: e7672936b, Date: 2019-08-19 10:51:32
2020-12-02 15:12:18.659 Status: Startup Path: /home/pi/domoticz/
2020-12-02 15:12:18.771 Status: PluginSystem: Started, Python version '3.5.3'.
2020-12-02 15:12:18.782 Status: WebServer(HTTP) started on address: :: with port 8282
2020-12-02 15:12:18.796 Status: WebServer(SSL) started on address: :: with port 443
2020-12-02 15:12:18.804 Status: TCPServer: shared server started...
2020-12-02 15:12:18.845 Status: RxQueue: queue worker started...
2020-12-02 15:12:20.815 Status: YeeLight Worker started...
2020-12-02 15:12:20.816 Status: XiaomiGateway (ID=7): Delaying worker startup...
2020-12-02 15:12:25.816 Status: XiaomiGateway (ID=7): Selected as main Gateway
2020-12-02 15:12:25.816 Status: XiaomiGateway (ID=7): Worker started...
2020-12-02 15:12:25.817 Status: Netatmo: Worker started...
2020-12-02 15:12:25.817 Status: (ZG) Started.
2020-12-02 15:12:25.817 Status: (PiMoniteur) Started.
2020-12-02 15:12:25.817 Status: XiaomiGateway (ID=7): Using 192.168.1.12 for local IP address.
2020-12-02 15:12:25.818 Status: Pinger: Worker started...
2020-12-02 15:12:25.819 Status: EventSystem: reset all events...
2020-12-02 15:12:25.834 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Solardata.lua
2020-12-02 15:12:25.836 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/global_data.lua
2020-12-02 15:12:25.836 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Yeelight Scene Selector.lua
2020-12-02 15:12:25.837 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Rideau_Garage_Axroll.lua
2020-12-02 15:12:25.837 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Check_dead_devices.lua
2020-12-02 15:12:25.837 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/PIR_Cadre_Etage.lua
2020-12-02 15:12:25.837 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/PIR_Cadre_Salon_Nuit.lua
2020-12-02 15:12:25.838 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Bouton_Carre_Switch.lua
2020-12-02 15:12:25.838 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/PIR_Cadre_SdB.lua
2020-12-02 15:12:25.838 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/CO2_ruban.lua
2020-12-02 15:12:25.838 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Bouton_Rond_miBox.lua
2020-12-02 15:12:25.838 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/PIR_Evier.lua
2020-12-02 15:12:25.839 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/PIR_mi_box.lua
2020-12-02 15:12:25.839 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Dummy_Soir_salon.lua
2020-12-02 15:12:25.839 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Dummy_tv_cine.lua
2020-12-02 15:12:25.839 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Dummy_cuisine_eclairage.lua
2020-12-02 15:12:25.839 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Xiaomi_gw.lua
2020-12-02 15:12:25.840 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Dummy_Salon_Blanc.lua
2020-12-02 15:12:25.840 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/PIR_Salon.lua
2020-12-02 15:12:25.840 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Beaufort.lua
2020-12-02 15:12:25.840 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/xiaomiMP3.lua
2020-12-02 15:12:25.841 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Fin2Cycle.lua
2020-12-02 15:12:25.841 Status: EventSystem: reset all device statuses...
2020-12-02 15:12:25.903 Status: XiaomiGateway: RGB Gateway Detected
2020-12-02 15:12:26.859 (ZG) Device: 42 - ID: 1411, Name: 'ZG - PIR TV', nValue: 0, sValue: 'Off'
2020-12-02 15:12:26.859 (ZG) Device ID: '1411'
2020-12-02 15:12:26.859 (ZG) Device Name: 'ZG - PIR TV'
2020-12-02 15:12:26.859 (ZG) Device nValue: 0
2020-12-02 15:12:26.859 (ZG) Device sValue: 'Off'
2020-12-02 15:12:26.860 (ZG) Device LastLevel: 0
2020-12-02 15:12:26.860 (ZG) Device Options: {}
2020-12-02 15:12:26.860 (ZG) Device: 43 - ID: 1900, Name: 'ZG - Rideau G', nValue: 0, sValue: 'Closed'
2020-12-02 15:12:26.860 (ZG) Device ID: '1900'
2020-12-02 15:12:26.860 (ZG) Device Name: 'ZG - Rideau G'
2020-12-02 15:12:26.860 (ZG) Device nValue: 0
2020-12-02 15:12:26.860 (ZG) Device sValue: 'Closed'
2020-12-02 15:12:26.860 (ZG) Device: 44 - ID: 2162, Name: 'ZG - lumi.plug.mmeu01_Voltage', nValue: 0, sValue: ''
2020-12-02 15:12:26.860 (ZG) Device ID: '2162'
2020-12-02 15:12:26.860 (ZG) Device Name: 'ZG - lumi.plug.mmeu01_Voltage'
2020-12-02 15:12:26.860 (ZG) Device sValue: ''
2020-12-02 15:12:26.860 (ZG) Device: 45 - ID: 2163, Name: 'ZG - Nespresso_Conso', nValue: 0, sValue: '0.0'
2020-12-02 15:12:26.860 (ZG) Device ID: '2163'
2020-12-02 15:12:26.860 (ZG) Device Name: 'ZG - Nespresso_Conso'
2020-12-02 15:12:26.860 (ZG) Device sValue: '0.0'
2020-12-02 15:12:26.860 (ZG) Device: 46 - ID: 2164, Name: 'ZG - Nespresso_Cumul', nValue: 0, sValue: '0.0;256.5'
2020-12-02 15:12:26.860 (ZG) Device ID: '2164'
2020-12-02 15:12:26.860 (ZG) Device Name: 'ZG - Nespresso_Cumul'
2020-12-02 15:12:26.860 (ZG) Device sValue: '0.0;256.5'
2020-12-02 15:12:26.860 (ZG) Device Options: {'EnergyMeterMode': '1'}
2020-12-02 15:12:26.860 (ZG) Device: 47 - ID: 2165, Name: 'ZG - Nespresso', nValue: 0, sValue: 'Off'
2020-12-02 15:12:26.860 (ZG) Device ID: '2165'
2020-12-02 15:12:26.860 (ZG) Device Name: 'ZG - Nespresso'
2020-12-02 15:12:26.860 (ZG) Device sValue: 'Off'
2020-12-02 15:12:26.860 (ZG) Device: 48 - ID: 2168, Name: 'ZG - lumi.plug.mmeu01_Voltage-04cf8cdf3c7b094b-15', nValue: 0, sValue: ''
2020-12-02 15:12:26.860 (ZG) Device ID: '2168'
2020-12-02 15:12:26.861 (ZG) Device Name: 'ZG - lumi.plug.mmeu01_Voltage-04cf8cdf3c7b094b-15'
2020-12-02 15:12:26.861 (ZG) Device nValue: 0
2020-12-02 15:12:26.861 (ZG) Device sValue: ''
2020-12-02 15:12:26.861 (ZG) Device LastLevel: 0
2020-12-02 15:12:26.861 (ZG) Device Options: {}
2020-12-02 15:12:26.861 (ZG) Device: 49 - ID: 2169, Name: 'ZG - KIA Conso', nValue: 4, sValue: '4.514'
2020-12-02 15:12:26.861 (ZG) Device ID: '2169'
2020-12-02 15:12:26.861 (ZG) Device Name: 'ZG - KIA Conso'
2020-12-02 15:12:26.861 (ZG) Device nValue: 4
2020-12-02 15:12:26.861 (ZG) Device sValue: '4.514'
2020-12-02 15:12:26.861 (ZG) Device: 50 - ID: 2170, Name: 'ZG - KIA Cumul', nValue: 0, sValue: '4.51;851.4'
2020-12-02 15:12:26.861 (ZG) Device ID: '2170'
2020-12-02 15:12:26.861 (ZG) Device Name: 'ZG - KIA Cumul'
2020-12-02 15:12:26.861 (ZG) Device sValue: '4.51;851.4'
2020-12-02 15:12:26.861 (ZG) Device Options: {'EnergyMeterMode': '1'}
2020-12-02 15:12:26.861 (ZG) Device: 51 - ID: 2171, Name: 'ZG - 220FR - 2 KIA', nValue: 1, sValue: 'On'
2020-12-02 15:12:26.861 (ZG) Device ID: '2171'
2020-12-02 15:12:26.861 (ZG) Device Name: 'ZG - 220FR - 2 KIA'
2020-12-02 15:12:26.861 (ZG) Device nValue: 1
2020-12-02 15:12:26.861 (ZG) Device sValue: 'On'
2020-12-02 15:12:26.861 (ZG) Device: 52 - ID: 2730, Name: 'ZG - Portail', nValue: 0, sValue: 'Closed'
2020-12-02 15:12:26.861 (ZG) Device ID: '2730'
2020-12-02 15:12:26.861 (ZG) Device Name: 'ZG - Portail'
2020-12-02 15:12:26.861 (ZG) Device sValue: 'Closed'
2020-12-02 15:12:26.861 (ZG) Device: 53 - ID: 2781, Name: 'ZG - Volet Baie', nValue: 0, sValue: '0'
2020-12-02 15:12:26.861 (ZG) Device ID: '2781'
2020-12-02 15:12:26.861 (ZG) Device Name: 'ZG - Volet Baie'
2020-12-02 15:12:26.861 (ZG) Device sValue: '0'
2020-12-02 15:12:26.861 (ZG) Device LastLevel: 100
2020-12-02 15:12:26.862 (ZG) Device: 54 - ID: 2783, Name: 'ZG - Contact Volet', nValue: 0, sValue: 'Closed'
2020-12-02 15:12:26.862 (ZG) Device ID: '2783'
2020-12-02 15:12:26.862 (ZG) Device Name: 'ZG - Contact Volet'
2020-12-02 15:12:26.862 (ZG) Device nValue: 0
2020-12-02 15:12:26.862 (ZG) Device sValue: 'Closed'
2020-12-02 15:12:26.862 (ZG) Device LastLevel: 0
2020-12-02 15:12:26.862 (ZG) Device Options: {}
2020-12-02 15:12:26.862 (ZG) Device: 55 - ID: 2784, Name: 'ZG - Contact Baie', nValue: 0, sValue: 'Closed'
2020-12-02 15:12:26.862 (ZG) Device ID: '2784'
2020-12-02 15:12:26.862 (ZG) Device Name: 'ZG - Contact Baie'
2020-12-02 15:12:26.862 (ZG) DomoticzVersion: 4.11214
2020-12-02 15:12:26.216 Status: PluginSystem: Entering work loop.
2020-12-02 15:12:26.260 Status: Python EventSystem: Initalizing event module.
2020-12-02 15:12:26.260 Status: EventSystem: Started
2020-12-02 15:12:26.260 Status: EventSystem: Queue thread started...
2020-12-02 15:12:26.718 Status: (ZG) Entering work loop.
2020-12-02 15:12:26.719 Status: (ZG) Initialized version 4.11, author 'zaraki673 pipiche38'
2020-12-02 15:12:26.837 Status: (PiMoniteur) Entering work loop.
2020-12-02 15:12:26.838 Status: (PiMoniteur) Initialized version 3.1, author 'Xorfor'
2020-12-02 15:12:26.851 Status: (ZG) Zigate plugin stable-4.11.011 started
2020-12-02 15:12:26.851 Status: (ZG) Debug: 2
2020-12-02 15:12:26.862 Status: (ZG) load PluginConf
2020-12-02 15:12:26.864 Status: (ZG) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2020-12-02 15:12:26.864 Status: (ZG) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2020-12-02 15:12:26.864 Status: (ZG) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2020-12-02 15:12:26.864 Status: (ZG) pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigate/Logs/
2020-12-02 15:12:26.864 Status: (ZG) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2020-12-02 15:12:26.864 Status: (ZG) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2020-12-02 15:12:26.864 Status: (ZG) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2020-12-02 15:12:26.864 Status: (ZG) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-17.json
2020-12-02 15:12:26.864 Status: (ZG) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2020-12-02 15:12:26.864 Status: (ZG) channel set to 11
2020-12-02 15:12:26.864 Status: (ZG) port set to 8282
2020-12-02 15:12:26.864 Status: (ZG) Switching Heartbeat to 5 s interval
2020-12-02 15:12:26.864 Status: (ZG) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2020-12-02 15:12:26.864 [GCC 6.3.0 20170516]
2020-12-02 15:12:26.864 Status: (ZG) DomoticzVersion: 4.11214
2020-12-02 15:12:26.864 Status: (ZG) DomoticzHash: e7672936b
2020-12-02 15:12:26.865 Status: (ZG) DomoticzBuildTime: 2019-08-19 10:51:32
2020-12-02 15:12:26.865 Status: (ZG) Opening DomoticzDB in raw
2020-12-02 15:12:26.926 Status: (ZG) Plugin Database: DeviceList-17.txt
2020-12-02 15:12:26.934 Status: (ZG) DeviceConf loaded
2020-12-02 15:12:27.488 (PiMoniteur) Debug logging mask set to: NONE
2020-12-02 15:12:27.017 Status: (ZG) load ListOfDevice
2020-12-02 15:12:27.433 Status: (ZG) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-17.txt
2020-12-02 15:12:27.478 Status: (ZG) Transport mode: USB
2020-12-02 15:12:27.478 Status: (ZG) ==> Transport Mode: auto
2020-12-02 15:12:27.482 Status: (ZG) Connection Name: Zigate, Transport: Serial, Address: /dev/serial/by-id/usb-Prolific_Technology_Inc._USB-Serial_Controller-if00-port0
2020-12-02 15:12:27.482 Status: (ZG) Connection open: Name: 'ZiGate', Transport: 'Serial', Protocol: 'None', Address: '/dev/serial/by-id/usb-Prolific_Technology_Inc._USB-Serial_Controller-if00-port0', Port: '', Baud: 115200, Connected: False, Parent: 'None'
2020-12-02 15:12:31.857 (Opale) Temp + Humidity (Netatmo ext.)
2020-12-02 15:12:31.869 (Opale) Temp + Humidity + Baro (Netatmo int.)
2020-12-02 15:12:31.873 (Opale) Air Quality (CO2)
2020-12-02 15:12:31.876 (Opale) General/Sound Level (Sonomètre)
2020-12-02 15:12:32.166 Status: dzVents: Info: Handling events for: "CO2", value: "459"
2020-12-02 15:12:32.166 Status: dzVents: Info: ------ Start internal script: CO2_ruban: Device: "CO2 (Opale)", Index: 62
2020-12-02 15:12:32.171 Status: dzVents: Info: ------ Finished CO2_ruban
_ Python 3.5.3
_ usbZwave
_ GW Xiaomi
_ LMS
_ Yeelight
_ Tradfri
calouis
si ça peut aider :
pi@Pi3_Domo:~ $ sudo udevadm info --query=all --name=ttyUSB0
P: /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.3/1-1.1.3.3:1.0/ttyUSB0/tty/ttyUSB0
N: ttyUSB0
S: serial/by-id/usb-RFXCOM_RFXtrx433XL_DO2ZYL2E-if00-port0
S: serial/by-path/platform-3f980000.usb-usb-0:1.1.3.3:1.0-port0
S: ttyUSB-RFXComXL
E: DEVLINKS=/dev/ttyUSB-RFXComXL /dev/serial/by-path/platform-3f980000.usb-usb-0:1.1.3.3:1.0-port0 /dev/serial/by-id/usb-RFXCOM_RFXtrx433XL_DO2ZYL2E-if00-port0
E: DEVNAME=/dev/ttyUSB0
E: DEVPATH=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.3/1-1.1.3.3:1.0/ttyUSB0/tty/ttyUSB0
E: ID_BUS=usb
E: ID_MODEL=RFXtrx433XL
E: ID_MODEL_ENC=RFXtrx433XL
E: ID_MODEL_FROM_DATABASE=Bridge(I2C/SPI/UART/FIFO)
E: ID_MODEL_ID=6015
E: ID_PATH=platform-3f980000.usb-usb-0:1.1.3.3:1.0
E: ID_PATH_TAG=platform-3f980000_usb-usb-0_1_1_3_3_1_0
E: ID_REVISION=1000
E: ID_SERIAL=RFXCOM_RFXtrx433XL_DO2ZYL2E
E: ID_SERIAL_SHORT=DO2ZYL2E
E: ID_TYPE=generic
E: ID_USB_DRIVER=ftdi_sio
E: ID_USB_INTERFACES=:ffffff:
E: ID_USB_INTERFACE_NUM=00
E: ID_VENDOR=RFXCOM
E: ID_VENDOR_ENC=RFXCOM
E: ID_VENDOR_FROM_DATABASE=Future Technology Devices International, Ltd
E: ID_VENDOR_ID=0403
E: MAJOR=188
E: MINOR=0
E: SUBSYSTEM=tty
E: TAGS=:systemd:
E: USEC_INITIALIZED=6945416
pi@Pi3_Domo:~ $ sudo udevadm info --query=all --name=ttyUSB1
P: /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/ttyUSB1/tty/ttyUSB1
N: ttyUSB1
S: serial/by-id/usb-Prolific_Technology_Inc._USB-Serial_Controller-if00-port0
S: serial/by-path/platform-3f980000.usb-usb-0:1.3:1.0-port0
S: ttyUSB-Zigate
E: DEVLINKS=/dev/ttyUSB-Zigate /dev/serial/by-id/usb-Prolific_Technology_Inc._USB-Serial_Controller-if00-port0 /dev/serial/by-path/platform-3f980000.usb-usb-0:1.3:1.0-port0
E: DEVNAME=/dev/ttyUSB1
E: DEVPATH=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/ttyUSB1/tty/ttyUSB1
E: ID_BUS=usb
E: ID_MODEL=USB-Serial_Controller
E: ID_MODEL_ENC=USB-Serial\x20Controller
E: ID_MODEL_FROM_DATABASE=PL2303 Serial Port
E: ID_MODEL_ID=2303
E: ID_PATH=platform-3f980000.usb-usb-0:1.3:1.0
E: ID_PATH_TAG=platform-3f980000_usb-usb-0_1_3_1_0
E: ID_REVISION=0300
E: ID_SERIAL=Prolific_Technology_Inc._USB-Serial_Controller
E: ID_TYPE=generic
E: ID_USB_DRIVER=pl2303
E: ID_USB_INTERFACES=:ff0000:
E: ID_VENDOR=Prolific_Technology_Inc.
E: ID_VENDOR_ENC=Prolific\x20Technology\x20Inc.
E: ID_VENDOR_FROM_DATABASE=Prolific Technology, Inc.
E: ID_VENDOR_ID=067b
E: MAJOR=188
E: MINOR=1
E: SUBSYSTEM=tty
E: TAGS=:systemd:
E: USEC_INITIALIZED=6930632
_ Python 3.5.3
_ usbZwave
_ GW Xiaomi
_ LMS
_ Yeelight
_ Tradfri
calouis
d'apres Rules, mes liens sont bons ! donc rfxcom en ttyUSB0 et zigate en ttyUSB1.
au secours !
_ Python 3.5.3
_ usbZwave
_ GW Xiaomi
_ LMS
_ Yeelight
_ Tradfri
calouis
ce ne serait pas Strecht ou ma version de DZ qui pose pb?
_ Python 3.5.3
_ usbZwave
_ GW Xiaomi
_ LMS
_ Yeelight
_ Tradfri
pipiche
Message par pipiche »
Est-ce que si tu mets la clef sur un PC Windows et que tu la testes avec l'outil ZGUI elle fonctionne ?
Voir https://zigate.fr/documentation/tester-la-zigate-usb/
calouis
Je testerai WE prochain, j'avoue qu'après maj réussi du firmware, j'ai rebranché zigate sur monRpi et n'ai pas vérifié son fonctionnement avec l'outil Windows...
_ Python 3.5.3
_ usbZwave
_ GW Xiaomi
_ LMS
_ Yeelight
_ Tradfri
pipiche
calouis a écrit : 02 déc. 2020, 17:04 Je testerai WE prochain, j'avoue qu'après maj réussi du firmware, j'ai rebranché zigate sur monRpi et n'ai pas vérifié son fonctionnement avec l'outil Windows...
Après tu peux refaire un flash . Autre possibilité le module USB-TTL est en panne
calouis
Bonjour Pipiche
Je viens de reflasher la zigate.
Mais quand je teste son fonctionnement avec ZGWUI sur GetVersion une ligne de réponse au lieu de trois..
Dois-je en conclure que la zigate est HS ?
_ Python 3.5.3
_ usbZwave
_ GW Xiaomi
_ LMS
_ Yeelight
_ Tradfri
pipiche
Tu peux essayer de reflasher en faisant un erase EEPROM.
Après quoi si pas ok tu peux contacter le vendeur de la zigate peut-être aura-t-il d’autres pistes
Wiki ici
chat sur Keybase.io
